Re: Intel 2.0 GHz processor running at about 200Mhz? Help
It's rare but if the heat pipe leaks it's gas out it will lose most of it's heat transfer capabilities.
i dont understand what you mean by reasonable speed
http://www.cpuid.com/softwares/cpu-z.html > Which you probably cant install if its this slow.
Also, might help you to download hiren's boot cd and run the mini xp on there. Is it still sluggish? What about a linux live cd of some sort?Leave a comment:
My thought, however, is that it wouldn't be very useful, since speedstep runs at low speed until the CPU is placed under load. Displaying the BIOS screen shouldn't produce much load on the system. No load means the BIOS setup screen always shows the current speed is the minimum speed.Leave a comment:
yyonline - just FYI - there are BIOS'es that report the current speed. I know the Dell d610's do, and I'm fairly certain there are others as well.
I had a d610 overheat that exhibited these exact symptoms. I didn't expect overheating at first because I didn't hear the fan screaming.... turns out there was a piece of paper that had jammed the fan.Leave a comment:
I meant is it operating at the speed you'd expect it to.
BIOS will display the max speed of the CPU usually. I've never seen a laptop bios that reports the current CPU speed, as it's largely irrelvant in the BIOS screen.
One other thing to check is the power management options. Assuming you're running Windows XP, run the following command in command prompt window:
powercfg /query
This will print out the power management for your system. Look for the Processor Throttle settings. You want to see:
Processor Throttle (AC): Adaptive
Processor Throttle (DC): Adaptive
If you see "Constant" or "Degrade", your power management settings are set to reduce performance.
If you've cleaned and reseated the heatsink, and checked power settings, perhaps the CPU is defective. Panasonic's specs just say P4 Northwood core. Depending on whether you have a P4 or P4-M CPU, they can be found on ebay for $5-10.Leave a comment:
Does the computer operate at reasonable speed? The few cases I have seen of the CPU speed being reduced to 200Mhz, the computer was completely unusable. If it's operating normally, the Intel utility *might* be reporting the speed incorrectly. Try cpuz as has been suggested and see what it says.
the system tasks about 5 - 10 minutes to boot up to desktop, compared to 1 or less than beforeLeave a comment:
If the BIOS is showing normal speed, it might just be a software issue.Leave a comment:
Does the computer operate at reasonable speed? The few cases I have seen of the CPU speed being reduced to 200Mhz, the computer was completely unusable. If it's operating normally, the Intel utility *might* be reporting the speed incorrectly. Try cpuz as has been suggested and see what it says.Leave a comment:
To mirror what yyonline said:
Check the laptop heatpipe vent. Is it clogged with a dust layer? Is air going through? Secondly, replace the thermal paste between the CPU and the heatsink. There's no way the paste they used on that model has stayed viable after all these years. You'll need CPU-grade heatsink paste. I recommend Gelid GC-2.
Thirdly, if you have a desktop model Pentium 4 in your laptop then just buy a new one off eBay and see if that helps. It could be the lithographic pathways have deteriorated on the chip (Again, which is common on Pentium 4), and it is causing the chip to overheat.Leave a comment:
the bios speed indicate the normal speed, and the fans are not running at full speed, they run on working with the system an off doing less work or not using the system.Leave a comment:
Did you check the speed in BIOS? Sometimes, software can misread FSB clock and multiplier values. Also, is the fan running at full speed even on idle load? That could indicate an overheating problem.Leave a comment:
No. But it tells you the CPU model. From there, you can look up the maximum clock speed. Laptop CPUs only work at full power when needed. When idle, they'll reduce to 600Mhz-1Ghz or so depending on the model. A laptop CPU will only go full speed under load. Many newer desktop CPUs work on a similar scheme.
200Mhz indicates a problem, assuming the Intel utility is detecting the speed properly. Try CPU Z and see if you get the same reading.
You say the fans are working and the heatsink is attached properly. Did you check if the heatsink is clogged? Some laptop heatsinks get plugged up pretty easily. I would try reseating the heatsink. Perhaps it's not getting good contact. That means pulling off the heatsink, cleaning it up, and applying a new coating of thermal paste. Now, I have seen a few laptop CPUs that use a gap pad on the CPU. This will appear as a squishy foam or rubber-like pad. These can sometimes disintegrate, shift out of place, or dry out. If it has a pad, it will be too thick of a gap for thermal paste. If that's the case, you may need to order new gap pad from somewhere.
You can also download HWMonitor from the same site as CPU Z. HWMonitor allows for temperature monitoring for most systems. With this you could watch the CPU temperature to see if its overheating, assuming your system has the appropriate temperature monitoring hardware. Then again, if the CPU overheats when loading the OS, it will already be throttled back...in which case the monitoring software won't tell us much.Leave a comment:
does this CPU-Z show expected speed and detected speed?Leave a comment:
the fans are working, the heat sink is tightly connected i just checked. what else culd cause thisLeave a comment:
Yes, it's likely overheating and reducing speed to prevent CPU damage. SpeedStep will reduce the frequency, but not that drastically. When I see this in laptops, the CPU heatsink is either completely plugged with dust or the fan is dead or not connected.Leave a comment:
Your chip is overheating. Intel chips are designed to drastically reduce clockspeed when there's a catastrophic failure in cooling. Maybe the heatsink isn't touching the chip properly.
Also Pentium 4 chips which have failed and cannot run at their full clockspeed without overheating - even when cooled properly - will exhibit this behavior. You see it often in Prescott chips.Leave a comment:
Try CPU-Z instead. It could be SpeedStep... but SpeedStep itself only drops multiplier, gotta be some custom software or BIOS if it's decreasing FSB (seen it on a few laptops).Leave a comment:
Hello guys,
My system Samsung v25 with intel PSU 2.0GHz is running at 200MHz!!!
the FSB speed is 50MHz instead of 200MHz
i have reformatted many times, but no success
i downloaded the intel processor utility to test it from here
any helpTags: None
This specification for the HP Compaq dc7700p Intel Core2 Duo Processor E6300 2x512M/80G DVD-ROM WXP Pro Small Form Factor PC can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq dc7700p Intel Core2 Duo Processor E6300 2x512M/80G DVD-ROM WXP Pro Small Form Factor PC boardview and Compaq dc7700p Intel Core2 Duo Processor E6300 2x512M/80G DVD-ROM WXP Pro Small Form Factor PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will...09-12-2024, 03:36 PM
This specification for the HP Compaq dc7800p Intel Core2 Duo Processor E6750 1G/160G DVD+/-RW WVST Bus Small Form Factor PC can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq dc7800p Intel Core2 Duo Processor E6750 1G/160G DVD+/-RW WVST Bus Small Form Factor PC boardview and Compaq dc7800p Intel Core2 Duo Processor E6750 1G/160G DVD+/-RW WVST Bus Small Form Factor PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be...09-12-2024, 03:30 PM
This specification for the ASUS ZenBook 14 Gun Grey FHD (1920 x 1080) 16:9 Intel Core i5-10210U Processor NVIDIA GeForce MX250 512GB M.2 NVMe PCIe SSD Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 Gun Grey FHD (1920 x 1080) 16:9 Intel Core i5-10210U Processor NVIDIA GeForce MX250 512GB M.2 NVMe PCIe SSD boardview and 14 Gun Grey FHD (1920 x 1080) 16:9 Intel Core i5-10210U Processor NVIDIA GeForce MX250 512GB M.2 NVMe PCIe SSD schematic. Our users have donated over...09-06-2024, 05:30 PM
This specification for the ASUS ASUS E510MA-EJ015TS 15.6" FHD Intel Celeron N4020 Processor 4GB 64G with M365 1 year Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS E510MA-EJ015TS 15.6" FHD Intel Celeron N4020 Processor 4GB 64G with M365 1 year boardview and ASUS E510MA-EJ015TS 15.6" FHD Intel Celeron N4020 Processor 4GB 64G with M365 1 year schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated...09-07-2024, 01:30 AM
This specification for the ASUS ASUS Chromebook CX1400CNA-BV0061 14" HD Intel Celeron N3350 Processor 4GB 64G Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS Chromebook CX1400CNA-BV0061 14" HD Intel Celeron N3350 Processor 4GB 64G boardview and ASUS Chromebook CX1400CNA-BV0061 14" HD Intel Celeron N3350 Processor 4GB 64G schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional...09-06-2024, 11:40 PM
- Loading...
