Capacitor Identification.
  • tjolle62
    • Sep 2009
    Hello everybody,
    Got myself a bunch of capacitors of Ltec brand in value 100uF - 50V and
    they are satin black with gold markings and so far i know model TK,
    Ok they are pretty small but what i can read on them is TK105 C(M) and then
    a code like 8619D - 8609D - 8522D - 8110D - 8706D - 7D26D - 7N16D this is just an example on the caps,
    Is anyone know if these are date of manufacturing or what ?
    Best Regards,
    tjolle62.
  • MORETTIGIAN
    by MORETTIGIAN
    Title:
    Description:
    Procedure performed:
    - Removed backplate
    - Reapplied thermal compound
    - Reassembled card
    09-18-2025, 12:14 PM
  • pcconnect
    PS5 no power 5V short - capacitor identification
    by pcconnect
    Dead PS5 CFI-1216A, only 12v present on the board EDM-033
    Blown capacitor which is located 'under' HDMI Decoder IC on the other side of the board. Does anyone know what is the value of the capacitor, please? Pics included.
    Thank you...
    08-11-2025, 09:39 AM
  • AleXis6
    Manufacturing Date of Electrolytic capacitor
    by AleXis6
    Guys. could you help me please to decode some codes of main capacitor's producers.
    I would like to know the manufacturing date.
    Based on the information from capacitors I have - it seems easy to decode manufacturing date for Rubycon, Nichicon.
    If I understood correctly:
    1. Nichicons marks date of production as (see the attached pictures) H2116
    I don't understand the meaning of first letter - may be it is code of factory.
    21 -year
    16 week
    I bought this capacitor recently.
    another one-
    2....
    10-11-2021, 02:20 PM
  • eastcoastcomputing
    Capacitor identification
    by eastcoastcomputing
    Hi there,
    Beginner's question, sorry to waste your time...
    I'm not certain of the values for the capacitor highlighted (on the picture with the tape) as I am seeking a replacement. Am I correct, looking at the schematics) to think it is a 33 pico Farad (pf) 25 Volts? The size seems to be 0201 from what I can assess and when I try to source a replacement, I'm struggling to find one and it doesn't look like something common.
    Any help or suggestion welcome. This is on an Asus FX506H Quanta NJJ DANJJMB1AA0 Rev 1A...
    06-04-2025, 05:15 AM
  • Prolog
    by Prolog
    12-01-2024, 08:27 PM
