Trouble finding telephone patch panel.
  • Spork Schivago
    • Mar 2012
    • 4734
    • United States of America
    Hi!
    I'm looking and having trouble finding a patch panel for a PSTN telephone line. I tried using a regular cat 6 patch panel and just daisy chaining every port together, but that didn't work so well.
    I've found patch panels that are made for ISDN, but I don't have an ISDN line and probably never will. Eventually, we'll switch to VoIP, but that's still a ways away.
    Right now, I'm just looking for a patch panel where I can run in the incoming PSTN line to and have it distributed to all the ports (hopefully, at least 48 ports), and then run my cat 5e line from the wall plates to the various ports on the panel, punch them down, and have telephone working.
    Does anything like that exist and if so, could someone please help me try to find it? Maybe my search queries been wrong. I've been searching for PSTN telephone patch panel. I was hoping for one that supported 4 lines, 8P8C
    Thanks!
    -- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full
  • Spork Schivago
    • Mar 2012
    • 4734
    Re: Trouble finding telephone patch panel.
    Oh man, I think my college neglected to go over 66 blocks and 110 blocks. I mean, we went over 110 blocks, but we were just taught that's what regular patch panels use. When I heard people talk about 110 blocks, I didn't realize they weren't talking about ethernet punch down patch panels.
    We found a nice article that describes 110 blocks for telephones https://tombuildsstuff.blogspot.com/...telephone.html
    and how to wire them up, with the C-Clips, etc. I've never seen anything like that before, but will be purchasing one. It's not what I was imaging but I was attempting the same thing (with the bridges) using my cat 6 patch panel. I just didn't have c-clips.
    If I understand what I read, if I want 4 incoming lines, 48 telephone wall plates, I'd need a 400 pair 110 block, right? The first 8 rows would hold the lines going to the wall plates, the next 8 rows would all be bridges. Is that correct?
    I wonder if there's a more efficient way to wire those blocks where I don't have to dedicate one row of bridges for every row of lines used. That will add up super quick like. 400 pair block is going to take a lot of room in the rack.
      • 31094
      no way.
      look up "REN", line-load etc.
      you cant have more than 3-4 phones on a line without some type of powered booster.
      look at auctions for an old company PBX setup - terminal-handset, slave handsets and control-box.
      • Spork Schivago
        • Mar 2012
        • 4734
        What do you mean we cannot have more than 3-4 phones on a line without some type of powered booster? Only one phone will be active at a time, maybe two.
        4 pairs of wire in CAT 5e, that should mean up to 4 lines per cable. Right? I'm looking for something like this:
        https://www.leviton.com/en/products/47603-18b
        Supports up to 4 incoming lines, has 18 RJ-45 jacks for the lines going to the wall plates. It has an IDC input. A couple of those daisy chained together would be good. But I wanted something that was made for a rack. Those are made for a media enclosure. I could always mount them to a rack shelf I guess.
        • Spork Schivago
          • Mar 2012
          • 4734
          I read up on REN. Just so I'm a bit more clear, most of these phone lines will NOT have a phone hooked to them. We're installing them in each room, on the walls, so IF we want a phone hooked up, we can add one anywhere. For example, there is currently 4 active telephones in our house, but only one is hooked to the wall jack. They're all wireless telephones. Their ringers are not powered by the actual telephone line.
          Does that clear it up a bit?
            • 31094
            it does - you should have said outlets instead of phones.
            • Spork Schivago
              • Mar 2012
              • 4734
              That's my mistake. Haven't gotten a lot of sleep lately and started making some stupid mistakes. I try to stop working at 10:30pm now, no matter where I'm at and try to make sure I get a full night sleep.
              It's a real pain running wires. The shielded ethernet is much stiffer than what I'm accustomed too. The Belden 2412F F/UTP is just a little too big to fit into these BlackBox C6EZSP plugs. I think we should have been sold the BlackBox C6EZSP-STAG-100PAK ends, which say they're made for larger OD cables.
              We make the C6EZSP plugs work, but we have to spend a good amount of time getting the cable in far enough to prevent cross-talk. Real pain in the butt! I'm tempted to just scrap these C6EZSP's and just buy the C6EZSP-STAG's.
              I really wanted to the Belden R301602 plugs, but they're just too much money. They look real nice though. I'm trying to get Belden to send us a sample to try them out.
              • howardc64
                LG 49UJ6500 LCD panel lighter band that goes away
                by howardc64
                49UJ6500 LCD panel has a lighter band on top when first powered on. Goes away (or gets much fainter) after TV on for a few min. After powered off for awhile and power back on, same band appears. If powered on immediately after powering off, no or much fainter band. Running the latest firmware.
                Disassembled the TV and lifted the LCD panel during testing. Band is on the LCD panel (can see the band on the panel as I lift it slightly) Backlight is perfectly even at the top edge. Double checked LCD panel alignment in the frame and is perfect but since band moved with the panel, its on...
                02-19-2023, 12:13 AM
              • triplefour
                SAMSUNG UN50TU8000F rebooting, backlight ok. No 12v to panel boards.
                by triplefour
                TV flashes backlight then reboots over and over. no image. Client said it used to have image for a bit before rebooting. Got worse over time.
                tcon is built into mainboard.
                Only one cable goes to panel boards.
                there is a cable from one panel board to the other that links them.
                cost cutting measure that results in us having harder time to diagnose.
                removing the link to the second panel board allows TV to stay on with stable backlight but no image.
                used cut off tape method to mask 1 maybe 2 pins on the side of the cable that goes to that second panel board....
                07-28-2022, 07:59 PM
              • Storyteller12
                QN55Q60R Service Menu Panel Help
                by Storyteller12
                I had a the above tv qn55q60r that had a bad panel but everything else good. I had another panel here from un55nu6900 with bad leds and melted diffusers.
                I put the nu6900 panel in and powered it up and it does work but there are lines vertical lines.
                I was trying to change the panel type in the service menu but don’t see my exact panel. Anyway to fix this or someone have similar experience.
                the clear picture is the panel type from the service menus on the nu6900. The other 1 is the panel type that was set for the q60r with the bad panel....
                01-13-2024, 01:57 PM
              • maneatingmonkey
                Missing LCD Panel Voltages VGH, VGL, VCOM (TCL 55P6US Sound & Backlight but NO Picture)
                by maneatingmonkey
                I have a TCL 55P6US with sound and backlight but no picture. This model does not have a T-CON board, and the right (rear perspective) panel board is fed from the left panel board. I have not been able to induce any change by disconnecting the secondary panel board or the tape cut-off method on the primary board.
                There are a bunch of voltages missing on the panel boards. I can't find any shorted caps of the panel boards, and all of the missing voltage rails read in the kiloohms, which leads me to suspect the issue may lie on the circuit board, rather than a short in the panel.
                03-27-2024, 07:17 AM
              • howardc64
                Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                by howardc64
                • Prior owner tried a replacement main board. No difference.
                • Samsung 2x red blinking standby LED = panel fault
                • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                07-19-2025, 10:54 PM
