Reball advice needed
  • reaper57
    • Sep 2014
    • 216
    • Norway
    Ok, so I have this xbox 360 that failed and I want to swap the gpu. I have already done two reflows, and it looked like someone might have repaired it before me.
    I decided to just swap the whole chip instead of reballing, but the thing is that if this works, it's going to be my first successful reball/chip replacement. Every time I tried it before I usually popcorned the gpu while soldering the new balls to it and/or lifted pads on the motherboard and gpu, while cleaning it.
    My questions are:
    What preheat temprature should I use and how long should I leave the board only on bottom heating?
    What temperature should I heat the chip itself to and how long would I need to keep it there?
    One of the most important questions are should I start cleaning the motherboard from the old solder right after I lift the chip or should I let it cool down first?
    Another important question is what temperature should I set my soldering iron station to and how much time and heat does it normally take to lift a pad on the motherboard?
    Thank you to everyone who tries to help me! Any advice is appreciated!
    Keyboard not detected, press F1 to continue...
    • 31316
    Re: Reball advice needed
    before you do any of that, know this.
    there are a lot of gpu's you need to make sure the new one is the same as the old one.
    they kept changing the core voltage among other things - put the wrong part in and either it wont run, or it will burn up.
    • reaper57
      • Sep 2014
      • 216
      • Norway
      Thanks for the heads up, but I already got the correct one.
      • Agent24
        I see dead caps
        • Oct 2007
        • 5111
        • New Zealand
        For lead free solder, maximum is about 245C - 260C
        For leaded solder, 200C to 235C.
        Search google for "BGA Reflow profiles" to get some idea, then just practice and practice until you get it right.
        Popcorning is not just caused by too much heat, it can be that you are ramping the heat up too fast, or the chip has absorbed moisture and this trapped moisture expands rapidly during reflow causing the popcorning.
        If the chip has been in the normal atmosphere for some time, you may need to heat it for a while at a low temperature to make sure it is dry first before you reflow. Look up MSL http://en.wikipedia.org/wiki/Moisture_sensitivity_level
        -David VanHorn
        • reaper57
          • Sep 2014
          • 216
          • Norway
          Thanks for the advice. So, should I let the mb cool down before I start cleaning the old solder and what temperature should I set my soldering iron to?
          • Agent24
            I see dead caps
            • Oct 2007
            • 5111
            • New Zealand
            I'm not sure, but it may not matter either way, the main thing is to do the cleanup carefully.
            A lot of videos show people 'scrubbing' the pads with solder wick. This is a BAD idea.
            This is how you should do it: https://www.youtube.com/watch?v=l9eZFo7hQco
            When you are skilled and can apply very little pressure to let the wick glide over the pads you may be able to get away with it, but it still carries more risk of lifting pads so it's not a good idea.
            This is because when boards are heated, the glue holding the copper to the substrate actually loses about 80% of its strength. Because of this, any physical pressure on the copper can easily break the bond between it and the board substrate. Especially when you are talking about tiny little BGA pads!
            -David VanHorn
            • reaper57
              • Sep 2014
              • 216
              • Norway
              Thanks for the advice. I usually mess the pads up while cleaning them with the solder wick. This time I'm planning on setting my iron to 350C or maybe even 400C, and going over the pads carefully, like in the video you sent me.
              • xboxhaxorz
                • Jan 2011
                • 196
                This goes into a bit more detail https://www.youtube.com/watch?v=s38vQxXv0GE
                If you are using a new chip, simply bake it for say 48 hrs and if you still get popcorn than your profile is the issue
                • Hondaman
                  Windows 11 buying advice needed
                  by Hondaman
                  My mother may soon need to upgrade from Win7 (to continue safe browsing, e-mail, and office tasks, without a printer). Right now, she uses an Intel Core2Quad 9550 CPU (not sure of motherboard). Video is either the Radeon 6670 or 6770, completely air-cooled, with fins like a motorcycle engine (I think I pointed a 120mm fan at it). PSU is probably Seasonic, still running after 14 years (I choose quality). I am not sure of the RAM, or the PCI-e wifi chip. Probably 8 GB or 16 GB. Perfect for WIndows 7.
                  She does not want to switch to Linux. And she does not want to use a laptop because...
                  04-14-2025, 11:35 PM
                • Robby-Gr
                  TV Samsung UE55HU8500L (2014) – service menu + firmware reflashing advice needed
                  by Robby-Gr
                  I’m trying to recover a Samsung UE55HU8500L (curved UHD, 4K model from 2014) after replacing the panel. The new panel is a 55A1UU8EH, which produces excellent image quality — very close to the original.
                  However, since the swap, the TV enters a boot loop (Samsung logo → restart) unless I enter the service menu and perform a reset.
                  The service mode had been previously modified — possibly by a technician or during the panel swap — and I suspect some key settings are mismatched for the European (Greece) market.
                  Additional issues:...
                  09-27-2025, 12:02 AM
                • mariukonie
                  SONY VAIO PCG-711911M VPCEH2H1E advice about updating BIOS to UEFI needed please!
                  by mariukonie
                  Hi. I can't upgrade to win11 I think it's because my BIOS is without Secure Boot function. The BIOS version is R0180Z9. Can you please advise if it is possible to upgrade BIOS to UEFI for this laptop. Many thanks....
                  05-04-2025, 03:18 PM
                • rustinjust
                  Advice needed-Technika 32-207 works but sticks on channel,won’t change channels ok
                  by rustinjust
                  My tv will work for a while and change channels with the remote as it should but then it will stick on one channel only and work ok but it won't change channels. I have tried unplugging it for hours and whilst unplugged pressing the power button on the tv to reset it.
                  The volume button on the remote still works but it just won't change channels once it decides to stick on one channel
                  It has built in basic freeview tv here in the uk, I've tried doing an automatic search to reset the tv but nothing works.
                  I have to turn the tv off and then on again with...
                  09-28-2023, 12:23 PM
                • Lobell
                  A1466 i7 2.2 Ghz Upgrade Advice needed
                  by Lobell
                  Dear All,
                  I am trying to breathe new life into my wife's 2015 Macbook Air (1.6 Ghz / 4 GB RAM) by upgrading the logic board to an i7 2.2 Ghz with more RAM.
                  That's when the advert below caught my eye: 16GB on the i7 A1466 - that's double what Apple originally put on.
                  I know that this is technically feasible, but has anyone made experiences with it?
                  Do you know and rate the vendor, Yopolean? I am ignorant and don't know them.
                  How did the performance turn out?
                  I hope this is an appropriate question for this forum.
                  09-14-2024, 05:07 AM
