Substitute Capacitor Question
  • sam67
    • 256
    Can anyone tell me what capacitor i can substitute for a 0.1uf 63v cap ?
    I have managed to get other small caps but struggling with this one as i only need 2 so mouser or digikey is a no option with the amount of shipping to uk.
  • Krankshaft
    • Jan 2007
    • 2328
    Re: Substitute Capacitor Question
    It depends on what type of circuit the cap is in. At that value you could probably throw in a bipolar ceramic cap.
    • sam67
      • 256
      Hi Krankshaft,
      It's going in a psu ....i need 2 of them like i said so i can get this psu back up and running .
      • Prolog
        by Prolog
        12-01-2024, 08:27 PM
      • chth96
        by chth96
        06-02-2024, 07:31 PM
      • chth96
        Is it no harm to replace with capacitor without ripple current rating?
        by chth96
        When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
        Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
        But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
        Rubycon YK DataSheet (b...
        04-19-2024, 05:19 AM
      • chth96
        Should I replace polymer capacitor?
        by chth96
        a few days ago I finally purchased mser-100 v2 and I tested its abillity of measuring ESR value.
        I found that It shows pretty accurate ESR value for electrolytic capacitor,But When I measure polymer capacitor of dreamcast game console,I found that one third of polymer capacitor's ESR value is more than twice the value of ESR meter table.(for example, I measured one polymer capacitor of 6.3v 100uf, It showed ESR value of 7.68)
        Although my dreamcast now turns 20 years old but it still works. I occasionally have played game with it.
        Is this ESR value of polymer capacitor correct?...
        11-18-2022, 04:22 AM
      • NuclearSpartan
        Samsung C32HG70 - Blown Ceramic Capacitor (CP813)
        by NuclearSpartan
        I'm new to this, so I apologize for not providing enough details. Is there anything else I need to mention? I'm trying to learn more about electronic/board repairs and hopefully fix my own.
        The only visible issue on my board is one capacitor, CP813, which appears to be labeled R 221k 2kV (possibly obsolete to B 221k 2kV now). My monitor hadn't shown any prior issues, although it is a few years old. Just before the capacitor popped, there was a high-pitched squeal for 2–3 seconds.
        I don't see any other visible damage anywhere else on the board....
        11-14-2024, 02:32 PM
