Toshiba kitchen food processor (model: TFP 1500) Capacitor value ?
  • MikeDD
    • Sep 2021
    • 5
    • New Zealand
    I am repairing an old Toshiba kitchen food processor (model: TFP 1500) with a blown paper wound capacitor. The electric motor is not working so I guess this is a starting capacitor.
    Can anyone interpret the markings, or alternatively suggest a value to try as a replacement?
    The can is about 30mm long and 12mm diameter. It is marked;
    FKC.1+.003x2
    240VAC 9625
    Thanks for any help
    Mike
    PS I have tried Toshiba but not found the right people yet.
    • 31213
    Re: Capacitor value ?
    that's a suppressor also called a delta-cap
    3 wires,
    0.1uf between the 2 lives, and 0.003uf (3nf) between each live and ground.
    is it shorted?
    • MikeDD
      • Sep 2021
      • 5
      • New Zealand
      Re: Toshiba kitchen food processor (model: TFP 1500) Capacitor value ?
      When the machine was disassembled the paper from inside the cap was distributed around the interior space. I only saw 2 wires connected to the cap - the one in the photo and another on the other cap of same or similar diameter.
      Where would the ground wire go?
      Thanks for your help,
      Mike
        • 31213
        if it is a 3wire cap then the "earth" goes to the metal body of the motor
        • PeteS in CA
          • Aug 2005
          • 3581
          • USA, Unsure of Planet
          I don't know if the company still makes the part, but I'm pretty sure the original part was made by Wima, https://www.wima.de/en/ .
          PeteS in CA
            master hoarder
            • May 2008
            • 12175
            • Bulgaria
            Yup, that looks just like an EMI/RFI suppressor cap. 0.1 uF between Live and Neutral, and 0.0033 uF (3.3 nF) between Live-to-Ground and Neutral-to-Ground. So that's where the 3 wires go. In case you can't find an exact replacement: you can build your own arrangement from individual X1/X2 and Y1/Y2 caps. So something like a 0.1 to 0.22 uF cap between Live-to-Neutral and 2x 3.3 nF Y1/Y2 -class cap between Live-to-Ground and Neutral-to-Ground should work fine. Of course, that's assuming you do have the space inside the food processor to place these individual components. As for the motor not working... that may (and likely is) a different issue not related to this bad cap. More pictures/info of the motor and how it's connected would help, though. Generally, start/run caps made for AC motors are quite a bit larger in size. So I don't think we are dealing with such motor or cap here.
              • 31213
              it will work without the cap for test purposes.
              • MikeDD
                • Sep 2021
                • 5
                • New Zealand
                I get the machine today, so will investigate wiring, space and motor further.
                Thanks all.
                • MikeDD
                  • Sep 2021
                  • 5
                  • New Zealand
                  Further investigation shows:
                  - A mechanical safety switch has a fault. Temporarily got it working and the motor runs
                  - the cap aluminium body was held by a bracket on the motor casing which I assume provided the grounding.
                  - All as predicted by momaka & stj
                  - Wima could not identify the cap markings
                  I haven't sourced a replacement cap yet, or the X and Y replacements, but that will come in the next few weeks.
                  Thanks very much all, I've gained new knowledge,
                  Mike
                    master hoarder
                    • May 2008
                    • 12175
                    • Bulgaria
                    Good work.
                    Yeah, those safety switches can fail too, especially if they aren't of high quality. Probably need to get that sorted first before worrying about the X/Y combo cap. Technically, you could just bypass the safety switch and still use the food processor... but clearly this would be a poor idea in most cases, especially if it belongs to someone else.
                    Anyways, keep us updated how it goes. Looks like it should be a fairly straight-forward repair... but with the only catch being if you can find the right replacement parts easily.
                      • 31213
                      if you have to salvage a cap, you find them in vacume cleaners
                        09-06-2024, 05:27 AM
                        09-06-2024, 05:59 AM
                        09-06-2024, 05:33 AM
