My server is driving me COMPLETELY NUTS!
  • pentium
    • Mar 2006
    • 2778
    Okay, ever since I made a dedicated server I have been driven nuts by accounts and passwords and software.
    I have a Proliant 1600 and with it was a burned copy of a utility cd that you installed and included drivers. I installed it and while it did install the drivers almost all the programs that came with it didn't work right and fifteen minuets after I had rebooted the server (following the install) my system logs ere packed with errors and corruption that in some cases didn't even exist.
    I then uninstalled the utilities but to my astonishment, some of the programs remained and continued to flood my logs. One of them being "NIC agent" and you couldn't remove them now because windows could not see it.
    The second problem is accounts.
    I have the one admin account, an account for my Hamachi connection and accounts for other systems (linux, unix etc.).
    The problems there can range from the systems refusing to retain connection passwords (you check "remember password" and an hour later you have to login again), to security settings not working (You prevent an account from writing to a drive but it will let you do it anyways) to mystery accounts (my laptop wants me to login to an account called "IPC$" and it has a mystery password) and systems which refuse to login to accounts stating that either the account selected does not have specific rights or the account does not exist.
    It's driving me and my friends nuts and I can't seem to figure out what's doing all this.
    What should I do? Please, I'm desperate.
    Find Nedry!
    Check the Vending machines!!
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16956
    Re: My server is driving me COMPLETELY NUTS!
    What os is on it?
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • pentium
      • Mar 2006
      • 2778
      Windows 2000 Server. It's fully updated and was freshly installed this morning.
      My error log started to flood and the system became slower as soon as I installed the utilities from the Compaq cd. I have always had the account problems.
      In one case my mac can use the guest account to browse the entire server and I disabled the guest account.
      Find Nedry!
      • Topcat
        The Boss Stooge
        • Oct 2003
        • 16956
        Remove the compaq utilities. They're OLD if they came with the server anyway. Install nothing but the essential drivers for any hardware. As old as that system is, Win2k should have embedded drivers for the criticals anyway. What's the role of this server?
        Team : 49813
        Join in!!
        Team Stats
        • pentium
          • Mar 2006
          • 2778
          I did uninstall the utilities but some crap remained behind and according to the system it's not installed and does not exist (but still belches out errors).
          The system is a central file server that connects together Linux, Unix, Windows and Mac system with a wide range of versions. It also has a camera server and is a print server and eventually it will be an FTP and mail server. It also manages all the X10 modules in the house.
          Find Nedry!
          • Topcat
            The Boss Stooge
            • Oct 2003
            • 16956
            I'd say its time for a clean install then, or a detailed cleaning of the registry....... Uninstalling all their crap probably left tons of startup commands in the registry for files/services that no longer exist. Windows 2000 is a very streamline OS if you keep on top of it. Using it as a lab rat for different utilities will slow it to a crawl come uninstall time. Of course, experimenting is good, once you find the sweet spot of programs and utils you'll actually use, then do a clean install with those programs and utils only. After that, just keep the OS updated, and as a win server, it'll run stable forever!
            That system will have its hands full with duties... That's the dual P-Pro 200?? I hope it has a big enough pair of kahonas!
            Team : 49813
            Join in!!
            Team Stats
            • pentium
              • Mar 2006
              • 2778
              No, it's a dual PIII system.
              *sigh*
              Okay, well it looks I will have to reload the server next weekend.
              Find Nedry!
              • mitsu2k
                Power-One solar Inverter driving me NUTS!!!
                by mitsu2k
                Hello folks, this is a last ditch effort. I thought I would seek your expertise before giving up.. I have been working on this thing for over 2 months and have gotten nowhere. Here is the issue:
                Inverter powers on and immediately red GFI light comes on and inverter will not complete the initialization process.
                There is no error code on the screen. I have removed most of the Y capacitors and tested to no avail.
                All relays are good.
                I replaced the current transducer- same problem. Checked most of the transistors and diodes and all appear good. I wish I could get my hands...
                11-13-2023, 07:19 PM
                HP ZBook 15v G5 Mobile server 15v Specification for Upgrade or Repair
                This specification for the HP ZBook 15v G5 Mobile server can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15v G5 boardview and 15v G5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP ZBook 15v...
                09-06-2024, 11:39 AM
              • harp
                Comparing FreeNAS, FTP server, SMB server, multimedia server...
                by harp
                I thinking about some central LAN file server, on where I can put some files from other devices, or access to them, and maybe play some movie without download...
                I never study this, but when I see that freenas need few gigabyte of ram to recommended working, some wiered partition, I wonder if I miss somewhat in the midletime...
                Also exist "turnkey file server", and other turnkey products that I can not distinguished what is major difference and how it perform - no experiance at all.
                What is general difference between this products, and what be most useful...
                01-04-2024, 02:44 PM
              • Fireballcz
                Windows 2016 server L2TP/IPsec VPN - two subnets
                by Fireballcz
                Hello, please how to properly configure VPN in this environment?
                I have two subnets in two different (geographical) workplaces, connected via IPsec (thru gateway routers)
                Main subnet: 192.168.11.0/24, gateway (router IP) 192.168.11.1, Windows 2016 server (VPN, DHCP, DC etc.) 192.168.11.3
                2nd subnet : 192.168.22.0/24, gateway (router IP) 192.168.22.1 - just client computers.
                I need to allow external (home office) users connect via VPN server (192.168.11.3) to the 2nd subnet (192.168.22.0/24) to their computers (via RDP).
                I have no problems with VPN connection...
                07-29-2022, 03:20 AM
              • tobeend
                Bypass mdm macbook m2 ventura
                by tobeend
                1. RESET MACOS WITH IPSW
                a. Power off MacBook, press and hold the power button to enter Recovery
                b. Open Disk Utility, remove Macintosh HD
                c. Reboot, connect to the network to Activate Mac.
                d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
                d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
                e. Release the other keys, but keep holding the Power key for another 10 seconds
                f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click...
                05-26-2023, 07:18 AM
