ROG Strix GA15DH Gaming Desktop PC GA15DH-EH562
  • Cipherx
    • Apr 2025
    • 10
    I truly appreciate your help!
    I have an ROG Strix GA15DH Gaming Desktop PC, which I primarily use for photo and video editing with the Adobe suite. Yesterday, I decided to reapply thermal paste to the CPU.
    After doing so, I used compressed air to clean out some dust.
    However, when I powered the system back on, everything seemed to work fine, except there was no video output, and there was no BIOS beep.
    After hours of troubleshooting, here are my findings:
    What works:
    1. All fans, including the CPU fan, are operational.
    2. RGB lighting is functioning.
    What doesn't work:
    1. No video output (neither from the dedicated GPU nor the GTX card).
    2. None of the USB ports are working.
    3. No motherboard error beep sound.
    Troubleshooting steps: I tested the components in another working PC and the results were:
    1. 32GB DDR4 RAM - Passed.
    2. NVMe M.2 drive - Passed.
    3. GTX Graphics card - Passed.
    4. PSU - Passed (I've attached the results photo).
    Additionally, I tried resetting the CMOS by removing the battery and also using the motherboard jumper that didn't help.
    Processor ‎4.4 GHz ryzen_5_3600x
    RAM ‎32 GB DDR4
    Memory Speed ‎3200 MHz
    Hard Drive ‎1TB SSD
    Graphics Coprocessor ‎NVIDIA GeForce GTX 1650
    Chipset Brand ‎AMD
    Card Description ‎Dedicated
    Graphics Card Ram Size ‎4 GB
    Wireless Type ‎802.11ac
    Number of USB 3.0 Ports ‎8
    Brand ‎ASUS
    Series ‎ROG Strix GA15DH
    Item model number ‎GA15DH-EH562
  • DeXXter
    • Aug 2023
    • 92
    • Chile
    It looks like a bios issue, have you tried to reprogram or read your bios ic?
    • Cipherx
      • Apr 2025
      • 10
      Thank you for the replay,
      Unfortunately I have no way to read or reprogram the bios. Also to be honest Ive never done it before. not sure if there is another way to do that.
      • DeXXter
        • Aug 2023
        • 92
        • Chile
        I see, well the only thing you have left to do is to check around where you took a screw or disconnected something and try to check if there's a smd component missing, also you could try to turn your computer on while disconnecting fans for example, sometimes we bend stuff while plugging connectors... and try only one ram slot (this is not very likely but still).
        • Cipherx
          • Apr 2025
          • 10
          I have checked for missing components. Everything looks good. I did try the one ram slot but that didn't help either.
          I did order a bios ic programmer. hopefully I can manage to program the bios chip again. Its a Winbond 25Q128FWSQ.
          Will report back. Thank you
          • DeXXter
            • Aug 2023
            • 92
            • Chile
            Alright, try to check a video about programming one of those bios, the few times I've done that on asus desktop motherboard I had to use uefitool to extract the bios body (something like that) before flashing the ic.
              • 31084
              if it's a ryzen board, does it have diagnostic leds?
              • Cipherx
                • Apr 2025
                • 10
                Thank you much appreciated, also I searched everywhere but cannot find the bios firmware to download. The chip is winbond 25Q128FWSQ.
                • Cipherx
                  • Apr 2025
                  • 10
                  Hi there, Its Asus GA15DH board m.2 SOCKET3 REV2.0. No sure if it does. but if it does there are no led lights on. Thank you
                  • dmill89
                    • Dec 2011
                    • 2534
                    Just because I haven't seen it mentioned yet. Have you tried re-seating (removing and reinstalling) the CPU? Pinned CPUs like AM4 can often be pulled loose from the socket when the CPU cooler is removed due the cooler being "stuck" to the CPU by the thermal paste (especially if the paste is old and dry) since there isn't much holding them into the socket (just the tension of the pins in the socket vs. LGA CPUs like intel from socket 775 on or AM5 which are held down by a clamp over the CPU). You may also want to verify none of the pins are bent, since if the CPU does get pulled loose and you don't notice it and then screw the cooler back down that can potentially bend the pins of the now misaligned CPU.
                    • DeXXter
                      • Aug 2023
                      • 92
                      • Chile
                      I guess from asus site https://rog.asus.com/desktops/mid-to...helpdesk_bios/
                      Btw that uefitool thing that I said is for intel motherboards, I didn't see that yours is an amd, so my bad, I haven't programmed one of these, but I guess you can just download it and program it, in any case save a backup from the original, and do it twice, with different softwares, asprogrammer and neoprogrammer for example (I use these with the ch341).
                        • 31084
                        thats a 1.8v chip,
                        DO NOT try to use a ch341 on it
                        https://www.winbond.com/hq/product/c...rtNo=W25Q128FW
                        contact asus for a motherboard manual,
                        it may have a flash-recovery feature that will flash the bios from the usb port - a lot of ryzen stuff does.
                          master hoarder
                          • May 2008
                          • 12175
                          If the PC worked fine before cleaning and not afterwards, then it is almost definitely NOT going to be a BIOS issue.
                          I suggest to O/P to double-check what he/she did.
                          As Dmill89 suggested, check if the CPU was possibly pulled out or partially puled out when changing the thermal compound. Better yet, re-seat it as suggested.
                          Also, what was the new thermal compound that was used? Anything conductive, like Arctic Silver 5 or anything from the category "liquid metal"?
                          On that note, even if non-conductive thermal compound was used, check to see if any of the old or new thermal paste got spilled/smudged anywhere else on the board, particularly on small SMD components (like resistors or caps) or under a BGA chip.
                          If all of the above checks out, see if there was some other "user error" made when re-assembling the system - i.e. did you remember to plug back in the 4-pin 12V CPU power connector?
                          Lastly, was the board even taken out of the case for the cleanup, or did you do it all while in the PC. If it's the former, how did you handle the board? It's generally not that easy to kill modern hardware with ESD as we were told back in the days... but still, some precaution should still be taken in regards about what surface the board is placed on and how it's handled. On that note, if you used compressed air to clean the fans, did you make sure to block the fans from spinning while cleaning them. I've seen a lot of people make this mistake and not block/stop the fans. In addition to possibly causing over-stress on the fan bearings (from the very high speed), the fan(s) can also genera back-EMF (potential/voltage) and send it back to whatever other components are connected to the fan connector. Thus, it's not impossible to kill fan controllers and monitoring ICs when doing this.
                          And one more thing...
                          Both the stock Intel push-pin cooler design and AMD's clamp design are quite terrible when it comes to preventing PCB stress/warping. If anything, these are notorious for doing exactly the opposite - depending on manufacturing tolerances, some of these will warp the motherboard like a nutshell right under the CPU socket. I've seen quite a few boards going bad as a result of this. And sometimes, the worst part is that the damage doesn't really show up until the CPU cooler is removed/refitted... eventually causing any cracked solder joints under the CPU socket to become trouble.
                          Now obviously this would be the worst case scenario for your board. But before assuming this is what happened here, do as stj suggested - check if the board has any diagnostic LEDs and see what they report if you try to power on the board with and without RAM... or see if the PC speaker (if the board has one connected) sounds off any alarms without RAM (it should). If you don't have diag. LEDs on your board, then you may have to resort to a POST card... and that's provided the board has a PCI slot for it. (On that note, are there any POST cards made for "modern" PCs that don't have a PCI bus?)
                          I think the above covers about everything.
                          Don't waste time trying to read/re-program the BIOS (not yet anyways), as that might introduce new problems on top of whatever issue you likely caused by cleaning/working on the computer already.
                          • Cipherx
                            • Apr 2025
                            • 10
                            stj
                            I checked the CPU and attached some pictures. All the CPU pins look fine.
                            As momaka mentioned, I also removed the RAM and powered the PC on — but the situation is still the same, with no BIOS error beeps. To make sure the CPU isn't dead, I removed the CPU fan and powered the system on. The CPU does heat up, so it seems to be functioning.
                            I'd also like to add that during the dust cleaning and CPU re-pasting, I didn't remove any other components from the PC. That said, I went back and rechecked all the connections, and everything appears to be properly in place.
                            I applied the correct amount of thermal paste to the CPU. There are no diagnostic LEDs lit that I can see. There is an orange light on the edges of the motherboard—after researching into it, I found out it's just the RGB lighting.
                            Thanks for the heads-up about the BIOS chip—it's 1.8V. I haven't used the programmer yet.
                            Honestly, I'm out of ideas at this point. It's driving me crazy, and I'm not sure what to try next.
                            I really appreciate your help.
                            • adamski1952
                              • Oct 2021
                              • 93
                              • england
                              Have you tried resetting the cmos? Sorry .I missed that one.It seems you have.
                              • Cipherx
                                • Apr 2025
                                • 10
                                Yes, that was the first thing I did—removing the battery and/or using the CMOS jumpers.
                                • adamski1952
                                  • Oct 2021
                                  • 93
                                  • england
                                  Only other thing I can think of is to try a different power supply.The tester you used only shows voltage without load.There may still be a problem there.
                                    • 21133
                                    Did you replace the thermal paste while the graphics card was in or out.
                                    • Cipherx
                                      • Apr 2025
                                      • 10
                                      It was in. I turned the power off completely (I completely turned off the power by unplugging the power cord and holding down the power button to discharge any remaining electricity.).
                                      It was the AMD CPU that I applied the thermal paste to. I did not touch the graphic card.
                                      • Cipherx
                                        • Apr 2025
                                        • 10
                                        Just a quick follow-up—
                                        I wanted to thank everyone for their help.
                                        After a lot of troubleshooting, I ended up replacing the motherboard. Once I did, everything went back to normal.
                                        Out of curiosity, I took the old motherboard to a PC repair shop to see what had gone wrong. After a quick test, the technician told me that two electrolytic capacitors were bad—though he wasn't sure why. The repair would've been a bit costly, so I decided to just start fresh with a new board.
                                        Either way, I'm back up and running now.
                                        Thanks again, everyone—much appreciated!
                                          ASUS ROG G531GT-BQ091T-GAMING Notebook Strix Specification for Upgrade or Repair
                                          This specification for the ASUS ROG G531GT-BQ091T-GAMING Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the G531GT-BQ091T-GAMING boardview and G531GT-BQ091T-GAMING schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 03:21 PM
                                          ASUS ROG Scar II GL504GV-ES020-GAMING Notebook Strix Specification for Upgrade or Repair
                                          This specification for the ASUS ROG Scar II GL504GV-ES020-GAMING Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Scar II GL504GV-ES020-GAMING boardview and Scar II GL504GV-ES020-GAMING schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                          09-06-2024, 07:50 AM
                                          ASUS ROG Scar II GL704GV-EV024-GAMING Notebook Strix Specification for Upgrade or Repair
                                          This specification for the ASUS ROG Scar II GL704GV-EV024-GAMING Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Scar II GL704GV-EV024-GAMING boardview and Scar II GL704GV-EV024-GAMING schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                          ASUS ROG GL703GM-71250-GAMING Notebook Strix Specification for Upgrade or Repair
                                          This specification for the ASUS ROG GL703GM-71250-GAMING Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GL703GM-71250-GAMING boardview and GL703GM-71250-GAMING schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 07:02 AM
                                          ASUS ROG GL703GS-71250-GAMING Notebook Strix Specification for Upgrade or Repair
                                          This specification for the ASUS ROG GL703GS-71250-GAMING Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GL703GS-71250-GAMING boardview and GL703GS-71250-GAMING schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
