Stupid questions on Ubuntu Server
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    So I set up a webserver at work, running Ubuntu Server 12.04 LTS 64-bit, a 500GB WD Caviar Green HDD, and 2GB RAM...
    It works well, http://renewcomputers.dyndns.org/
    HOWEVER I'm having some trouble with FTP
    I want to transfer some huge files to it, and put them in the /var/www directory...
    Point being, what the heck am I doing wrong? Before, I was able to anonymously log in with FileZilla, now after doing some more edits to /etc/vsftpd.conf it just says Connection Refused...
    This is the guide I followed to FTP setup:
    https://help.ubuntu.com/10.04/server...tp-server.html
    One more thing, how do I make a MySQL user for a SugarCRM web app (which I'm trying to upload to it lol). I've already imported the database with PhpMyAdmin which i installed!
    THANK YOU!
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5045
    • US
    Re: Stupid questions on Ubuntu Server
    as someone who has ran ubuntu servers for the past several years, let me suggest:
    http://www.webmin.com/
    from what I can tell from thier site there is a module for vsftp
    http://www.webmin.com/cgi-bin/search...i?search=vsftp
    once its installed, it will scan for all packages and load the proper module
    • shovenose
      Send Doge Memes
      • Aug 2010
      • 6575
      Looks interesting. I might consider that for my home server. However, this server at work won't do anything besides host this web-application and it's database...
      so it seems silly to bother with a control panel. Really, I just need to use this FTP once, to set up this thing...
      I would like to do this without a control pane, thank you though.
      • Uranium-235
        Comrade Glimmer
        • Aug 2007
        • 5045
        • US
        is ssh enabled on the server?
        then get winscp
        http://winscp.net/eng/index.php
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16959
          www.ispconfig.org
          not sure how friendly it is with ubuntu, but its spiffy with Debian and FC (the two I've used it on). Its a pain in the ass to set up, but once you find the sweet spot, it makes managing web servers sexually arousingly easy (especially with multiple sites, FTP, email, SSL, and so on)!
          <--- Badcaps.net Founder
          Badcaps.net Services:
          Motherboard Repair Services
          http://folding.stanford.edu/
          Team : 49813
          Join in!!
          Team Stats
          • mariushm
            • May 2011
            • 3799
            I've only worked with FreeBSD a while ago (not into network administration these days) but when I did, I used pureftpd (for minimal basic usage) and proftpd - i remember it was very easy to configure and didn't require creating actual users on the system for people to actually be able to authenticate. also had settings for total disk space usage restrictions, bandwidth limits, total files+folders per account, stuff like that.
            it's a bit fuzzy (long time ago) but I think i hated vsftpd because it needed users so it could chmod the files and stuff like that.
            In your case, since it's a one time thing I'd just install wget and upload a zip of the files somewhere. then unpack it to your destination folder.
            When I couldn't set up a ftp server for various reasons (mainly being behind a firewall and no way to open ports) i simply installed midnight commander (mc) on the server - in case you don't know it's like norton commander from the dos days - which has ftp client functionality. Then I set up a ftp server at home and just connect from mc on the server to my home computer.
            • shovenose
              Send Doge Memes
              • Aug 2010
              • 6575
              I think I'm going to remove vsftpd and use pureftp.
              I'll post if I come into some problems!
              • Uranium-235
                Comrade Glimmer
                • Aug 2007
                • 5045
                • US
                if you have ssh enabled on there you should be able to use winscp. It can transfer data just like a normal ftp client. infact I use it as a ftp client for other ftp sites cause it works very well as sftp(ssh)/ftp/scp and its free
                you don't need any ftp server with winscp, it uses the scp system built into ssh
                • shovenose
                  Send Doge Memes
                  • Aug 2010
                  • 6575
                  I have tried WinSCP, that's the first thing I tried before I even came here!
                  No, it did not work I did not have permissions or something stupid like that...
                  • Uranium-235
                    Comrade Glimmer
                    • Aug 2007
                    • 5045
                    • US
                    sometimes you have to use putty to login to the console with ssh and sudo chmod a folder
                    • omega
                      Troubleshooting of redundant F750E-S0 Dell PowerEdge Server
                      by omega
                      Hello all,
                      as a beginner electronics hobbyist, after a few years I would like to place another post on this Forum section, given that I did not succeed in finding any useful advice among the other posts.
                      Over the last years, I have been using a PowerEdge Dell Server with two redundant PSUs, namely the 750W F750E-S0 ones (aka 06W2PW). Unfortunately, last summer one of them failed (perhaps owing to an overheating), and the server had for working to take into account the other one only. Of course I opened and tried to troubleshoot the failed PSU, but each cap I tested seemed to...
                      02-09-2024, 03:34 PM
                      HP ZBook 15v G5 Mobile server 15v Specification for Upgrade or Repair
                      This specification for the HP ZBook 15v G5 Mobile server can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15v G5 boardview and 15v G5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP ZBook 15v...
                      09-06-2024, 11:39 AM
                    • harp
                      Comparing FreeNAS, FTP server, SMB server, multimedia server...
                      by harp
                      I thinking about some central LAN file server, on where I can put some files from other devices, or access to them, and maybe play some movie without download...
                      I never study this, but when I see that freenas need few gigabyte of ram to recommended working, some wiered partition, I wonder if I miss somewhat in the midletime...
                      Also exist "turnkey file server", and other turnkey products that I can not distinguished what is major difference and how it perform - no experiance at all.
                      What is general difference between this products, and what be most useful...
                      01-04-2024, 02:44 PM
                    • Fireballcz
                      Windows 2016 server L2TP/IPsec VPN - two subnets
                      by Fireballcz
                      Hello, please how to properly configure VPN in this environment?
                      I have two subnets in two different (geographical) workplaces, connected via IPsec (thru gateway routers)
                      Main subnet: 192.168.11.0/24, gateway (router IP) 192.168.11.1, Windows 2016 server (VPN, DHCP, DC etc.) 192.168.11.3
                      2nd subnet : 192.168.22.0/24, gateway (router IP) 192.168.22.1 - just client computers.
                      I need to allow external (home office) users connect via VPN server (192.168.11.3) to the 2nd subnet (192.168.22.0/24) to their computers (via RDP).
                      I have no problems with VPN connection...
                      07-29-2022, 03:20 AM
                    • frans00000001
                      Supermicro Server mainbaord x10dri-ln4+ schematic
                      by frans00000001
                      Good day
                      I am looking for a mainboard schematic for a Supermicro Server mainbaord x10dri-ln4+ as the track broke off on the BIOS chip and I want to repair to use the server again. If possible can someone assist to get this schematic?
                      08-06-2025, 05:36 AM
