Best Replacement For Panasonic ECEP2HP152HA
  • KG7AMV
    • 41
    Best Replacement For Obsolete Panasonic ECEP2HP152HA
    1500uf 500V 50 X 105
    Here Is the Data Sheet
    https://cdn.badcaps-static.com/pdfs/...f035321a79.pdf
    CDE Cornell has a 382LX152M500B102VS
    My Personal Blog
  • PeteS in CA
    • Aug 2005
    • 3583
    • USA, Unsure of Planet
    Re: Best Replacement For Panasonic ECEP2HP152HA
    Twist-lock types are closer to general purpose than are the many flavors of low impedance types. 85C rated parts especially. So I'd go for rated voltage and value. If the T-UP series has been obsolete very long, you might find the package size is smaller, and/or in a 105C series. A 105C part might be a nice reliability upgrade. And, for example, a 45mm or 40mm diameter part might improve airflow if what you are repairing is fan cooled (or the convection pattern if convection cooled).
    I would still stick with a good brand, and AFAIK, CDE is a good brand.
    PeteS in CA
    • Jagster
      Panasonic SA-XR25,Looking for a good replacement cap
      by Jagster
      I have a Panasonic SA-XR25 surround receiver that is not working and I believe it may have a faulty capacitor. This large capacitor near the mains power input has a plastic top that is bulged out. Anyhow, I'm trying to find a like replacement but Panasonic doesn't seem to make this capacitor any longer and I want to find a suitable replacement. It has an "AUDIO" designation written which I presume means something important in relation to the capacitors design characteristics. Can someone advise on what would be a good replacement? Image attached.
      The sleeve info:
      10-27-2022, 09:34 PM
    • BigPete
      Panasonic Heatpump Dryer Repair
      by BigPete
      I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
      The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
      In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
      Unfortunately the whole machine has to come apart to fix it.
      I have...
      11-01-2025, 06:40 PM
    • Andre Gilbert
      by Andre Gilbert
      11-20-2024, 08:52 PM
    • Jacksoft
      Panasonic Viera TX-P46G10E 11 blink even after fan replacement
      by Jacksoft
      I have here a Plasma TV TX-P46G10E that before had a problem where it had issues with 11 blinks (FAN SOS) BEFORE starting normally. After that it works for all day long.
      It had some bad cold solder and I remade them all. After I replaced a fan that was half-dead (no RMP signal from the respective pin, but ok with 9V).
      Now the TV power up instantly and works perfect... only without the backplate!
      If the backplate is placed on the TV shutsdown after about 10min and start blinking with the 11 blinks. If I shutdown and re-powerup it starts blinking after a bunch of...
      11-26-2023, 07:22 AM
    • reformatt
      by reformatt
      07-31-2025, 08:37 PM
