Video Editing That Allows Adding Lines and Objects
  • JonathanAnon
    • Jul 2012
    • 457
    • Ireland
    Hi Guys,
    I'm looking for software that will allow me to put in text, arrows and shapes for tutorial and demonstration. Of all the free video editors I have tried the only ones that have the ability to add lines and shapes are VSDC and Power Director.
    I want to put together tutorials and point to things and put in values and the like. I've settled on VSDC. Does anybody in the community have an objection to my decision?
    thanks,
  • joelz
    pin Setting parameter line or set lines menu for adding ITE5571e on RT809F programmer
    by joelz
    Hi, sorry if i here to request if anyone know number of pin to set lines for reading ITE7751e on RT809F..i try to see on schematic but i dont know how to choose it..pleasee..
    11-18-2024, 06:02 AM
  • Stanley1843
    by Stanley1843
    06-29-2024, 11:54 AM
  • jeyoung12
    Samsung QN50Q60t lines on screen
    by jeyoung12
    Hi all
    I have lines on the screen...which is an age old problem that can be remedied by watching Youtube videos and getting out the tape.
    My issue (after successfully fixing a different sammy tv with a separate tcon board and isolating the side of the panel...):
    This tv has an integrated tcon...so it is a bit more confusing when trying to isolate the clocks.
    It has a c ribbon and i have taken each end out to see if that will isolate the lines. instead, it makes it much worse ALL over the tv!
    So....i don't know what end of the C ribbon to work with...
    02-26-2024, 10:38 AM
  • pni
    LG 49uf695v vertical coloured lines
    by pni
    Hi guys…I need your help. My cousin ask me to fix her tv. The tv when I went to pick up showed 3 horizontal black line. So I know it was a bad panel issue but I could try to fix with the tape method so I said her I could fix easy. When I come back to home, I turned on the tv and now the tv show vertical line colored….and the problem is that I unplug the ldvs cable, first the right side then the left side I still have the lines. The lines never disappear. When the right side is plug in I don’t have nothing on the screen only this vertical lines, when the right side is unplugged I have picture...
    11-14-2025, 03:15 AM
  • howardc64
    by howardc64
    07-24-2025, 05:17 PM
