solid vs reg caps
  • marcia
    • Nov 2009
    solid vs reg caps
    Replacing 2 caps on a biostar mobo. Can I replace the regular caps with newer solid caps? 1000uf 6.3 volts. How can i tell with no pictures which are reg caps and which are solid caps.
    thanks
    marcia
  • madscientist750
    Replacing electrolytic caps by solid caps on old motherboards
    by madscientist750
    I do have several old pc motherboards which i recapped 10 year ago and some of those caps are bulged now.
    I would like to upgrade them using solid capacitors. I do use them for testing and helping some alternative operating systems.
    I would like to ask if such an upgrade can be done, what should i have in mind when replacing electrolytic by solid caps and if such thing exist, if there are caps list for old motherboards. I would have to figure out what caps needs each motherboard and then prepare a list to try to ask for them on some electronics stores.
    10-19-2025, 06:10 AM
    by momaka
    03-12-2025, 03:42 PM
  • eryjus
    by eryjus
    05-10-2023, 11:21 AM
  • Paxman_Swede
    by Paxman_Swede
    Hello!
    01-14-2025, 09:51 AM
  • captain150
    by captain150
    03-16-2025, 07:34 PM
