Intel AX201 (Dell) whitelist?
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Running into an issue with a build. Adding an Intel Ax201 WiFi card to an itx system with an ASrock j3455-itx board (one of the many Topcat's been refurbishing). Bought 2 used cards for cheap off fleabay... Neither show up (PCIe WiFi or USB Bluetooth).
    Both parts of the m2 slot are enabled. But I noticed both have DPNs (Dell part numbers) on the label. I've had issues in the past with Lenovo cards having whitelists (like the laptops themselves)... Has Dell done the same? I used to not have these issues with Dell, but I haven't done a Dell build since Ivy Bridge.
    Anybody able to confirm this? Would like a sanity check before I buy different cards.
    sigpic
    (Insert witty quote here)
  • lti
    • May 2011
    • 2551
    Re: Intel AX201 (Dell) whitelist?
    The AX201 is one of those weird CNVi cards, not regular PCIe. They use the same M.2 slot for some stupid reason, even though they aren't compatible. Then the interface keeps changing between chipsets, so different models of CNVi cards don't interchange.
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      Whoops... You'd think they'd change the slot keying but no...
      Guess I need to read the spec sheets closer next time. Need a model ending in 0, not 1 .
      Edit- I found a couple open box 9650's for 7 a pop shipped. Don't need WiFi-6... Edit2: cancelled order, those are also CNVi too.
      sigpic
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        Found an ax200 for 15... Third time's the charm?
        sigpic
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16956
          You should have said something....got a bin full of USB wifi adapters....
          <--- Badcaps.net Founder
          Badcaps.net Services:
          Motherboard Repair Services
          http://folding.stanford.edu/
          Team : 49813
          Join in!!
          Team Stats
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            I've never had good luck with USB wifi adapters. I thought I mentioned wanting to put a wifi card in it while I was over?
            sigpic
            • Topcat
              The Boss Stooge
              • Oct 2003
              • 16956
              I don't remember....
              I was also going to see if you wanted a husqavara mower....but forgot....and you had your truck too. Aging sucks.
              Team : 49813
              Join in!!
              Team Stats
              • ratdude747
                Black Sheep
                • Nov 2008
                • 17136
                If nothing else I'll be back in September.
                sigpic
