Check this one out LOOOLZ!!!!
  • Koda
    • Aug 2011
    • 317
    • Macedonia
    http://www.dealextreme.com/p/colorfi...cs-card-109821
    128mb memory on a radeon 5550 OMG!!!
    Guns don't solve problems. I'll take 12
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16959
    Re: Check this one out LOOOLZ!!!!
    is that for real?! Typo/mistake? I havent seen a 128mb card in probably 5 years....and a radeon HD.....but then again, what do you expect for $65.00!!
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • shovenose
      Send Doge Memes
      • Aug 2010
      • 6575
      Maybe they meant it had a 128-bit interface with the memory? lol
      • Koda
        • Aug 2011
        • 317
        • Macedonia
        I doubt that, check the picture of the backside, it has only one ram field populated and it's GDDR2, oh and I see another ram chip under the heatsink in the lower right side. btw this is the first time I heard of colorfire, they probably manufacture these cards in an oven in some garage and where I'm at I can buy a 1GB GDDR3 5550 for exactly the same price.
        • mariushm
          • May 2011
          • 3799
          128 megs is enough for that card.
          If you read the specs it says 32 bit memory interface, which is about right, considering the ram locations are populated with just one or two ddr2 chips (i only see one on the bottom pcb).
          The card pcb is most likely the default, as there's 8 ddr2 chip pads.. making it for a total of 1 GB at 64bit
          The price seems to be the only issue - you can get low profile cards with 4550 at 45$ on newegg: http://www.newegg.com/Product/Produc...82E16814150582
            AMD Radeon R9 290 / R9 380 / R9 390 Schematic & Board View
            The Radeon R9 290 was a high-end graphics card by AMD, launched on November 5th, 2013. Built on the 28 nm process, and based on the Hawaii graphics processor, in its Hawaii PRO variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon R9 290. The Hawaii graphics processor is a large chip with a die area of 438 mm² and 6,200 million transistors. Unlike the fully unlocked Radeon R9 290X, which uses the same GPU but has all 2816 shaders enabled, AMD has disabled some shading units on the Radeon R9 290 to reach the...
            10-01-2024, 12:46 PM
            AMD Radeon RX Vega 56 / RX Vega 64 Schematic & Board View
            The Radeon RX Vega 56 is a high-end graphics card by AMD, launched on August 14th, 2017. Built on the 14 nm process, and based on the Vega 10 graphics processor, in its Vega 10 XL variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon RX Vega 56. The Vega 10 graphics processor is a large chip with a die area of 495 mm² and 12,500 million transistors. Unlike the fully unlocked Radeon RX Vega 64, which uses the same GPU but has all 4096 shaders enabled, AMD has disabled some shading...
            10-01-2024, 01:07 PM
            AMD Radeon RX 470 / RX 580 Schematic & Board View
            The Radeon RX 470 is a mid-range graphics card by AMD, launched on August 4th, 2016. Built on the 14 nm process, and based on the Ellesmere graphics processor, in its Polaris 10 PRO variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon RX 470. The Ellesmere graphics processor is an average sized chip with a die area of 232 mm² and 5,700 million transistors. Unlike the fully unlocked Radeon RX 480, which uses the same GPU but has all 2304 shaders enabled, AMD has disabled some shading units...
            10-01-2024, 12:52 PM
            AMD Radeon R7 340 / R7 430 Schematic & Board View
            The Radeon R7 340 OEM was a graphics card by AMD, launched on May 5th, 2015. Built on the 28 nm process, and based on the Oland graphics processor, the card supports DirectX 12. Even though it supports DirectX 12, the feature level is only 11_1, which can be problematic with newer DirectX 12 titles. The Oland graphics processor is a relatively small chip with a die area of only 77 mm² and 950 million transistors. It features 384 shading units, 24 texture mapping units, and 8 ROPs. AMD has paired 2,048 MB GDDR5 memory with the...
            10-01-2024, 12:36 PM
            AMD Radeon RX 7900 XT (RX7900XT) Schematic & Board View
            The Radeon RX 7900 XT is an enthusiast-class graphics card by AMD, launched on November 3rd, 2022. Built on the 5 nm process, and based on the Navi 31 graphics processor, in its Navi 31 XT variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on Radeon RX 7900 XT. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The Navi 31 graphics processor is a large chip with a die area of 529 mm²...
            10-01-2024, 12:20 PM
