Lga1366, Xeons and server RAM.
  • PopcornMobo
    • Dec 2017
    • 53
    • Lithuania
    I'm building a gaming PC but i'm super tight in terms of budget. I've found a pretty sweet xeon w3565 for 7€. It's a lga1366 socket but i've found some sellers who have Lga1366 mobos and because they're not popular (the mobos) i might get a deal.
    Since it's a xeon CPU i thought server RAM might be an option. I've found 8Gb sticks for 20€ each and by the looks of things they're 1600MHz, not bad imo.
    I won't be buying anything anytime soon since i'm pretty much broke right now so i have time to look for best deals.
    What i want to know is how to identify a server ram compatible mobo in case it's the route i choose to go. Afterall, 40€ for 16 gigs of ram is not too bad.
    And in case you're wondering why i'm broke, well, the R9 295X2 on my table might have something to do with that.
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16958
    Re: Lga1366, Xeons and server RAM.
    Depends on the chipset (Tylersburg is my favorite)....but most LGA1366 stuff can use PC3-10600R (reg/ecc), which is dirt cheap right now. I run a lot of them myself. The westmere platform (5600-series Xeons) is still bulletproof and fast!
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • PopcornMobo
      • Dec 2017
      • 53
      • Lithuania
      Good to know. The server 1600MHz ddr3 ram is 2x cheaper than the regular 1600MHz ddr3 ram around the used market here, which is why i want to go that route. I could very easily get 24 gigs of server ram for 60€, but i'll settle for 16 gigs i think.
      I guess it's decided, server ram it is then.
      • Snayperskaya
        • Nov 2015
        • 46
        • Brazil
        1366 is a great platform for tinkering with, even by today performance standards. Some tips:
        * LGA1366 RAM clock support for all chips tops at 1333MHz. Older 55xx series top at 800/1066MHz. You can check this at Intel Ark;
        * Check if the motherboard is compatible with the CPU. I've had problems with a 5520 chipset mobo not recognizing 56xx chips, even the lower wattage ones;
        * There are many types of "server memory" - Unregistered ECC (UDIMM), Registered ECC (RDIMM) are the most common. Check your motherboard support. Rule of thumb is: Buy all your modules from the same type. Server-grade motherboards recognize half of maximum RAM supported (or less) while using UDIMMs (compared to RDIMM). Also, RDIMMS are not compatible with desktop-grade chipsets;
        * Check the RAM's ranks. Most likely to have less trouble with them if you have all modules using the same config (may it be 1Rx8, 2Rx4, etc);
        * Don't update motherboard BIOS if you are unsure if it's compatible between PCB revisions. I've had a X8DTI-F non-bootable after a "successful" BIOS update since SuperMicro don't mention anything on their site.
        * Get a 60mm (or 50mm) fan into the PCH heatsink if you are going for a server-grade motherboard. They get real hot very quick.
        * Grab a cooler that is compatible with the Xeon 1366 backplate for direct assembly. Some motherboards have the area near the socket pretty cluttered with VRM components and don't fare well with cooler assemblies that use a front plate.
        There are plenty SuperMicro, Intel and Tyan options on eBay if you are going for a 2 CPU build.
        • PopcornMobo
          • Dec 2017
          • 53
          • Lithuania
          well we agreed with the seller that the cpu would be 9 euro shipped and i gave him my email for all the bank details and whatnot, but he never responded so i gave up on him.
          i did find a i7-3820 for 50 euro but 2011 mobos here are super expensive. I did find a few Chinese made 2011 miniATX mobos for 90 euro.
          I'm in no hurry so i can wait for better deals to come, it's not like i can up and pull money out my ass anyways.
          Also the PC is for games not server use but more power is always better.
          • Snayperskaya
            • Nov 2015
            • 46
            • Brazil
            AliExpress have some great deals on 1366 CPUs. I've snatched a pair of X5570 so I could use the best possible into a board that don't work with 56xx series. I paid US$16 for each. There's some good deals for the high-end (X56xx) chips, but I think they
            I don't trust chinese boards. I've heard that 1366 boards use modified H61 chipsets (but I didn't go after to check this).
            There are some implications on going for a server system (I've described most of them above), but they are very solid, performance and reliability-wise.
            • omega
              Troubleshooting of redundant F750E-S0 Dell PowerEdge Server
              by omega
              Hello all,
              as a beginner electronics hobbyist, after a few years I would like to place another post on this Forum section, given that I did not succeed in finding any useful advice among the other posts.
              Over the last years, I have been using a PowerEdge Dell Server with two redundant PSUs, namely the 750W F750E-S0 ones (aka 06W2PW). Unfortunately, last summer one of them failed (perhaps owing to an overheating), and the server had for working to take into account the other one only. Of course I opened and tried to troubleshoot the failed PSU, but each cap I tested seemed to...
              02-09-2024, 03:34 PM
              HP ZBook 15v G5 Mobile server 15v Specification for Upgrade or Repair
              This specification for the HP ZBook 15v G5 Mobile server can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15v G5 boardview and 15v G5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP ZBook 15v...
              09-06-2024, 11:39 AM
            • harp
              Comparing FreeNAS, FTP server, SMB server, multimedia server...
              by harp
              I thinking about some central LAN file server, on where I can put some files from other devices, or access to them, and maybe play some movie without download...
              I never study this, but when I see that freenas need few gigabyte of ram to recommended working, some wiered partition, I wonder if I miss somewhat in the midletime...
              Also exist "turnkey file server", and other turnkey products that I can not distinguished what is major difference and how it perform - no experiance at all.
              What is general difference between this products, and what be most useful...
              01-04-2024, 02:44 PM
            • Fireballcz
              Windows 2016 server L2TP/IPsec VPN - two subnets
              by Fireballcz
              Hello, please how to properly configure VPN in this environment?
              I have two subnets in two different (geographical) workplaces, connected via IPsec (thru gateway routers)
              Main subnet: 192.168.11.0/24, gateway (router IP) 192.168.11.1, Windows 2016 server (VPN, DHCP, DC etc.) 192.168.11.3
              2nd subnet : 192.168.22.0/24, gateway (router IP) 192.168.22.1 - just client computers.
              I need to allow external (home office) users connect via VPN server (192.168.11.3) to the 2nd subnet (192.168.22.0/24) to their computers (via RDP).
              I have no problems with VPN connection...
              07-29-2022, 03:20 AM
            • frans00000001
              Supermicro Server mainbaord x10dri-ln4+ schematic
              by frans00000001
              Good day
              I am looking for a mainboard schematic for a Supermicro Server mainbaord x10dri-ln4+ as the track broke off on the BIOS chip and I want to repair to use the server again. If possible can someone assist to get this schematic?
              08-06-2025, 05:36 AM
