Display resolution conf.Help
    Hi guys does This Monitor displays Configurations applies for Linux Mint 14 Mate.
    and can i set one display in VGA output to 1024x768 and the DVI to
    1920x1080 or (1600x900 if this will reduce the over scan on the TV)?
    http://community.linuxmint.com/tutorial/view/877
    Re: Display resolution conf.Help
    on DVI? there should be no overscan on DVI, overscan is pretty much an analog thing. Check the zoom settings on the TV and make sure its 'normal'
      Originally posted by Uranium-235 View Post
      on DVI? there should be no over scan on DVI, over scan is pretty much an analog thing. Check the zoom settings on the TV and make sure its 'normal'
      Uranium my Sony KVHS500 is an Old Tube Hd Tv and the DVI input cuts the edges of the display where the controls for the desktop are,
      i have to have another small led display with VGA with full 1080 resolution to mirror the pic so i can have access to the desktop controls.
        Also on the TV there is no controls for adjust of the over scan.
        i have to live with it,it's not important cause i can see a nice hd full pic, beside the Sony manual says that the DVI is not intended for PCs.
        my beef is not to be able to assigne 2 diferent resolutions for the 2 tvs so i can conf.1080i to the DVI output and 1024 to the VGA output,
        it seems that only can mirror the vga monitor into the dvi tv monitor
        i want to do this cause to have full resolution on the tv the text on the vga tv monitor is two small and hard to see,if anybody know how to config in the terminal 2 monitors 2 diferent resolution i would apreciate,thanks
