PCI in PCI-X
+ More Options
Posts
  • Logistics
    • Apr 2007
    • 721
    PCI in PCI-X
    I'm not well educated on the nuances of utilizing PCI-X slots. Does the entire length of the slot run at 133MHz if it's a 133MHz PCI-X slot or does only the added, back portion run at that speed.
    I'm wondering if there are PCI cards, specifically video cards, which will utilize the front half of a PCI-X slot, but still run at the full speed of the PCI-X slot.
    The best thing that seems to remain in the PCI world is the Geforce 8400GS, which claims to miraculously be able to play full HD video. (I only question this because I thought more bandwidth would be required to do this.) Do you suppose manufacturers of this card have designed it to be able to run at the 133MHz of a PCI-X slot?
    Any info would be appreciated as this is an area I am foggy on.
    -Logistics
    Presonus Audiobox USB, Schiit Magni 3, Sony MDR-V700
  • brethin
    • Dec 2008
    • 1907
    Re: PCI in PCI-X
    There are many different speeds of PCI-X slots ranging from 33MHz to 266MHz depending on the board its on. Never asume because its PCI-X its 133MHz. Unlike say PCI which is 33MHz or AGP which is 66MHz PCI-X uses many different speeds depending on the board they are on. ANY PCI-X card placed in a PCI slot (and yes there are many) will run at the PCI rate. So sticking a PCI-X 266MHz card in a standard PCI slot will drop it to 33MHz if the card supports running in a half slot (or PCI vs PCI-X slot).
    • mariushm
      • May 2011
      • 3799
      Re: PCI in PCI-X
      No, the card runs at 33 Mhz PCI 32 bit. The 133 MB/s shared between all pci slots is plenty for a video card.
      The way the card can decode HD video is through a hardware decoding chip on it. The driver sends the compressed frames to the chip, chip decodes them and puts the output in the video card memory and the driver can then overlay that frame over the screen image. The image doesn't have to be sent back to the computer so there's no heavy transfers across the pci.
      You can put pci cards into pci-x slots but the majority of the cards will support only the 32bits side. Some video chipsets may auto detect the pci-x and run on 64 bit bus... thinking of workstation aimed video chips.
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        Re: PCI in PCI-X
        The main difference between the two for your purposes is the voltage. Regular PCI is normally 5V, while PCI-X is normally 3.3V. As a result, the key in the slot is in a different position for each.
        Few PCI cards are 3.3V only. However, many have two keys cut in them and are thus dual voltage (3.3V and 5V).
        If it fits in the slot (correct voltage key), then it should. (I did it to my main rig with a 1394 card).
        If not, then it obviously will not work.
        Beware of cards that hare "double keyed" but are not actually dual voltage. I have an old higher-end diamond sound card that is like that. It's stupid but for whatever reason once in awhile you come across a dumb design like that.
        The way you tell is to try the card in the slot. If it POSTs and the card shows up in the OS, you're good. If not, then it's not really dual voltage and not usable in a standard PCI-X slot. Don't worry, getting the wrong voltage in a PCI-X won't kill anything since at worst you are putting a 5v card in a 3.3V slot.
        Data wise, PCI-X was meant to be backwards compatible from day 1. This also works for PCI-X cards that are dual keyed; they will usually work in a regular PCI slot running as a regular PCI card, provided that the particular shot has no components nearby that get in the way of the extra unused connector.
        Hope this helps. If not, I have some spare/Junk parts that I can use to make some tutorial pictures.
        sigpic
        (Insert witty quote here)
        • brethin
          • Dec 2008
          • 1907
          Re: PCI in PCI-X
          NO PCI card will ever run at anything other than 33MHz (unless overclocking the PCI buss) no matter what slot you put it in (and no sticking a PCI 33Mhz card in a PCI slot on a 266MHz PCI-X buss will just make that buss run at 33MHz). If you put a PCI card in a system with a PCI-X buss running at 266MHz it will slow down and make the buss run at 33MHz. This is why many server boards had multiple PCI-X busses so you could group the cards in the slots per buss based on the cards speeds and not cripple all the slots because of 1 slow card.
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            Re: PCI in PCI-X
            True... That may explain some oddities regarding my personal setup although removing the pci card int he PCI-X slot made no difference.\
            That said, if the OP isn't using any PCI-X cards, who gives a darn if his PCI-X bus speed slows down?
            sigpic
            • Logistics
              • Apr 2007
              • 721
              Re: PCI in PCI-X
              True. My board has a single 133MHz PCI-X slot, two 100MHz and a single PCI slot. I'm not worried about slowing the bus down, I just thought I would need to make an attempt at more bandwidth so the system could genuinely put out real HD video. However, I believe my TV is only a 720p rig so I don't need HD in 1080. Now, I just need to find said card in low-profile so I can stick it in the rack server I just bought.
              • homerging
                • Dec 2011
                • 24
                Re: PCI in PCI-X
                I can remember much the same problem affecting some early AGP cards. Put them in the wrong motherboard and things would go very badly.
                • japlytic
                  • Oct 2005
                  • 2086
                  Re: PCI in PCI-X
                  As far as I know, PCI-X (not Express) slots have only been used in workstations and servers.
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    Re: PCI in PCI-X
                    Powermacs used them. I also know of desktop boards that used them (the Supermicro PDSGE in my dad's rig has 2).
                    sigpic
                      HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera EliteDesk 800 i7-7700 Specification for Upgrade or Repair
                      This specification for the HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our...
                      09-12-2024, 02:00 PM
                    • totoagung2
                      by totoagung2
                      Totoagung2: Situs Slot Gacor Paling Gampang Jackpot di Indonesia 2024
                      Hadirnya situs slot gacor gampang jackpot Totoagung2 yang menyediakan banyak sekali permainan slot terpopuler terkini yang hadir setiap tahun nya. Tentunya di Indonesia sendiri yang menjadi salah satu negara yang favorit bagi provider game slot. Banyak sekali pengembang permainan melihat negara tanah air Indonesia untuk menjadikan dan mencoba berbagai kesempatan bisnis judi online yakni games judi slot Totoagung2 terbaik dan terpercaya no 1. Hal itu juga dibuktikan dengan sangat banyaknya provider mesin slot...
                      01-01-2024, 02:43 PM
                      GeForce RTX2080 Super Aero video gaming card issues help need
                      by sam_sam_sam
                      This is from my son’s gaming computer that at first had minor overheating issues when playing a very intense game with it causing the computer to crash or reboot
                      Then bough a new motherboard and a new computer case that a cooling system in it already installed also brought the cooling system for this video card but now the issue with it is that it randomly rebooted screen goes blank randomly and suddenly video freezing or started with video being there then blank screen and then the video comes back or it just stays blank for a while and then maybe it will come back but it...
                      05-07-2023, 08:12 AM
                      HP EliteBook x360 1030 G2 + GoPro HERO6 Black 4K Ultra HD Video Camera Notebook Specification for Upgrade or Repair
                      This specification for the HP EliteBook x360 1030 G2 + GoPro HERO6 Black 4K Ultra HD Video Camera Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1030 G2 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and 1030 G2 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users...
                      09-06-2024, 06:20 AM
                    • alro7779
                      Samsung UN55MU6103F video problem; has colored stripes on the display
                      by alro7779
                      Hello, everyone!
                      A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,...
                      09-27-2025, 11:29 PM
