HP folio 1040 G3 Bios request
  • ketan19
    • May 2021
    • 16
    Re: HP folio 1040 G3 Bios request
    Still looking for help on this .can anyone point me to right direction?
      • 21584
      Your bios backup is only 1MB. The ch341a software is`t good, try this alternative:
      https://www.badcaps.net/forum/showpo...04&postcount=7 NeoProgrammer
      You have 2 bios chips on the board,you`ll see a white silkscreened number at the side of them, U23 and U32. If you`re using a sop8 clip then attach the charger to the board,after you attach the clip.Make 2 backups of each chip, open them with HxD hex editor and use the File Compare to check that both backups are identical (or use some other file compare method).If they`re not then make more backups until they are (its more reliable to desolder the chips). Post one of each backups and someone will help.
      https://mh-nexus.de/en/hxd/
      • ketan19
        • May 2021
        • 16
        Thank you for the response. At this time I believe I have messed up as I have erased and written multiple bios files to the U23 IC. The only BIOS/partial BIOS i have is the 1 MB file I saved before writing new files on the IC. I was able to read and confirm files with 2 copies for the U32 BIOS. I have attached both to this. Really hoping I can do something about the U23 file . I have ordered a new laptop now to work from. Hopefully, I can fix this and cancel that order .. Any help is really appreciated. Would getting new IC's from internet/ebay help?
        • ketan19
          • May 2021
          • 16
          I was able to get the backup of U32 IC as attached, however, I only have the 1 MB bios file that I backed up for the U23 IC. I am not sure if that was a bad backup or the BIOS update had messed up the BIOS file. Attached both files here. Hoping this can be resolved..
          • ketan19
            • May 2021
            • 16
            Still looking for some progress..
            • ketan19
              • May 2021
              • 16
              Tried few more BIOS files however dont see anything for this motherboard .still looking for any help on this.
              • ketan19
                • May 2021
                • 16
                adding note to bump this on top. Still looking for assistance on this..
                • ketan19
                  • May 2021
                  • 16
                  HP folio 1040 G3 Bios - edit from clean bios
                  Hello team,
                  I was unable to get anywhere with my failed BIOS update on HP folio 1040 g3 i7 system. From flashing a lot of BIOS bin files, I didn't get anywhere. I believe the only next move would be to try and get the bin file from the HP website update and try to update system info in it before flashing.
                  Can someone point me to the right direction on what I would need to update on the bios file downloaded from HP webpage to make this system book?
                  The motherboard is : DAY0FAMBAC1 REV:C
                  The system is HP FOLIO 1040 G3 with 12 GB RAM , 256 SSD
                  IC seems to be Winbond 25q128fvsq 1621 for U23
                  I do not have the original BIOS from this before it got corrupted.
                  The serial seems to be : 5CD633ORHZ
                  I have downloaded the attached file.
                  Any help will be appreciated.
                  Previous post : https://www.badcaps.net/forum/showth...=1040+folio+g3
                  • qayyum786
                    • Aug 2018
                    • 1958
                    • INDIA
                    #29
                    Re: HP folio 1040 G3 Bios - edit from clean bios
                    Post proper file its 9mb only
                    • qayyum786
                      • Aug 2018
                      • 1958
                      • INDIA
                      #30
                      Your file is 9 mb
                      it should be 16mb
                      read again and post here
                      i think ic number 25q128fvsq and 25b64csig
                      • ketan19
                        • May 2021
                        • 16
                        Thank you for the quick update . unfortunately I do not have the bios file from the u23 IC. When I tried to flash it the first time it got bricked, it was only a 1MB file in it, which makes me think it never got updated .I did find a 8 MB file in the u32 IC. I have attached these files here. Where can I get the 16 MB file for the u23?
                        The previously attached file is just from the extracted content from bios update file from HP website.
                        • qayyum786
                          • Aug 2018
                          • 1958
                          • INDIA
                          #32
                          TYR FROM HERE
                          https://www.alisaler.com/hp-eitebook...mbaj1-bios-ec/
                          • ketan19
                            • May 2021
                            • 16
                            Originally posted by qayyum786
                            I tried these two. For the U32 IC with the ~8 MB file, I kept getting a Verification error on address: 00002010 and similar errors. this didn't happen earlier. when I skipped verifying and wrote the bios anyway, I don't see the charging indicator as well on the laptop when I plug in the power. I have the battery disconnected. Unsure whether something shorted or its writing to U32 that did that.
                            • ketan19
                              • May 2021
                              • 16
                              Still looking for assistance on this. Any help would be appreciated
                              • qayyum786
                                • Aug 2018
                                • 1958
                                • INDIA
                                #35
                                i try many site to get bios for this model its not available in our forum but also another site also
                                its available only in few paid sites
                                lets see i will try with some one to get it for you from there
                                • ketan19
                                  • May 2021
                                  • 16
                                  Can you share the paid sites? I can check them out too.
                                  Thank you!
                                  • qayyum786
                                    • Aug 2018
                                    • 1958
                                    • INDIA
                                    #37
                                    can you share the paid sites? I can check them out too.
                                    Thank you!
                                    paid site link cannot send or work here
                                    here is everything for free
                                    this file is available on the "vinafix site"
                                    and this file also from "vinafix" is corrupted because its posted to fix the file by a vinafix client but
                                    we just need that exact file for the reference because of this non good file we can build a new one for you
                                    btw i attached 2 pic so you can see & make sure its model and both bios file given by numbers
                                    you can google by this name is given in image 1 and type "vinafix" ahead to find that
                                    • qayyum786
                                      • Aug 2018
                                      • 1958
                                      • INDIA
                                      #38
                                      try this @KETAN
                                      both file attached U32 & U23
                                      • dahnking
                                        • Apr 2018
                                        • 261
                                        • kenya
                                        #39
                                        Re: Hp elitebook folio 1040 g3
                                        Originally posted by zmedia
                                        BIOS HP 1040 G3 DA0Y0FMBAJ1
                                        DA0Y0FMBAH0 - Y0F
                                        Perfect
                                        Thank you 100%
                                        • MAZMAZ22
                                          • Jul 2016
                                          • 68
                                          • ALGERIE
                                          #40
                                          Re: Bios dump 4 hp elitebook 1040 g3
                                          NEED TO REPAIR MY BIOS hp elitebook 1040 g3 DA0Y0FMBAJ1
                                            HP EliteBook Folio 1040 G3 Notebook 1040 Specification for Upgrade or Repair
                                            This specification for the HP EliteBook Folio 1040 G3 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1040 G3 boardview and 1040 G3 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP...
                                            09-06-2024, 06:06 AM
                                            HP EliteBook Folio 1040 G2 Notebook 1040 Specification for Upgrade or Repair
                                            This specification for the HP EliteBook Folio 1040 G2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1040 G2 boardview and 1040 G2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP...
                                            09-06-2024, 05:30 AM
                                            HP EliteBook Folio 1040 G1 Notebook 1040 Specification for Upgrade or Repair
                                            This specification for the HP EliteBook Folio 1040 G1 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1040 G1 boardview and 1040 G1 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP...
                                            09-06-2024, 05:27 AM
                                            HP EliteBook Folio EliteBook Folio G1 Notebook Specification for Upgrade or Repair
                                            This specification for the HP EliteBook Folio EliteBook Folio G1 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook Folio G1 boardview and EliteBook Folio G1 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-06-2024, 06:34 AM
