Apple iMac 27" A2115 2019 efi firmware UNLOCKED
    Is there any one who can help unlock the efi firmware file attached?
    It is for Apple iMac 27" A2115 2019.
    Appreciate the help.
    Re: Apple iMac 27" A2115 2019 efi firmware UNLOCKED
    try..
      Thank you for the prompt response. I'll try and give you feedback in 2 days.
      Thanks again for the great help.
        Originally posted by peste View Post
        try..
        I tried the file, but it did not work. Any idea?
        Thanks again
          You sure this is not T2 model?
            No, T2 is only found on the 2020 model.
              Try this one. Make sure you do PRAM reset.
                Hi, I've tried this one and the iMac will not boot into an OS. It loads for a while then reboots.
                  hi can someone help unlock the efi firmware file attached?
                  Apple iMac 27" A2115 2019 emc 3194.
                    try..
                      Hi all! I have an iMac 2019 27" A2115 EFI locked. Pressing the option button during boot doesn't give me any options to boot from a usb stick. Just the apple logo.
                      I have attached the original bios file. Can someone unlock it? I've already tried 2 different bios files I found here and there but no luck so far. Thanks in advance guys!
                        try...
                          try...
                          Thank you for the response! Unfortunately it doesn't work. The apple logo is not showing up at all after flashing this file. Do you have any suggestions or a different version to try out?
                            try the blocked bios again.. see what happens..
                              Hello, I've A2115 with winbond EFI chip. ( W25Q128JVSQ ) . Can I use the attached file starting with mx in this topic ? Or how to find original EFI firmware file for A2115 ?
                                Originally posted by webhost
                                its was a mistake , before i attach another bios dump
                                found here the original dump
                                thank You
                                Please read the updated rules,serial numbers are now required.
                                https://www.badcaps.net/forum/showthread.php?t=103569
