Hitachi Deskstar 1TB won't even spin
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Awhile back in a freebie box I was given an untested 1TB Hitachi desktar from a 2007 Mac (apple firmware).
    I went to test it... and the drive wasn't showing up at all... in fact, It sounded TOO quiet... not even spinning!
    Normally I'd chuck a drive if it failed... but since it's a 1TB and the not spinning up part is kinda odd, I figured I'd ask.
    Perhaps something with the apple firmware locking it out of a non-Mac system? (and if so, would a gen 1 imac G5 work as a tester?)
    sigpic
    (Insert witty quote here)
  • seanc
    • Nov 2008
    • 1319
    Re: Hitachi Deskstar 1TB won't even spin
    I don't think the firmware will be the reason for the drive not spinning up, something else. Given it a sharp tap? It's worked for me on Western Digital blue drives as of late.
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      Nope, the tap trick didn't work.
      Looks like a paperweight then?
      sigpic
      • rhomanski
        nowhere man
        • 5157
        • U S of A
        They don't call them Hitachi Deathstars for nothing. I've had several do that to me so far.
        sigpicThe Sky Is Falling
        • nitelite
          • Apr 2013
          • 11
          Before chucking it, I would try putting it in a sealed plastic bag (or two) and leaving it in the freezer overnight.
          This is a technique I heard sometimes works but haven't tried myself so YMMV...
          • retiredcaps
            • Apr 2010
            • 9271
            Check the DC voltages on the hard disk pcb board to make sure you are least getting the normal voltages.
            --- begin sig file ---
            --- end sig file ---
            • brethin
              • Dec 2008
              • 1907
              It could be set to pwr-on with no spin up (sleep mode) like many DVR drives do. I wouldn't trash it. If you can't figure it out sell it for parts not working and explain it doesn't spin up on pwr-on. You might get something for it.
              • theOracle
                • Nov 2012
                • 163
                ^ This ^
                FYI - back in the day, they were called IBM Deathstars, before IBM sold this problem-child to Hitachi
                other than this afterbirth of a drive, Hitachi's are very reliable drives, as are pretty much all Hitachi products
                __________________
                the BIG 4
                ~~~ the top tier of low-ESR electrolytic capacitors ~~~
                • ratdude747
                  Black Sheep
                  • Nov 2008
                  • 17136
                  IIRC the deathstar was only a specific bad model back when IBM made them... however, most consumers don't know HDD models and as a result assumed they all were bad, and quit buying IBM drives. IBM then sold it to hitachi, and like the other IBM drives, there were no issues.
                  I may see if it is indeed a sleep mode thing. edit- No, that's probably not it, mac drives uses virtually the same FW from what I'm seeing.
                  Not too keen on selling it as it was a freebie from a buddy and I don't want to look like loser by backstabbing a friend.
                  sigpic
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    Got it to spin finally... made a horrible racket (fast clunk, not quite like a head crash) and a chip got hot, fast. You guys reckon it's just the controller board? Or is the entire drive a waste?
                    edit- never mind, the noise changes when I change the physical orientation of the drive. some postions I hear a scraping noise... drive is indeed 100% toast.
                    (I had plans for it too... for now it's being subbed by a PATA 80gb, the next best drive I have not in use)
                    sigpic
                    • shovenose
                      Send Doge Memes
                      • Aug 2010
                      • 6575
                      It came out of an Apple Time Capsule not a Mac :P
                      I've used drives with Apple firmware on them in PCs and never had an issue. So that is a non-issue.
                      • Elysarian
                        • Mar 2013
                        • 200
                        Knackered spindle bearing is an issue though... *points to Ratdude's last post*
                        • rhomanski
                          nowhere man
                          • 5157
                          • U S of A
                          I bought 6 Hitachi Deskstars, after one year, 1 was totally dead and 4 were losing files left and right. I have one left I use for backups and gets turned on about once a week.
                            Acer Spin Spin 511 R753TN Chromebook Specification for Upgrade or Repair
                            This specification for the Acer Spin Spin 511 R753TN Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Spin 511 R753TN boardview and Spin 511 R753TN schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                            09-07-2024, 02:20 AM
                            Acer Spin Spin 3 SP313-51N-58JR Hybrid (2-in-1) 3 Specification for Upgrade or Repair
                            This specification for the Acer Spin Spin 3 SP313-51N-58JR Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Spin 3 SP313-51N-58JR boardview and Spin 3 SP313-51N-58JR schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                            09-06-2024, 09:30 PM
                            Acer Spin Spin 3 SP313-51N-58LR Hybrid (2-in-1) 3 Specification for Upgrade or Repair
                            This specification for the Acer Spin Spin 3 SP313-51N-58LR Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Spin 3 SP313-51N-58LR boardview and Spin 3 SP313-51N-58LR schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                            Acer Spin Spin 3 SP314-54N Hybrid (2-in-1) 3 Specification for Upgrade or Repair
                            This specification for the Acer Spin Spin 3 SP314-54N Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Spin 3 SP314-54N boardview and Spin 3 SP314-54N schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                            09-06-2024, 07:50 PM
                            Acer Spin SPIN 1 SP111-33 Hybrid (2-in-1) 1 Specification for Upgrade or Repair
                            This specification for the Acer Spin SPIN 1 SP111-33 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SPIN 1 SP111-33 boardview and SPIN 1 SP111-33 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                            09-06-2024, 08:40 AM
