Capacitor Nudging
  • Kong
    • Jul 2010
    • 19
    Capacitor Nudging
    I was inspecting a soundcard's front panel I/O board when I noticed that one of the larger capacitors (25v 220uF) was bent. I gently nudged it a little, let it settle, and nudged it some more until it was back around 90 degrees. There doesn't appear to be any damage to the capacitor itself, and the legs are still going completely through the other side of the board and up into the base of the capacitor with no apparent damage.
    Would you say this capacitor should still be functional?
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Capacitor Nudging
    Chances are that it is good UNLESS there is/was bad/cracked/poor solder joints. The leads can take a bit of punishment.
    --- begin sig file ---
    --- end sig file ---
    • seanc
      • Nov 2008
      • 1319
      Should be fine, unless the reason for it being bent over was because the bung is pushing out of the bottom.
      • Kong
        • Jul 2010
        • 19
        Thanks for the replies.
        The solder joints appear to be intact, and the bottom of the actual capacitor seems to be even.
        • MORETTIGIAN
          by MORETTIGIAN
          Title:
          Description:
          Procedure performed:
          - Removed backplate
          - Reapplied thermal compound
          - Reassembled card
          09-18-2025, 12:14 PM
        • Prolog
          by Prolog
          12-01-2024, 08:27 PM
        • chth96
          by chth96
          12-22-2023, 04:34 AM
        • chth96
          by chth96
          06-02-2024, 07:31 PM
        • chth96
          Is it no harm to replace with capacitor without ripple current rating?
          by chth96
          When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
          Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
          But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
          Rubycon YK DataSheet (b...
          04-19-2024, 05:19 AM
