I'm considering only using my laptop from now on...
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    Currently I use a Compaq PC hooked up to my Dell 23" LCD...
    I'm considering just letting it go on Craigslist and just hook my LCD up to my laptop...
    I'd use the nice graphics card from the Compaq in the Bedside PC and use the lame Geforce 6200 in the Compaq (since the onboard VGA port is dead for some reason; probably the nShitia chipset)...
    Do you think it's an OK idea?
    Specs of Compaq:
    -CPU: Athlon 7550 (2.5GHz)
    -RAM: 3GB DDR2
    -HDD: Seagate 160GB
    -Graphics: GeForce 8600GTS 256MB
    -OS: Windows 7 Ultimate 32-bit
    Specs of laptop:
    -Lenovo IdeaPad V570
    -CPU: Core i5 2.3GHz quadthread (dual-core with HT) Turbo Boost to 2.9GHz
    -RAM: 6GB DDR3
    -HDD: 640GB WD
    -Graphics: Intel HD 3000
    -OS: Windows 7 Home Premium 64-bit + Windows 8 Developer Preview
    Do you think I should just hold on to the Compaq or do you think I should use the Lenovo... I mean, this nice Lenovo laptop doesn't do a lot of good sitting on the table unused lol...
    Also, how much do you think I could sell the Compaq CQ5107C for? (I'd put a legit Vista install on it using the product key on it instead of my *alternative* Windows 7)...
  • mockingbird
    • Dec 2008
    • 5484
    Re: I'm considering only using my laptop from now on...
    No way... Why wear out a puny 60W adapter that's enclosed in a plastic chassis with zero ventilation when you can abuse a full-fledged desktop with impunity.
    Not to mention that the wrist rest on laptops dull in color due to hand sweat after extended use.
    Laptops are not desktop replacements.
    • shovenose
      Send Doge Memes
      • Aug 2010
      • 6575
      1. I'd be using an External keyboard
      2. Aren't these big laptops pretty much marketed as desktop replacements?
      The thing about the power adapter is a good point though for sure.
      • mockingbird
        • Dec 2008
        • 5484
        High-performance laptops are not a good idea if you ask me...
        The idea of them started out as a way for 3D-Designers to be able to take their projects away from their office.
        Now they're selling laptops with quad core CPUs and near desktop-class videocards... Laptops shouldn't run hot. It defies their original concept... If you get a quad-core laptop with a Geforce 525/540m class GPU, it's ostensibly a reasonably good gaming platform but why do it? You can get a significantly more powerful abuse-tolerant desktop for a lot less.
        If you get a quad-core laptop with plain integrated video, then what's the point of all that processing power... And I still didn't mention the mandatory glossy screen. Why stare at that power-optimized LCD when you can use a full-fledged LCD?
        If someone needs a laptop, they should get something reasonably fast that runs reasonably cool and is cheap. Why? Wear. Sure the insides can last a long time (They use tantalum caps), but like I said, the outside will wear. Get something you won't be attached to and will be able to toss in a few years.
        Following this logic, why would you want to get something souped up to begin with.
        Buying a performance laptop is like buying a Lambourghini and driving it in Alberta throughout the winter.
        • shovenose
          Send Doge Memes
          • Aug 2010
          • 6575
          I get that games will run like ahit. Actually, Minecraft is pretty much unplayable. But, as I do more work on my computer and less games, that becomes less important.
          As stated, my laptop has Intel integrated graphics. So it does run quite cool. Also because it has a 5400RPM hard drive and a good cooling system (I think, lol!)
          This laptop is wwwaayyy too big to carry around; that's what my MacBook Air is for...
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            They key word being MARKETED.
            They are not a replacement... Laptops are laptops. Desktops are desktops.
            Laptops should be a portable as possible given screen size/resolution needs.
            Now, if you need a laptop, there are features that may be considered "souped up" that may have merit. things like metal construction, decent graphics (If needed), etc.
            In my case for instance, I do all my college work On My dell latitude d630. The reason is mainly because my work involves both note taking and lab work, both of which a laptop is essential (there are school desktops for labs, but due various reasons, they suck). I also do most of my homework and projects on it as well. Having all of it under one computer is essential.
            It also sees a lot of home and travel use, the former being for various reasons (desktop location, OS, lazyness , etc.)
            After evaluating my usage, I came up with these requirements for a college laptop for me:
            -Durable. No plastic crap (I have had clumsy moments now and then, last semester was a doozy)
            -Decent power. Pentium M range or better. Core2 range if within budget.
            -Good battery life, or at least the capability after battery replacement
            -Not too heavy/large. I use it daily and it is often being lugged
            -Good linux compatibility
            As luck would have it, I came across the D630 the day before my birthday last summer and it was gifted as an birthday/ HS graduation present. It fit all the requirements and for what I do, it fills the role perfectly.
            For you, shovenose, I'd suggest you spend a few days figuring out your needs before you buy anything... you may even find that a laptop isn't what you need after all.
            sigpic
            (Insert witty quote here)
            • shovenose
              Send Doge Memes
              • Aug 2010
              • 6575
              Um... hold on one sec.
              I already own the Lenovo laptop!
              I'm just trying to figure out if using it as my desktop computer would make sense so I can sell my big PC...
              • ratdude747
                Black Sheep
                • Nov 2008
                • 17136
                I know, I was just describing how one would see what fits... If the lenovo didn't come close to fitting, then sell it and buy something that fits better.
                sigpic
                • cheapie
                  null
                  • Jul 2010
                  • 849
                  Your desktop is still much better than all 3 of mine...
                  • shovenose
                    Send Doge Memes
                    • Aug 2010
                    • 6575
                    I love my Lenovo laptop! Lol!
                    Again, the point of this thread is for me to get advice as to whether I should use my Laptop or my main Desktop as my main computer...
                    • Topcat
                      The Boss Stooge
                      • Oct 2003
                      • 16958
                      I wouldn't....but I'm not a fan of frail little laptops when I have my bulletproof desktop in front of me.
                      <--- Badcaps.net Founder
                      Badcaps.net Services:
                      Motherboard Repair Services
                      http://folding.stanford.edu/
                      Team : 49813
                      Join in!!
                      Team Stats
                      • pentium
                        • Mar 2006
                        • 2778
                        I like my laptop having four hours of life and days on standby even if it costs me my ability to play modern games. There's also that modern wonder of Remote Desktop so if your old Pentium M can't handle Youtube, just connect to your box at home and play it through that.
                        But hey, you make it sound like there are no decent DOS/9x games around.
                        Nobody will laugh at you for playing Alien Carnage though they might ask what Indie game studio released it.
                        Find Nedry!
                        Check the Vending machines!!
                        • smason
                          • 1652
                          Wow, can't believe I agree with an entire Mockingbird post even the part about Alberta
                          I use a moderate laptop ($250.00 3 year old D830) and if I need more, I RDP into the desktop system, or on rare occasions, get off my ass and go to the desktop machine.
                          • 370forlife
                            Large Marge
                            • Aug 2008
                            • 3112
                            Luckily I was able to swipe a HP Compaq 8710p from my friend for $50. It's a bit massive, 17.3", with a T7500 and Nvidia NVS 320M graphics card, it runs Autodesk AutoCAD and Inventor extremely well which is good for when I work on my projects for college. I no longer use my desktop anymore as this laptop does everything I need to.
                            • shovenose
                              Send Doge Memes
                              • Aug 2010
                              • 6575
                              My laptop does EVERYTHING I need except have a big screen...
                              That's why I want to use it.
                              But I guess we've come to the conclusion that I should just use my lousy desktop
                              • Topcat
                                The Boss Stooge
                                • Oct 2003
                                • 16958
                                Well, we just offered our opinions. If you want to use your laptop and get rid of your desktop, knock yourself out my friend!
                                Team : 49813
                                Join in!!
                                Team Stats
                                • shovenose
                                  Send Doge Memes
                                  • Aug 2010
                                  • 6575
                                  It soudhns like y'all got a good argument, so for now I'll continue using my desktop.
                                  But when I get an SSD for my laptop this Compaq shit's gonna get sold
                                  • Wester547
                                    • Nov 2011
                                    • 1268
                                    • USA.
                                    I'm also in agreeance with the opinions articulated in this thread, but something else I'd like to add is that troubleshooting a laptop is not nigh as easy and workable as troubleshooting a desktop. In a laptop, you can only replace the RAM, battery, HDD, and AC adapter with ease; if something else goes wrong it will likely involve recapping it (which isn't as easy as it would be on a desktop), reflowing it (similar can be said of that), or the logic board would need replacing since the components are so integrated and compact by comparison....
                                    But I do think that, like with any kind of system that isn't inherently defective, treat it well and don't push it very hard ad nauseam and it will probably last you a good while. I'd say that applies for laptops and desktops (for the sake of the electricity bill, I would admonish not running it 24/7 and exercising the battery in the case of the laptop so as to prevent it from drying out, but, of course, you're free to use it as you so wish... and I wouldn't put it through too many power cycles either, for the sake of thermal expansion). While I do, as stated, agree with the insight offered in this thread already, I doubt it'd be as easy or conveniencing to lug your desktop around like you could your laptop, though I don't recommend abusing the laptop in that regard.
                                    And, of course, laptops are not nearly as easy to upgrade, and for that matter just aren't as upgradeable. I know you have a solidified setup in performance but just to add. Also, both the G84 (8600 GTS) and NV44 (GeForce 6200) have bumpgate problems (with their underfill) that no amount of reflowing or reballing can permanently solve. They will eventually stop working, perhaps sooner than later. Since it's a desktop, however, it can be tiffed that it would be a decent lifetime for a graphics card, but even then, they could prematurely die. So, you may either consider a graphics card replacement from AMD/ATI for your desktop if you use it again or remain a stickler for your laptop (assuming you're not that much of a gamer - last I checked, Intel's drivers are not very compatible with a great range of 3D games).
                                    Last thing, I would keep the temperatures in your laptop below 70C (or 158F) at the very least, at all times. Your CPU may be able to handle it but the rest of the components will eventually suffer the ramifications, I would think...
                                    • shovenose
                                      Send Doge Memes
                                      • Aug 2010
                                      • 6575
                                      Thank you all for the thoughts
                                      But there are some new developments: I am now forced to use my Lenovo laptop as pretty much my only/main computer. Why? Because my last grade report was pretty bad and so I'm pretty much banned so I can't use my desktop computers (I had to put them in the corner ) but I can still use my laptop *for school stuff* and whatnot...
                                      Of course, right now I'm on here and playing games because my mom's not home... but point being this laptop's gonna have to for a while.
                                      The good news? I might get a 64GB Kingston SSD for it next Saturday
                                      • Agent24
                                        I see dead caps
                                        • Oct 2007
                                        • 5037
                                        • New Zealand
                                        I would have at least one desktop and one laptop. Both are useful and neither can replace the other.
                                        One problem with running a laptop as a desktop is that the battery is going to be fully charged most of the time - which I believe isn't a good thing for its lifespan - but neither is taking it out and leaving it discharged.
                                        And as someone else said, a high-performance laptop can be an overheating nightmare. I would rather run games and such on my desktop (yeah I don't do as much gaming now as I did either, but when I do, I want it to work well!)
                                        -David VanHorn
                                          HP Compaq Compaq SG3-240ES Compaq SG3 220 Specification for Upgrade or Repair
                                          This specification for the HP Compaq Compaq SG3-240ES can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Compaq SG3-240ES boardview and Compaq Compaq SG3-240ES schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-12-2024, 03:44 PM
                                          HP Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) Compaq Elite 8000 E5500 Specification for Upgrade or Repair
                                          This specification for the HP Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) boardview and Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request...
                                          HP Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower Compaq Pro 6005 B59 Specification for Upgrade or Repair
                                          This specification for the HP Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower boardview and Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information....
                                          09-12-2024, 03:36 PM
                                          HP Compaq Compaq dc7900 Compaq Q9400 Specification for Upgrade or Repair
                                          This specification for the HP Compaq Compaq dc7900 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Compaq dc7900 boardview and Compaq Compaq dc7900 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                          09-12-2024, 03:30 PM
                                          HP Compaq Compaq SG3-331IT Compaq SG3 245 Specification for Upgrade or Repair
                                          This specification for the HP Compaq Compaq SG3-331IT can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Compaq SG3-331IT boardview and Compaq Compaq SG3-331IT schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
