Re: CDs make me sick
I found this while I was waiting. Hope you'll find it useful. Once you've installed it, it functions almost as if it was integral to Windows.
By the way: I understand if you don't have the HDD space necessary to back up all your CDs and DVDs. But if you have it, you really should use it. I'll bet you $1000 that a TON of hard drive space goes to waste these days.
CDs make me sick
There is only one thing to remember: There is no substitute for a proper backup system.Leave a comment:
You didn't have flash memory in 1982, when the compact disc (CD) was invented. You didn't even have 3.5" floppy disks until 1984, when IBM came up with 720 KB floppies in that format.
So you only had floppy drives, tape drives and hard disks that were going into the 5.25" slots because 3.5" drives only appeared in 1988 when Connor made the first.
CDs were very good and reasonably protected. Remember, they were supposed to be played at 1x which is 150 rpm, and the imprints in the chemical layer were much more pronounced than nowadays so the devices were able to read the data on them even with quite a few scratches.
Much later as burning speed went up, different chemical compositions were used and the "grooves" made by the writers were less pronounced and more prone for read errors. Fast read speed also made it worse as the plastic expands with the high speed, but the drives themselves got better error correction and so everything kept up.
ps. Oh... even the CD-R standard was added to the CD standard only in 1988. So you should probably look up how much did a 3.5" drive cost in 1988 and see how well it would have worked for you to use hard drives to move data around.Last edited by mariushm; 04-26-2012, 04:45 PM.Leave a comment:
If you don't like them, you have tapes.
Oh, I'm sorry, you want big storage AND fast random access?
Also, they wanted to be very easy to explain to old people and noobs how they work... imagine how you would explain your grandmother how to use them if they were cartridges.
Hmm.. One good whack with a sledgehammer and both will be equally toast.Leave a comment:
Oh, I'm sorry, you want big storage AND fast random access? Then live with it.
ps.
Initially the discs were meant as replacement for regular discs, the ones where a head physically touches the grooves and forms sound due to the vibrations in the crystal, and cassette tapes. Computers already had 1-4 GB tapes and tape drives.
There were ideas thrown around to encase the disc in a cartridge but they gave that up to make things cheaper to manufacture (sega and sony also gave up on cartridges soon after and went with cd like formats). Also, they wanted to be very easy to explain to old people and noobs how they work... imagine how you would explain your grandmother how to use them if they were cartridges.Last edited by mariushm; 04-26-2012, 03:52 PM.Leave a comment:
Well, when CDs came your other choice was a 1ft stack of floppies...Leave a comment:
You can always encase it yourself within a jewel-box or cover...Leave a comment:
CDs make me sick
LOL...who thought making a high-precision optical device out of easily scratched polycarbonate and then not encasing it was a good idea???
Don't forget that there's only a neglegibly thin layer between the outside world and the data on traditional CDs.
And to top it off, blank optical media seems to be another thing where it's harder and harder to get good quality. I even remember seeing visible defects on TDK branded CD-Rs after like 2-3 days. FAIL. And I thought TDK was meant to be a good brand...
Anyway, here's my advice: ALWAYS back up optical discs of everything, unless it's a non-PC-readable format. DON'T use CD-Rs for personal data unless you have to for compatibility. Right???
Yes, I know hard drives fail. But CDs are 1,000,000 times easier to destroy.Tags: None
by triplefourTV flashes backlight then reboots over and over. no image. Client said it used to have image for a bit before rebooting. Got worse over time.
tcon is built into mainboard.
Only one cable goes to panel boards.
there is a cable from one panel board to the other that links them.
cost cutting measure that results in us having harder time to diagnose.
removing the link to the second panel board allows TV to stay on with stable backlight but no image.
used cut off tape method to mask 1 maybe 2 pins on the side of the cable that goes to that second panel board.... -
by sheppHello People, Not been on here for a long time but I have a treadmill to get my teeth into & I'm struggling to find the problem....
So the machine runs sometimes, but then other times I get the error code 3 for Low voltage, so the low voltage could be the motor output voltage from the drive or it could mean something else, all the voltages seem stable enough, like 24V etc...
On startup from a mains power up the relay at the line input socket clicks in & out constantly which its not suppose to do, so my 1st thoughts are with this circuit somewhere.....
...16 Photos -
by wrobbieMy T14's (NM-C801) main USBC input keeps failing every few months. Initially, it worked fine for several years. The symptom is that once powered from the main USBC port using a 65W power brick, after some time (minutes, hours) charging will fail completely. Powering from the secondary (docking) USBC input still works. This laptop is basically always plugged in. The first time it happened, it took me a long time to find that the FPF2281 over-voltage IC for that USBC input was at fault. When the issue occurs, it will continuously reset power delivery negotiations with the power brick -- according...
by Jamey021So, what are the odds I shorted the M2 CPU? I got in an a2681 MacBook Air. Liquid damage. Ordered from China and replaced a chip (APL109D 343S00555) cleaned corosion and ultrasonic..The whole 9 yards.
Last night I put it all together and it came on beautifully. 20V- Apple Logo. I celebrated and knocked the LCD connector loose right away while holding the laptop. Now, it wont boot and it cycles on the volt meter.
Cycle 20v - .02a then volt meter goes off, then it comes on and rinse and repeat. Classic sign of a MacBook short. I looked at the board with my thermal camera and I can...01-22-2025, 05:22 AM -
by czacha414Guys, I need your help. I have an issue with Lenovo T490s laptops – several dozen units in different configurations, and in about half of them, the same problem appeared over time. Specifically, the Enter and Backspace keys don't work unless they are held down for a few seconds or pressed slightly harder than usual. Once they start working, they continue to function until the next reset. However, this is not just a Windows issue – it occurs under other operating systems, in BIOS, and during POST as well.
While searching for information, I found many threads describing the same...12-27-2024, 01:41 AM - Loading...
