how do I polymod this?
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5042
    • US
    I have a shuttle. Input VRM is 16v 1500. thats not an issue. All the output caps are 10v 3300.
    the sucker is a heat problem with this 3ghz/800 prescott in such a small case.
    I at least want to poly the vrm
    3300 is kind of high. What the minimum I can go on this safely? I see some nichicons on mouser that are 10/1500, but they're smd. can I just remove that black piece of plastic and replace and turn these into radials?
    ugh these fuckers are expensive
  • mariushm
    • May 2011
    • 3799
    Re: how do I polymod this?
    I would be comfortable with 1800uF 4v :
    http://www.digikey.com/product-detai...105-ND/1662491
    But 1500uF would probably also work just fine.
    The CPU doesn't see more than 2v or a bit more, so using 4v rated caps should be perfectly safe. They're just using 10v rated caps for best diameter/esr/ripple combo.
    Nah, you CAN remove that plastic bottom but the leads are wider, won't easily go through the holes in the pcb.
    • Uranium-235
      Comrade Glimmer
      • Aug 2007
      • 5042
      • US
      I thought since this was a weird system there might be more involved but I just took it to the meter and it reads 1.2v on output
      damn number of 3300ufs for a 1v output vrm
      • Uranium-235
        Comrade Glimmer
        • Aug 2007
        • 5042
        • US
        damn still $20 for 8 of these fuckers. I just might replace them with nichi HM's.
        thanks for the info, I should of known
        • c_hegge
          • Sep 2009
          • 5219
          I'd go with 1500uF 2.5V Polies (http://www.digikey.com/product-detai...221-ND/1826685). I've often used them on the VRM out to replace 3300uF 6.3 lytics. On the VRM In, Go with 470uF 16v polies. (http://www.digikey.com/product-detai...019-ND/1136109)
          Otherwise, use lytics and mod the case for better cooling
          It shouldn't be $20 for 8 of them. Are you sure you didn't mean $10?
          • Uranium-235
            Comrade Glimmer
            • Aug 2007
            • 5042
            • US
            on mouser, $20
            I like mouser cause they're 5 mins from me and I can pick them up the next day
            unfortunately, all low esr lytics have a minimum diameter of 12.5, and these are 8mm (10 will fit) on mouser
            • mariushm
              • May 2011
              • 3799
              http://www.digikey.com/product-detai...691-ND/2207226
              http://www.digikey.com/product-detai...700-ND/2207236
              Get 10 of these for 6$, plus a couple of dollars on shipping fees.
              What's an extra day when you save more than 10 bucks...
              • Uranium-235
                Comrade Glimmer
                • Aug 2007
                • 5042
                • US
                those are Functional Polymers. Hmm.
                Still better than OST RLS I bet
                • c_hegge
                  • Sep 2009
                  • 5219
                  Nichicon FPCAP are usually quite reliable. Nichicon know what they're doing with their functional polies, so I wouldn't have a problem with them.
                  • ben7
                    Capaholic
                    • Jan 2011
                    • 4059
                    ^ Agreed.
                    DON'T take the plastic off the base of an SMD capacitor, when you bend the leads they are VERY likely to break! I learnt that the hard way...
                    Muh-soggy-knee
                    • Uranium-235
                      Comrade Glimmer
                      • Aug 2007
                      • 5042
                      • US
                      Originally posted by ben7
                      ^ Agreed.
                      in that case I just thought of something. its possible to take some decent sturdy wire, solder it into the holes with ~1-2mm sticking up, and bend it inward, and solder the cap ontop of that. Might come off easy though since its round wire
                      • mariushm
                        • May 2011
                        • 3799
                        It's possible, but you increase the overall length of the capacitor lead this way by a lot.
                        In the VRM section, the length of the wire should to be as small as possible, otherwise the wire will behave like an inductor and potentially mess up things.
                        Plus, with high peak currents there, I don't know how thin wire would behave.
                        • Uranium-235
                          Comrade Glimmer
                          • Aug 2007
                          • 5042
                          • US
                          well I got them in. pain in the ass board to work on but looks great and runs good.
                          runs this chip kind of wierd though. Its a SL6WK 3ghz HT and the 'auto' voltage in the bios sets it to 1.5v, which is 100mv over the max spec by intel. Sure it dosen't hurt anything but it causes it to run hotter, and in this small shuttle case, that sucks. I put it down to 1.35 (intel spec says 1.25-1.4) and it booted fine. still have to get into windows and prime95 it. Monday i'm replacing a ladys 3.2ghz P4 478 with a new MB and a celeron G1610 (which gets awesome scores for a $49 cpu-and backward comatible with pretty much all LGA 1155 boards [some requiring a bios flash]-congrats on intel for porting ivy bridge to 1155, I don't think that socket will be dying anytime soon). Anyways, shell probably let me keep it so I'll take that 3.2 and put it in here see how it does. Add a gig of ram and xp to it, its a nice little box. I plan to eventually replace the rest of the caps with nichicon lytics, unless I can track down the nb vrm (ATI RS300) I might try to polymod that too
                          • Uranium-235
                            Comrade Glimmer
                            • Aug 2007
                            • 5042
                            • US
                            well sonofabitch. I guess the motherboard didn't mind the polys, but the power supply did. Its a 250w /w pfc shuttle psu. Its dead. fuck
                            • mariushm
                              • May 2011
                              • 3799
                              Pictures or it never happened :p
                              • Uranium-235
                                Comrade Glimmer
                                • Aug 2007
                                • 5042
                                • US
                                actually, never happened.
                                One thing I did before I even started this project (I had this shuttle 4 years, bought it 'untested' [though I actually booted it] from goodwill for $50, was used at my old workplace for 2 years. Had heat problems). Turns out one of the 3 fan headers is dead. There are two fan headers under the cpu fan (blowing out the back). One is header 3, which is always full on (for the RS300 fan) the other one is dead, and the other header is actually next to the RS300, but pics always show the RS300 always hooked to header 3. The bios's smart fan feature will only let me choose fan header 1 or 2 for CPU fan throttling. header 1 is dead, and header 2 is too far for the fucking cpu fan cable. But tomorrow i'm going to frys to get another fan since this one's bearings are dirty anyways, and this one from frys will undoubtely have a longer cable. Hell I might get a LED fan. OK ..back to the story. I took apart the PSU before I even considered recapping. Had some OST caps but they were all in good condition. PSU generally looked nice (no burn marks, no bloated caps, no burn smell).
                                I took it apart (the PSU), all looked just fine. Put the tester back on (antec tested with the 5 LED's), started up fine. My initial worry was cause the damn thing would not turn on (the shuttle). The tester gave me 4 orange lights and one green on the 5SB. I put the PSU back together and the computer turned on. Not sure what to think. Maybe something inside was loose. which still worries me
                                • mariushm
                                  • May 2011
                                  • 3799
                                  It was just an expression anyway, but wanted to say it in a funny way to post some pictures if you need a second set of eyes for debugging/investigation purposes.
                                  You could just hack the cable, after all it's just 3-4 wires.. just cut wire, add some wire in the middle, solder and insulate..
                                  I'm not familiar with the small format of Shuttle systems , but depending on how it's laid out too many fans may actually hurt its cooling... there should be air flow, not air pushed inside and going nowhere.
                                  Could you still post some pictures of the system and the power supply (unless you have to open it again in which case don't bother) ? I'm curious to see how it looks inside.
                                  • Uranium-235
                                    Comrade Glimmer
                                    • Aug 2007
                                    • 5042
                                    • US
                                    heres a few online pics
                                    http://www.hardwareoverclock.com/Bar...-ST61G4-17.jpg
                                    http://img.hexus.net/v2/sff/shuttle/st61/Inside1.jpg
                                    it has one copper based heatsink ontop of the 478 chip, heatpiped to a grill in the back, and a fan blowing on that, out the back. The RS300 has an active fan. Suprisingly, mine still works with no bearing issues for such a small fan, which is kind of rare in my experience.
                                    the rest of this page has some other images
                                    http://hexus.net/tech/reviews/system...g4-xpc/?page=4
                                    • ben7
                                      Capaholic
                                      • Jan 2011
                                      • 4059
                                      Since you said the PSU worked after you moved it around again, I am guessing there is a bad solder joint or two in there. Possibly from your soldering, or possibly other joints have cracked from being stressed by the disassembly process.
                                      Muh-soggy-knee
                                      • c_hegge
                                        • Sep 2009
                                        • 5219
                                        You polymodded the PSU?
                                          HP Pro Pro 3300 SFF Pro 3300 G850 Specification for Upgrade or Repair
                                          This specification for the HP Pro Pro 3300 SFF can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Pro 3300 SFF boardview and Pro Pro 3300 SFF schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                                          09-12-2024, 03:44 PM
                                        • dragon3x
                                          by dragon3x
                                          power on.
                                          Here are some examples :
                                          switching supply area).
                                          than 6.3 V.)
                                          03-21-2025, 02:46 PM
                                          DELL Latitude 3300 Notebook 3000 Specification for Upgrade or Repair
                                          This specification for the DELL Latitude 3300 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 3300 boardview and 3300 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 3300...
                                          09-06-2024, 02:34 PM
                                          09-06-2024, 12:30 PM
