Hi guys i installed Xubuntu 18.04 and it boots and may run find but some times the display graffics go off wack and i have to reboot PC,i had to go back to Xubuntu 16.04 which runs find. e Machines ,amd Athlon IIx2 250U,video card integrated Nvidia card.
Xubuntu 18.04 display Glitch ?
--- begin sig file ---
--- end sig file --- -
Re: Xubuntu 18.04 display Glitch ?
mine works fine apart from its very slow accessing my phones data card files . it used to be quick . also it now uses all the power of the processor when accessing those files .Comment
Thanks guys; i did a fresh install and did all updates,about the Nvidea Card it doesn't offer any other graffics alternative driver on Xubuntu 18.04, rather on Xubuntu 16.04 it offers 2 drivers Nvidia legacy 304, and X.org X server Nouveau displayComment
Thanks guys driver installed in Xubuntu18.04
lshw -numeric -C display
WARNING: you should run this program as super-user.
*-display
description: VGA compatible controller
product: C61 [GeForce 6150SE nForce 430] [10DE:3D0]
vendor: NVIDIA Corporation [10DE]
physical id: d
bus info: pci@0000:00:0d.0
version: a2
width: 64 bits
clock: 66MHz
capabilities: vga_controller bus_master cap_list rom
configuration: driver=nouveau latency=0
resources: irq:22 memorye000000-deffffff memory:c000000
I think after i installed, sudo apt install build-essential libc6:i386
So far it has been with no issue,cross my fingersLast edited by ivtec; 08-24-2018, 11:03 AM.Comment
Call For Testing: Ubuntu with nVIDIA graphic cards
https://discourse.ubuntu.com/t/call-...hic-cards/7774
Do you have a nVIDIA graphics card? Do you want to help ensure users have a smooth experience if they choose to use the proprietary or open source drivers?
We are looking for committed volunteers to test nVIDIA with proprietary and open source
drivers. The goal of this testing is to catch regressions early in the cycle, and fix bugs before they reach a major audience. It is for Ubuntu 18.04 (Bionic) or Ubuntu 18.10 (Cosmic), in laptop or PC machines.
If you want to be part of the team you will need:
A computer with a nVIDIA graphics card
A spare partition on that system (Only If you wish to run the install test)
If you don't have a spare partition you can easily create one.
An Internet connection
The cycle starts at 08/29/2018 and finishes 2 weeks later at 09/12/2018
Later In this post you will find the setting up instructions. Additionally, for testing details instructions and how the QA tracker works, you can visit:
QA Tracker details46
and follow the detailed instructions.
Thanks for helping to make Ubuntu even better!
== Setting Up Instructions ==
If you wish to test the installation process, we suggest you to have a spare partition, because the program involves fresh installations of Ubuntu. If you don't have a spare partition, you can create one following this steps: Resize partition instructions7. If you don't want to test the installation process, you should run the test that involves booting a live session.
I know some of you have several systems, but our tracker has some limitations that prevent to provide two results for the same account. To avoid creating too much trouble, just select one of your systems and test ALWAYS with that system.
You have to have an account in Launchpad. We are going to use it to generate data (it will be publicly available). If you don't have a launchpad account, follow these steps:
Go to Launchpad14.
Click on “Log In/register”
Enter your email address and select “I do not have an Ubuntu One account”
Enter the data and verify your email.
With your launchpad credentials, you have to login into the tracker: http://xorg.qa.ubuntu.com20
Once you're done with the tracker, add yourself to the list of participants in this page.
You're all set!--- begin sig file ---
--- end sig file ---Comment
GeForce 6150/6200 onboard GPUs / IGPs are well-known for going bad, both in laptops and on mobos. Consider putting a small fan on the IGP/chipset heatsink.
And yes, I know you mentioned that an older version of the OS runs "fine". But that doesn't mean your nVidia IGP is necessarily okay.
Personally, I would just buy a better PCI-E card for that system. There's plenty of video cards on eBay for less than $10 (with shipping!) that will run circles around that GF6150 IGP and have better Linux support.Comment
run software updater . click settings . then click additional drivers .Comment
think drivers should just show in the box .. although i seem to remember downloading some but was long time ago .Comment
check here .. https://www.nvidia.com/drivers/beta
Thanks i tried that but for 32 bit it doesn't install ,also installed from the link below,well i'll see how it goes.
https://mintguide.org/system/856-ins...inux-mint.htmlComment
This specification for the Acer Nitro Nitro 5 AN515-45 - (AMD Ryzen 5 5600H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060 6G, 15.6" FHD IPS 144Hz Display, Windows 10, Black) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Nitro 5 AN515-45 - (AMD Ryzen 5 5600H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060 6G, 15.6" FHD IPS 144Hz Display, Windows 10, Black) boardview and Nitro 5 AN515-45 - (AMD Ryzen 5 5600H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060...09-06-2024, 10:20 PM
This specification for the Acer Nitro Nitro 5 AN515-45 - (AMD Ryzen 7 5800H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060 6G, 15.6" FHD IPS 144Hz Display, Windows 10, Black) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Nitro 5 AN515-45 - (AMD Ryzen 7 5800H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060 6G, 15.6" FHD IPS 144Hz Display, Windows 10, Black) boardview and Nitro 5 AN515-45 - (AMD Ryzen 7 5800H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060...09-06-2024, 10:20 PM
This specification for the Acer Swift Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Silver) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Silver) boardview and Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Silver) schematic. Our...09-06-2024, 09:30 PM
This specification for the Acer Swift Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) boardview and Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) schematic. Our users...09-06-2024, 09:30 PM
This specification for the Acer Chromebook Acer Chromebook 311 CB311-11H - (MediaTek MT8183, 4GB, 64GB eMMC, 11.6 inch HD Display, Google Chrome OS, Silver) Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Chromebook 311 CB311-11H - (MediaTek MT8183, 4GB, 64GB eMMC, 11.6 inch HD Display, Google Chrome OS, Silver) boardview and Acer Chromebook 311 CB311-11H - (MediaTek MT8183, 4GB, 64GB eMMC, 11.6 inch HD Display, Google Chrome OS, Silver) schematic. Our users have donated...09-07-2024, 01:00 AM
- Loading...
