Why Ubuntu and Windows 8 do/will fail.
  • joshnz
    • Feb 2011
    • 969
    • New Zealand
    Re: Why Ubuntu and Windows 8 do/will fail.
    Encryption + bot net = no encryption.
    humans + encryption = failed encryption (leaked keys etc)
    The only thing that will stop a bot net is rolling encryption.
    My pc
    CPU : AMD PHENOM II x4 @ 3.5Ghz
    MB : ASUS M4A89TD PRO USB3
    RAM : Kingston ValueRAM 16gb DDR3
    PSU : Cooler Master 850W Silent Pro
    GPU : ATI Radeon HD 6850
    • brethin
      • Dec 2008
      • 1907
      And even rolling Encryption can be hacked, just ask Dish Network they have been using it for years.
      • mockingbird
        • Dec 2008
        • 5484
        Last I checked, no public hack was available for Nagravision 3.
        Key sharing doesn't count, which is what those boxes do (And as you know, they have to be connected to the internet at all times).
          LCD LED TV Service Menu Codes
          ALL LCD LED TV SERVICE MENU CODES
          Service Menu Code with Board Name
          China Universal Board / Jumper Board Service Menu Code
          Changhong Ruba Service Menu Code
          Ecostar LED TV Service Menu Code
          Orient LED TV Service Menu Code
          Haier LED TV Service Menu Code
          TCL LED TV Service Menu Code
          Samsung LED TV Service Menu Code
          LG LED TV Service Menu Code
          Videocon LED TV Service Menu Code
          Supra LED TV Service Menu Code
          Toshiba LED TV Service Menu Code
          Symphony LED TV Service Menu Code
          Veste/ LED TV Service Menu Code...
          10-31-2024, 03:58 AM
        • reformatt
          Windows 11 Start menu/Taskbar hanging
          by reformatt
          Couple of Windows 11 machines have come in this week with the same issue. After you login, the taskbar will not appear (or just be a black bar). No access to Start Menu. Task Manager (use CTL+SHIFT+ESC) works, however the Performance stats seem stuck with CPU on 100% for Task Manager itself. Trying to exit Task Manager result in it hanging as well. No issue if you boot into Safe Mode.
          First machine, tried many things to no avail (System Restore from last Windows update, rebooting in Diag mode, trying to reinstall Windows Apps via Powershell). In the end, I did an in-place upgrade...
          04-23-2024, 10:16 PM
        • mnciks11
          Mecer windows Tablet not working proper after reinstalling os
          by mnciks11
          Hello guys
          I have a windows tablet, 2 in one, runs windows, came with windows 10, 32Gb internal space. Uses sim card and wifi too.
          I reinstalled windows 10 on it and never came right after that, touch screen no longer working, doesn't recognise usb when plugged in using OTG , touch pen no longer working on it. I found driver for it but can't install them since it can't read usb after reinstalling or once reached desktop…
          I feel like those machine have their own windows , is there a specific windows for tablet, small devices that uses 32Gb internal...
          02-09-2022, 10:23 PM
        • Sus256
          HISENSE 65E7KQ PRO - no boot
          by Sus256
          Hi all!
          HISENSE 65E7KQ PRO
          RSAG7.820.13512 - chassis
          MT9618BAATAB - cpu
          RSAG7.820.12059 - power
          HD650Y3U77 - panel
          KLM8G1GETF - emmc
          The TV does not turn on, the standby indicator is on. All voltages are present.
          Emms is dead. Not readable, not detected.
          Replaced emmc.
          But with another dump there is no launch
          Terminal log
          UART
          AC_ON
          RPMB key is not yet programmed
          HASH1_VERSION=0x00000000 64bit
          E-B
          FDE enabled
          layout pattern onebin by SAR7,0...
          06-01-2025, 02:11 AM
        • japlytic
          DRIVER_PNP_WATCHDOG error re. old drivers in Windows 11 install image
          by japlytic
          In a Beelink GTR mini PC, mine has an Intel AX200NGW WLAN module.
          Tried (only with keyboard/mouse connected):
          • BIOS + database update
          • Using latest Windows 11 image built with official image creation tool
          • Previous setup version for Windows 11 installer
          • Replacing SSD without a slow block (the previous SSD had a slow block with access time > 500 mS)
          • TPM reset (worked to the point where DRIVER_PNP_WATCHDOG error message is displayed briefly after the point of stalling)
          • Disabling power to WLAN and LAN modules in BIOS (Advanced > AMD PBS > PCI Express Configuration)
          06-19-2025, 04:59 PM
