RS232 different pin outs.
  • Mad_Professor
    A Mech Warrior
    • Feb 2011
    • 1587
    SO I'm messing around with LIRC, and managed to get two lirc instances to work on an old machine running ubuntu. So I tried to set it up on my fileserver, it has one onboard serial and one header.
    I dug around and found a serial header cable, plugged it in and got everything setup and emitter on com1 or /dev/ttyS0 worked fine, but com2 or known as /dev/ttyS1 didn't work. I played with it, bios, drivers, lirc, nothing worked, even though it should!
    So I pulled out the meter and measured the pins and the ones I need is DTR pin 4 and ground pin 5. I get 10 volts on pin 4 but get -10 on pin 5 going from ground to ground? Then I checked the working com 1 and get 10 volts on pin 4 and 0 on pin 5, I measured again to be sure and it occurred to me that the old header cable I had dug around for, was wired incorrectly. Verifying this with the supermicro x9scm manual, it doesn't say but I assume it's in order of 12345/6789NC, because my header cable does 13579/2468NC.
    I don't mess around with serial much,
    So what gives? Why did it change? and whats the new straight thru wiring called? and where can I buy one?
  • brethin
    • Dec 2008
    • 1907
    Re: RS232 different pin outs.
    RS232 header cables are not all the same and motherboard makers used various pinout configurations which required their header cable from a standard cable. It can be a pain in the ass but most provided a pin for pin layout of the port in the motherboard documentation and a simple rewire of a header cable will make it work.
    • Mad_Professor
      A Mech Warrior
      • Feb 2011
      • 1587
      God damn it, why can't they stick to the standard.
      I dug around for more serial port cables, found a handful, all odd/even pin out, so I took one apart and desolder all the wires but pin 1 from the port then used my DMM and probe each wire and solder it to it's respective pin.
      It works now, and works well.
      • stefanpng
        HP EliteDesk 800 G1 SFF solder an extra fan header?
        by stefanpng
        So the HP EliteDesk 800 G1 SFF has only one fan header on the whole motherboard, a 4 pin cpu. There is a second chassis fan header, but it is not installed, there are just 4 bare through holes and some silkscreen.
        Other models like the tower version of this computer have the chassis fan header installed, so I was wondering if it was possible to solder in a new 4 pin header.
        There is some surrounding circuitry, and I think it is identical to this schematic. The CPU fan header circuitry matches exactly except for one filter(?) cap, and the chassis...
        07-13-2022, 05:54 PM
      • FuzzyOwl
        Denon AVR-X3600H No sound even to pre outs in direct analog mode. Help please!
        by FuzzyOwl
        Hi, I have a Denon AVR-X3600H I'm trying to repair. I have no electronics repair experience but I have a multimeter, service manual and a will to fix it (https://device.report/m/d5de8c00e617...f63147aba9.pdf)
        Everything seems to work except for no sound even through the pre outs. However I will get sound using Zone 2 pre outs.
        Only digital symptom I can tell is it will soft lock when in the Speakers/Test Tone menu and be unable to adjust +/- db during the test tone.
        I've followed the trouble shooting guide, audio check...
        12-05-2024, 11:54 AM
      • tintin_sn2
        RTX 2070 Fan not operating - 12v present at header but drops to 2V when fan connected
        by tintin_sn2
        I recently purchased a second hand RTX 2070 - an OEM Acer Predator manufactured by Sapphire - not a very common model.
        Upon connecting it up I noticed the fan wasn't operating resulting in the card overheating and shutting down. I checked the fan operation independently by connecting it directly to a power supply and function generator - it was working correctly with variable speed according to the square wave frequency.
        I then checked the output with a multimeter/DSO and verified that the GPU was putting out both 12V at pin 2 and PWM at pin 4. However, when the fan is...
        03-29-2024, 08:09 PM
      • Topcat
        Need to find a 34-Pin Motherboard Floppy Header
        by Topcat
        Looking for some floppy headers.....searching the usual sources (digikey/mouser/etc) until my eyes bled, I couldn't seem to find such a beast. Yes, the silly 34 pin floppy header for a PC motherboard....
        Why? Well, I was given a bunch of Optiplex 330's, which are useless systems these days....and despite what some have said, they do not respond well to the E5450 c0 stepping LGA771 Xeon mod, tried several, it never worked. They're in a standard BTX case, so I tossed some $5 Optiplex 380 boards in them I picked up on ebay, which will run ANY 5400-series Xeon with hard mods + firmware........
        06-25-2020, 10:50 AM
      • paparazzo79
        short over argb header from a fan?
        by paparazzo79
        Hi guys.
        I purchased Cooler Master Sickleflow 120 ARB Reverse edition in uknown condition since I purchased them from a guy, not store.
        I want to try them on my motherboard over argb header.
        In case the argb lightning on fans for some reason does not work, can it shorten out "something" on my motherboard (it was 500 $ paid)?
        03-18-2023, 01:53 AM
