are there any bad caps on this mobo ?
  • paganic12
    • Sep 2009
    • 17
    Re: are there any bad caps on this mobo ?
    Originally posted by gdement
    I have 2 or 3 of those boards, not working. The caps are all similar to yours, I think yours are original.
    I remember reading about all the problems people have with these boards, it's a pretty troublesome board apparently.
    It's probably a power problem.
    Since it basically runs, I doubt there's anything wrong with the chipset.
    yeah, u know ..it could be very troublesome...it could be anything goes wrong ..
    later on , i would try it with a 300watts psu
      by momaka
      03-12-2025, 03:42 PM
    • eryjus
      by eryjus
      05-10-2023, 11:21 AM
    • Paxman_Swede
      by Paxman_Swede
      Hello!
      01-14-2025, 09:51 AM
    • captain150
      by captain150
      03-16-2025, 07:34 PM
    • Foetuss
      Gigabyte GA-6OXT :: caps question
      by Foetuss
      Good evening
      I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
      Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
      But I was also suprised about the bigger boys, which are 330µF 25V.
      Could it be they used 25V caps because they were cheaper / available at that time?...
      02-11-2025, 12:22 PM
