Replacment Options
  • liontiger1974
    • Jul 2010
    Replacment Options
    I needed to find out if a MCZ 1000uf 10v can be replaced with a KZG 1000uf 10v on a motherboard for Gateway 500GR.
    Also, I have to replace a KZG 220uf 6.3v, but cannot find it anywhere. What else can it be replaced with, something close that would work.
    Thank you
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Replacment Options
    MCZ 1000uF 10V here
    https://www.badcaps.net/store/produc...products_id=47
    https://www.badcaps.net/store/produc...products_id=46
    220uF 16V cap here too ...
    https://www.badcaps.net/store/produc...products_id=53
    --- begin sig file ---
    --- end sig file ---
    • liontiger1974
      • Jul 2010
      is it safe to replace MCZ 1000uf 10v with a KZG 1000uf 10v??
      Thank you
      • seanc
        • Nov 2008
        • 1319
        Yes, they are both low ESR and have similar/identical ripple ratings depending on the size you use.
        I would stick with MCZ or something else since KZG do not like hot environments, it depends on where you're putting them really.
        • liontiger1974
          • Jul 2010
          I looked on Badcaps.net but could not find the KZG 220uf 6.3v
          Any idea on where I can find this or if I can use something else to relpace it.
          This is for a Gateway 500GR motherboard.
          Thank you
          • seanc
            • Nov 2008
            • 1319
            The 220uf 16v linked above will work fine.
            • c_hegge
              • Sep 2009
              • 5219
              NEVER use KZG or KZJ in recaps. They are a bad cap.
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                ^^ Agree ^^
                220uF 6.3v is a common cap.
                Using 220uF 10v or 16v is fine if they physically fit.
                - The diameter or height might matter for it to fit.
                The voltage rating on a cap is a max limit.
                Using one with a bit higher limit is fine as long as you don't get silly.
                A 50v cap might be silly depending on who you ask.
                A 63v or 100v cap WOULD be silly. [10+ times higher...]
                Mann-Made Global Warming.
                - Dr Seuss
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  If you need 5mm
                  http://search.digikey.com/scripts/Dk...me=493-1251-ND
                  If you need 6.3mm [the 10v FC is cheaper than the 6.3v]
                  http://search.digikey.com/scripts/Dk...name=P10220-ND
                  - Dr Seuss
