HP folio 1040 G3 Bios request
  • hyditech
    • Jun 2012
    • 272
    • nigeria
    Hello all please i need bios dump for (Da0y0fmbj1 rev:j)
    Hp elitebook folio 1040 g3 thanks
  • IDislikemakingLogins
    • Feb 2017
    • 38
    • moon
    Re: Hp elitebook folio 1040 g3
    Hi. I downloaded The bios update from hp, extracted it and found N83_0114.bin, its 9mb so its got padding or ec or other stuff inc. If you have a dump of the de-funk bios its sometimes possible to use it to find the beginning and end of the usable bios in the update file.
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Are there two bios chips-16MB & 8mb on this mobo??
      Post your old bios so that things are clear.
      • DProf.
        • Jun 2018
        • 100
        • Nigeria
        Bios dump 4 hp elitebook 1040 g3
        Good morning all. Pls I need bios dump for HP elitebook folio 1040 g3 board no DAOYOFMBAJ1-REV:J Someone should help me out please.
          • 21582
          Re: Bios dump 4 hp elitebook 1040 g3
          Try this one, if it doesn`t work then post your original bios backup .
          • Pascal Komlassan
            • Jan 2017
            • 809
            • TOGO
            thanks
            • Pascal Komlassan
              • Jan 2017
              • 809
              • TOGO
              https://www.badcaps.net/forum/attach...9&d=1547987707
              https://www.badcaps.net/forum/attach...0&d=1547987707
              • zmedia
                • May 2018
                • 63
                • Algerie
                BIOS HP 1040 G3 DA0Y0FMBAJ1
                DA0Y0FMBAH0 - Y0F
                • amr
                  • Apr 2017
                  • 5
                  • cairo
                  thank you very much
                  • fouzimiao85
                    • Jan 2020
                    • 10
                    • Algeria
                    thank you so much bro
                    • andresi
                      • Nov 2020
                      • 154
                      • INDONESIA
                      anyone can help me, i have bios coruppted, already erase, but i back to backup my bios i got no power, i use another bios i got no display
                      • peste
                        • Dec 2016
                        • 13335
                        • ROMANIA
                        what model is the motherboard ???
                        • andresi
                          • Nov 2020
                          • 154
                          • INDONESIA
                          da0y0fmbaj1 ref:j " hp 1040 g3"
                          • peste
                            • Dec 2016
                            • 13335
                            • ROMANIA
                            try it if it works, enter the DMI information ... here is a video for this ..
                            https://www.youtube.com/watch?v=9T57ktw8n3Y
                            • andresi
                              • Nov 2020
                              • 154
                              • INDONESIA
                              thnk you sir, this work
                              • ketan19
                                • May 2021
                                • 16
                                Hello. Can someone help me fix the BIOS/flash a new one please. I have been trying constantly for 2 weeks .
                                The Elitebook that I have was given to me from someone who worked for the company on some projects and it always had the message "this BIOS is not a production version". I upgraded the laptop along with BIOS which said it went through successfully, however, it never started after the shutdown. I have tried various ESC/f2.Win+B/Win+V options along with 4-1 USB recovery key and nothing seems to work. There is no display at all.
                                Now I got myself a ch341a programmer and I am able to read and write to the BIOS however I am not getting anywhere. I found random files for this system/the IC chip but none have worked. The most I got was the Fans spinning from one bin file. Another thing I noticed is that this system may have a different motherboard than normal? unsure. I can attach the BIOS copy I took after I connected the ch341a programmer to this system. Not sure if it is helpful or not. At this time I just want the laptop running to some state.
                                The IC seems to be Winbond 25q128fvsq 1621. I do not know what having 2 BIOS mean or how to find that. The motherboard has the number DA0Y0FPIAHI REV: H on it.
                                The system is HP FOLIO 1040 G3 with 12 GB RAM , 256 SSD.
                                • ketan19
                                  • May 2021
                                  • 16
                                  Re: HP folio 1040 G3 Bios request
                                  Correction: The motherboard seems to be DA0Y0FPIAH1 REV: H
                                  • ketan19
                                    • May 2021
                                    • 16
                                    Correction 2 : the motherboard may actually be 844418-601 and the processor is Intel I7-6600u
                                    • Mazorca
                                      • Jan 2017
                                      • 463
                                      Looking from the heatsink/cpu side, check if you have this right under the m.2 SSD: DA0Y0FMBAJ1 Rev J
                                      You will have to remove the drive in order to see the motherboard model. It is also on the back of the board. If so, then check these link, post #2. https://www.badcaps.net/forum/showth...ht=DA0Y0FMBAJ1
                                      I couldn't make sense of the bios, it is corrupt.
                                      • ketan19
                                        • May 2021
                                        • 16
                                        It's something totally different it seems... DAY0FAMBAC1 REV:C
                                        Its crazy that a bios update corrupted it. the update was from HP website itself. what else can i try?
                                          HP EliteBook Folio 1040 G3 Notebook 1040 Specification for Upgrade or Repair
                                          This specification for the HP EliteBook Folio 1040 G3 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1040 G3 boardview and 1040 G3 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP...
                                          09-06-2024, 06:06 AM
                                          HP EliteBook Folio 1040 G2 Notebook 1040 Specification for Upgrade or Repair
                                          This specification for the HP EliteBook Folio 1040 G2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1040 G2 boardview and 1040 G2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP...
                                          09-06-2024, 05:30 AM
                                          HP EliteBook Folio 1040 G1 Notebook 1040 Specification for Upgrade or Repair
                                          This specification for the HP EliteBook Folio 1040 G1 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1040 G1 boardview and 1040 G1 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP...
                                          09-06-2024, 05:27 AM
                                          HP EliteBook Folio EliteBook Folio G1 Notebook Specification for Upgrade or Repair
                                          This specification for the HP EliteBook Folio EliteBook Folio G1 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook Folio G1 boardview and EliteBook Folio G1 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-06-2024, 06:34 AM
