TP-link
  • MiG
    • Jan 2009
    • 28
    TP-link
    Any good of theesee network equipement? Bad or goood? Thanx!
  • NxB
    • Feb 2009
    • 1595
    Re: TP-link
    Its ok. Does what it should. I would read reviews on specific models.
    • howardc64
      Samsung UN55JU650DF network/streaming problem
      by howardc64
      Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
      This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
      07-09-2025, 12:44 PM
    • davg
      Home network connection problem
      by davg
      I just bought a new ThinkPad laptop and I need to connect it to my home network. I have several computers on my network and can see each other in File Explorer and the older ones can communicate with each other (even with the new one) but the ThinkPad can see the other computers but can't communicate with them. I get the (network error 0x80070035 The network path not found). I tried several scenarios that I found on line but none of them worked?? Since the other computers on the network can communicate fine I'm assuming the problem is with the setup of the ThinkPad? All computers are running Windows...
      03-06-2021, 07:13 AM
    • japlytic
      Maximum speed should be marked on network ports
      by japlytic
      I noted that a number of consumer entertainment devices have the maximum speed marked on the wired network port and considering that there are broadband plans faster than 100 Mbit, the wired network port can be a bottleneck since some routers do not have Gigabit (only 100 Mbit) support for the WAN port let alone the wired network ports.
      One other thing: Certain low cost network cables only have two pairs which limits speed to 100 Mbit.​
      12-19-2024, 05:04 PM
    • hikomalek
      SYMSI70 gas heater, TOP247Y exploded, power supply, snubber network
      by hikomalek
      Hello, I have a SYMSI70 gas heater board, which has issues with its primary side power supply, controlled by TOP247Y chip.
      When I replace a TOP247Y it explode in 1 second. I have desoldered transformer and measured a winding ratio, so transformer looks like OK.
      Transformer:
      |Info| Primary | Aux | AB | CD|
      |Ratio|1|25|40|12|
      |Voltage AC|230V|9.2V|5.8V|19V|
      |Voltage DC (*1.41)|230V|13V|8.1V|27V|
      I have disabled a undervoltage protection of TOP247Y, disconnected secondaries and tried to power it up...
      09-19-2025, 03:30 AM
    • harp
      simple win network with optimization issue
      by harp
      simple win network with optimization issue I like to ask some question about configuring simple room win network. So, there is 2 win computer, android4 device and wifi router not connected to internet. The purpose is storage space and manipulation with large files between any device. 1 pc - 192.168.0.2 (winxp sp2) wired to router port#1 2 pc - 192.168.0.5 (win10, enabled smb1.1) wired to router port#2 3 router - 192.168.0.1 with dhcp for wifi (192.168.0.101...) 4 main tablet - 192.168.0.101 (android4) wified to router wifi port I generally work and control transfer with my tablet via ES3 file...
      06-23-2025, 11:01 AM
