Transistor Replacement Help
  • stk_1994
    • Jul 2014
    Hey guys. Long story short, I need some help finding a suitable replacement for a BC200Y Transistor for a circuit board I'm working on. I'm not familiar enough with Transistors to choose a replacement on my own quite yet. If someone knows a thread that can help me or if they can just tell me a good alternative, that'd be great. Thanks in advance!
    P.S. I also need to replace a LM431BCZ, but I already found a TL431CLP Transistor which has a lot of the same values. Just wanted to run it by you guys before placing the order.
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Transistor Replacement Help
    BC200Y is NTE 159 which is a PNP Silicon, Lo-Noise Audio Amp, Switch. It comes in a
    TO-92 Case, Max Collector Current (Amps):1, Collector to Base (Volts):80, Collector to Emitter (Volts):80, Emitter to Base (Volts):5, Forward Current Gain:180, Max Collector Power Dissipation (Watts):0.625, Typical Freq (MHz):200.
    With the flat side down and pins at the bottom, the pins are Emitter Base Collector.
    Yes the LM431BCZ can replace TL431CLP as they both are NTE 999 which is an Adjustable Precision Shunt Regulator and not a Transistor. With the flat side down and pins at the bottom, the pins are Cathode Anode Reference.
    Hope this helps.
    • vikivng
      guys..i need help with this lcd display used on ebikes pls.
      by vikivng
      This is an lcd display used on ebikes.
      long story short, there was condensation inside the unit.
      I opened it and thoroughly cleaned the pcb with isopryl.
      The board had no visible corosion.
      It powered on fine and was tested for an hour or so.
      However when connected to the bike,,it did not power on at all.
      I took it home and reopened it to take a look. There are no shorts based on MY testing.
      However,,when I probe the transistor and the mosfet gate in diode mode or contuinity mode, (one probe on transistor collector and one probe on mosfet gate}the unit...
      09-16-2025, 12:56 PM
    • SuperAman
      PNP transistor symbol?
      by SuperAman
      I have a question about PNP transistor symbol. Usually the emitter arrow pointing in the direction of the base is at top where the collector would be. I got asked on a test where the arrow is pointing toward the base but was in the spot of the collector. The answer choices was PNP or NPN and forward biased or reverse biased. So is it a PNP that is forward biased or reverse biased? Usually on the schematics for PNP the Emitter is on the top and collector is on the bottom....
      04-14-2025, 06:11 PM
    • Haaheim
      Bias matching replacement transistor - Parasound 2250
      by Haaheim
      Hi guys!
      I am currently working on a Parasound 2250 (class AB), which had one defective channel. Components in the signal paths have been replaced, including an output transistor (2SC3519).
      According to the manufacturer, bias is adjusted by measuring 1-3mV across the output resistors. The original ones are completely fine around 1.5mV, but the replacement is not. Initially, I got a couple from eBay, assumed they were fake (they were) and was able to source a replacement locally. This exhibits similar behaviour, being around 0.6-0.8mV on its emitter resistor....
      05-13-2022, 12:45 PM
    • esinior
      Smd code to part number
      by esinior
      Hi i have a smd part with probably mark "QO 11" or "Q0(zero) 11" on it, and its package is SOT89, i doubt its KTB1260 PNP transistor, but in measuring with diode mode of multimeter it shows number 1.4 between emitter and collector pins and its not open circuit, and .59 from collector to base and .8 from emitter to base , and these numbers doesn't match a pnp transistor, i couldn't find any part number and datasheet for it, does anybody have information for that part number?
      I've attached pics of this part
      Thanks...
      08-20-2024, 02:50 AM
    • reformatt
      by reformatt
      07-31-2025, 08:37 PM
