Alternative supplier of SHM ceramic caps.
  • Sussexhandyman
    • Mar 2022
    • 9
    The PSU on my Samsung tv, pt no: BN44-00214A decided to give up the ghost.
    As I'm always trying to repair rather than scrap parts, I'm looking to overhaul the PSU board & have identified most of the capacitors & a MOSFET that need to be replaced.
    I'm stuck for one ceramic safety capacitor, at circuit location CM810. Its a cap made by SHM & the details printed on it are: SHM, X1400, Y1250, B471K.
    Looking at data sheets on SHM website doesn't reveal a traceable component, because its all in Chinese.
    The info on the Samsung schematics for the PSU give the values of this cap as 1KV, 2.2nF.
    Can those more knowledgeable on the forum make recommendations for replacement caps?
    Thanks.
  • Sussexhandyman
    • Mar 2022
    • 9
    Re: Alternative supplier of SHM ceramic caps.
    Have managed to source a replacement for the ceramic safety cap, so my request is redundant.
    Thanks for all the help.
      • 31209
      use 2Kv caps
        by momaka
        03-12-2025, 03:42 PM
      • eryjus
        by eryjus
        05-10-2023, 11:21 AM
      • Paxman_Swede
        by Paxman_Swede
        Hello!
        01-14-2025, 09:51 AM
        Casing Power MPT-301 [PCB ATX9806b-p REV: A3]
        by momaka
        This one should make @Pentium4 smile (if he is still reading BCN forums) – I got a new old stock / open box Casing Power MPT-301 PSU on eBay for $4 total.
        Yes, it’s a very generic-looking box, but the manufacturer isn’t (at least not back in the days), which is…
        Macron Power Technology Co. LTD.
        Let’s look at the PSU itself.
        The shell/case also appears quite generic, like many “sold-with-the-PC-case” units. However, the shell is well-formed and has decent steel thickness. In terms of...
        06-02-2021, 10:05 PM
      • captain150
        by captain150
        03-16-2025, 07:34 PM
