Stylistic tablet not detecting drives
  • pentium
    • Mar 2006
    • 2778
    I have a Fujitsu Stylistic ST series tablet which is not behaving with hard drives.
    With a drive installed the HDD light will blink when you power the tablet on (it does not do this if no drive is installed), the drive can be heard spinning up and it will blip once again once the POST is complete. However from there you can't boot from the drive. The BIOS also states that no hard disk is present. I tried several drives and reflowed the connector on the drive's ribbon cable (this) and I still can't get a drive to be detected.
    Find Nedry!
    Check the Vending machines!!
    <----Computer says I need more beer.
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    Re: Stylistic tablet not detecting drives
    is it really old? How big is the drive? Have you tried a different one?
    • kaboom
      "Oh, Grouchy!"
      • Jan 2011
      • 2507
      Use a BIOS overlay.
      WD EZ-Drive or similar.
      I've done that on a Compaq LTE5400 dinosaur (max 2.1GB) to use a 20GB HDD. Keep it under 32GB, though. I tried the same with a 40GB and got:
      No overlays, though, if the BIOS doesn't see the drive. With the 5400, the BIOS saw the drive, but I don't remember what the 'reported' capacity was.
      Ahh... FAT/FAT32 and BIOS limitations, makes me feel old.
      "pokemon go... to hell!"
      EOL it...
      All style and no substance.
      guilty,guilty,guilty,guilty!
      guilty of being cheap-made!
      • pentium
        • Mar 2006
        • 2778
        It's a 700mhz Pentium 3 Mobile based tablet. It isn't that old.
        Also, as stated, yes I have tried multiple hard drives The system will spin them up but the BIOS will not detect them.
        Find Nedry!
        • b700029
          Banned
          • Sep 2010
          • 640
          I can't imagine why it'd be useful on a tablet, but is there a BIOS option to disable the IDE controller?
          Also is there the possibility of getting a 'scope or LA on the pins of the drive?
          • pentium
            • Mar 2006
            • 2778
            Actually I have a scope but if I knew what I should be looking for it would be preferred.
            Yes the IDE is enabled.
            Find Nedry!
            • b700029
              Banned
              • Sep 2010
              • 640
              Pinout: http://pinouts.ru/HD/Ata44Internal_pinout.shtml
              You should see some activity on the data lines and the read/write strobes. Getting that would mean it's at least trying to detect the drive and communicate with it.
              • pentium
                • Mar 2006
                • 2778
                Slightly old BuMP but needed to pot some closure on this.
                I got the dock for it (well, not the exact dock but it worked after I chopped off two plastic pegs) and it does not even detect the CD drive in the dock.
                If it can't see the drive and it can't see the CD, chances are the IDE is toast. Damn.
                Find Nedry!
                • federalhouse
                  **Need Help Unlocking BIOS and Hard Drive on Dell Precision 5820 Tower**
                  by federalhouse
                  I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
                  **Background:**
                  I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
                  **What I've Tried So Far:**
                  1. I accessed
                  08-01-2024, 07:03 PM
                • reformatt
                  Intel iMacs, 3rd party SSD failures and Fusion setups
                  by reformatt
                  I thought I'd throw out some of my personal experiences in the last 12 months with Intel iMacs, 2.5" SATA SSD drives and Fusion drive data recoveries.
                  As a backgrounder, Apple never fitted a 2.5" SSD's to these iMacs. Apple's SSD option was a system of 32GB NVMe blade drive (NGFF connector) and Seagate 1TB 2.5" HDD, married together in software to become a Fusion drive. Non Fusion systems have just the 1TB Seagate HDD.
                  So, the most common reason an iMac comes across my bench is because it's either ridiculously slow, or it fails to boot at all. The most...
                  12-18-2024, 10:34 PM
                • mnciks11
                  acer aspire 1 a114 not detecting the drive
                  by mnciks11
                  Hello guys
                  I have an Acer aspire 1 A114 that is not detecting the harddrive at all, the EMMC drive 64Gb sandisk.
                  I have few questions, when replacing this chip so you have to use the same identical EMMC drive , same size, can you downgrade the space to 32Gb, do you have to program the drive maybe? I don't have Much info regarding this topic please assist guys I'll really appreciate
                  I'll replace the drive tomorrow and let you all know but first I need some tips
                  12-09-2022, 12:38 PM
                • perfm2
                  HP EliteBook Folio 1040 G2 won't detect a drive after reformat.
                  by perfm2
                  So I've worked on dozens of HP and Dell laptops and have never encountered this before.
                  Steps taken in my usual process.
                  Reset security settings in the BIOS
                  Ensure existing HD comes up into the OS
                  Shut down the laptop and disconnected the main battery
                  Removed old M2 drive and replaced with a new 1tb Mushkin Temptest NVME drive. (I'm aware the bus is Sata III but the drive should still work at a slower speed right? Been my experience in other laptops)
                  Replace battery connector and close up the laptop
                  Insert my USB drive with my Windows 10 image I've...
                  03-21-2023, 08:45 PM
                  HP EliteBook 840 G5 HC + LaCie Porsche Design USB 3.0 1TB Mobile Drive Notebook 800 Specification for Upgrade or Repair
                  This specification for the HP EliteBook 840 G5 HC + LaCie Porsche Design USB 3.0 1TB Mobile Drive Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G5 HC + LaCie Porsche Design USB 3.0 1TB Mobile Drive boardview and 840 G5 HC + LaCie Porsche Design USB 3.0 1TB Mobile Drive schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from...
                  09-06-2024, 08:50 AM
