Needs help with HP Compaq d530 cmt
  • Phaihn
    • Jan 2009
    • 842
    Does anyone know how to put windows XP on a HP Compaq d530 cmt.?
    My Computer.
    AMD APU A4-3300 2.5ghz 1mb cache
    Motherboard GigaByte GA-A75M-S2V
    Kingston HyperX Blue DDR3 8GB (2x4GB)
    SB Audigy 2 ZS [B800] Sound Card
    500GB WD Caviar® Blue™
    1 Terabyte WD Caviar® Black™
    2 Terabyte WD Caviar® Black™
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: Needs help with HP Compaq d530 cmt
    what version?
    sigpic
    (Insert witty quote here)
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      do you have the restore cd?
      sigpic
      • Phaihn
        • Jan 2009
        • 842
        My Computer.
        • Phaihn
          • Jan 2009
          • 842
          what version?
          Windows XP Home and no i dont have a restore cd i got this used from the computer store along with a motherboard and a 3 ghz CPU i traded for my 2.8 GHZ CPU.
          My Computer.
          • KeriJane
            Mac Enthusiast
            • Sep 2008
            • 681
            Hi Phaihn
            There are a couple of ways to legally re-install Windows XP on that machine.
            Assuming that the machine will boot and ask for a system disk and that the original XP Home Certificate of Authenticity (COA) is still attached AND the machine has its original BIOS with the SLP information intact:
            1- Use either an original Restore CD or an original hard drive repair partition. This method does not require entering a CD-Key as the original disk uses "System-Locked Pre-Activation" (SLP) which checks to see if the BIOS matches the install disk.
            here's one vendor of Restore CDs: http://restorecd4u.com/index.php
            2- Use an "OEM" XP Installation disk and use the CD Key on the machine's COA. The installer doesn't always accept these CD Keys, but usually does. You will probably have to call Microsoft during the Activation Process if you choose this method. This method must be used if the machine does not have the original BIOS or motherboard.
            There are also any number of questionably legal and outright illegal methods to install XP but it's best to stick to the legal ones as the machine is already licensed to use XP.
            OH! do NOT post a picture of the Microsoft Certificate of Authenticity without first making the CD Key illegible using Photoshop or somesuch. It's practically guaranteed that someone else will snag the number and activate it with MS before you do. (MS only allows one unique computer to use each number)
            Have Fun,
            Keri
            The More You Learn The Less You Know!
            • Phaihn
              • Jan 2009
              • 842
              As you can see it didn't come with a key but i got a different one but i think i would rather use a different board in this case but without the plate for the motherboard there are no standoffs to mount it on.
              My Computer.
              • KeriJane
                Mac Enthusiast
                • Sep 2008
                • 681
                Hi Phaihn
                If someone else snagged the COA, M$'s stand is that you must purchase a new one. The cheapest way to do so is with the "System Builders kit" or OEM version.
                If you obtained one another way, they may or may not allow you to activate it.
                The Restore CD is keyed to the specific model's BIOS, so if you intend to replace the board, don't bother getting the original CD. Just get the OEM System Builder disk which comes with a COA.
                Using the original board and Restore CD is the tidiest method. No fooling around with M$'s "Activation" Scheme. (M$'s Activation nonsense helped drive me to Mac)
                Have fun,
                Don't annoy the 800lb gorilla,
                Keri
                • Phaihn
                  • Jan 2009
                  • 842
                  My Computer.
                  • Phaihn
                    • Jan 2009
                    • 842
                    Originally posted by KeriJane
                    Hi Phaihn
                    Have fun,
                    Keri
                    I was thinking of useing a difrnt Board cause this one has a really funny Bios i cant get it to do what i want.
                    I dont think ill have troble with the key the guy said when they ask why i am reactivating just tell them i blew a board.
                    i only have one CPU between the 2 systems anyway i just wanted to see how well this thing worked.
                    My Computer.
                    • Phaihn
                      • Jan 2009
                      • 842
                      I am not asking how to activate windows i just want to know how to get this board to boot from the CD to install it wont even boot from my hard drive.
                      My Computer.
                      • ratdude747
                        Black Sheep
                        • Nov 2008
                        • 17136
                        could you please downsize your images? you are making things too wide. try to stick to 700p max width.
                        why must you upgrade? the bios takes abit of time to get used to, but that is no reason to switch mobos.
                        besides, most times the fron panel wires (hdd light, pwr light/sw) are in a block and will not usually fit the pin layout of another moldel motherboard. sometimes you can separate them into seperate plugs but that that is a pain. the screw hole layout should not be maddedas you could
                        - short the mobo
                        -break the mobo due to lack of support or cramming it where it doesnt fit
                        -break other things as it might not fit.
                        - mess up the cooling system
                        are you sure there is no code?
                        it should look like one of these:
                        again i see no reason to switch mobos
                        if you must, then find a good, not flimsy case (see https://www.badcaps.net/forum/showth...e+buying+tips). trying to shoehorn mobos into oem cases they dont fit is a bad idea.
                        sigpic
                        • ratdude747
                          Black Sheep
                          • Nov 2008
                          • 17136
                          quote: I dont think ill have troble with the key the guy said when they ask why i am reactivating just tell them i blew a board.
                          dont try that. that will come to bite you in the ass. they know you are lying and you will fail. if you dont like how this system works,then try ubuntu linux. completely free, faster, more secure, less viruses, tons of free, well designed software, almost all hardware supported. if you dont like something dont use it
                          sigpic
                          • Phaihn
                            • Jan 2009
                            • 842
                            it will fit it just needs standoffs for the holes.
                            My Computer.
                            • Phaihn
                              • Jan 2009
                              • 842
                              I know what the keys supposed to look like there's one on my main computer.
                              My Computer.
                              • ratdude747
                                Black Sheep
                                • Nov 2008
                                • 17136
                                trust me, the front panel connectors WILL NOT FIT!!!!!!!!!!!
                                i have that model and they are proprietary. its not worth it
                                what don't you like about the bios?
                                sigpic
                                • Phaihn
                                  • Jan 2009
                                  • 842
                                  i cant get it to install windows from the CD or the hard drive. and i cant figure out how to get to command prompt it might be a unix but the case says windows XP.
                                  My Computer.
                                  • Phaihn
                                    • Jan 2009
                                    • 842
                                    OK then tell me how to make it work cause i cant get it to load windows or boot from hard drive it says its a non system disk
                                    My Computer.
                                    • 370forlife
                                      Large Marge
                                      • Aug 2008
                                      • 3112
                                      First, in the bios, make sure the boot order has the cd drive first, have a known good cd drive, make sure your cd is in good condition, make sure your jumpers for your drives are right, on the right connectors on the cable, and make sure your hard drive is good.
                                      The connectors for the front usb and sound looks like the standard, non-proprietary connectors
                                      http://www.ixbt.com/power/psu/photos...sutest_018.jpg,
                                      is that what the front usb connector looks like?
                                      • Phaihn
                                        • Jan 2009
                                        • 842
                                        And Sata wont work either yeah the connectors are different
                                        do you know where i can get a bios update for it i think its mighty old.
                                        i love the fan that i got out of it tho lol...
                                        My Computer.
                                          HP Compaq Compaq SG3-240ES Compaq SG3 220 Specification for Upgrade or Repair
                                          This specification for the HP Compaq Compaq SG3-240ES can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Compaq SG3-240ES boardview and Compaq Compaq SG3-240ES schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-12-2024, 03:44 PM
                                          HP Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) Compaq Elite 8000 E5500 Specification for Upgrade or Repair
                                          This specification for the HP Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) boardview and Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request...
                                          HP Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower Compaq Pro 6005 B59 Specification for Upgrade or Repair
                                          This specification for the HP Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower boardview and Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information....
                                          09-12-2024, 03:36 PM
                                          HP Compaq Compaq dc7900 Compaq Q9400 Specification for Upgrade or Repair
                                          This specification for the HP Compaq Compaq dc7900 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Compaq dc7900 boardview and Compaq Compaq dc7900 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                          09-12-2024, 03:30 PM
                                          HP Compaq Compaq SG3-331IT Compaq SG3 245 Specification for Upgrade or Repair
                                          This specification for the HP Compaq Compaq SG3-331IT can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Compaq SG3-331IT boardview and Compaq Compaq SG3-331IT schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
