Re: Windows 10 and magically hidden files.
Living is dangerous as hell and death is the final outcome. Sodium reactors will not have a melt down no matter what one does or our many error an operator does. Like with everything there are dangers if it is not built correctly. If one does not build a building correctly it falls down and kills most of the people in it. Sodium reactor need to be keep away from air and water. Those are the dangers. Air will cause a fire and water will cause an explosion. One can minimize these risk by only allow a small storage of sodium to heat the water in a pipe that turns the turbines. This would be away from the main reactor and the large pools of sodium. What that does is prevents an explosion in the main reactor and minimizes it to a small area where the water is heated for the turbines. This would be easier to control if that happen and it would not involve the reactor. Containment of radiated liquid sodium is 300 years as appose to 10,000 years for light water. Sodium reactors will burn 99% of the fuel as appose to 1% with Water cooled reactors. In fact the waste from Water cooled reactor can be burnt in sodium cooled. The only problem in the reactor would be exposing it to air. Were a fire could start. The Tera power design the fuel cell would not have to be taken out of the pool because the cell would be use for the 60 years that the power plant was in operation.
Originally posted by stj
View Post
