I've been wanting for a long time to build a really really power efficient firewall that can offer 100mbps throughput, I've been looking at the VIA EPIA mainboards and there are some really good choices, like this one.
However I am unsure if a 33Mhz PCI solution will be able to offer 100mbps throughput, I think not, I think atleast one of the NIC, prefferably both, must be connected directly into the northbridge, thus avoiding the PCI bus max bandwidth limit of 133mbps throughput...
So I stumbled across Silent PC Reviews latest CPU power efficiency article, and there are some really good choices if you are into underclocking and undervolting the CPU nowdays...
I at first had the opinion that only the VIA CPU's could offer what I want but I mean a Intel Dothan at 14w or a AMD Turion at 18w is quite impressive to me... Of course the Athlon64 at 20w is probably an even better choice, since it should be cheaper and I can still lower it's clockspeed to reduce the power consumption even more...
But there is of course also the possibility of building a Socket 370 system with a Intel Tualatin CPU, or a VIA but then I really think the Mini ITX route is better though, if a "proper" NIC layout is found that is...
So, as you can see I am pretty open to the CPU choice, but what I want now is a nice mainboard to team this system up with, perhaps Tyan has something nice to offer? I don't know that is why I am asking... I have no problems buying second hand items off eBay or anywhere else either...
Preferrably the 2x NIC's should be integrated on the mainboard, both to reduce cost but also power consumption... But I guess a board with a NIC that interfaces with the northbridge directly and then a PCI 66Mhz slot for a second NIC would be a really nice solution too...
It would also be cool to build this into either a Mini ITX chassi or a 1U rackmount chassi, but that is mostly secondary, just for the coolness factor... But in other words if the mobo has a 1U layout that would be simply great!
