Question on finding replacement capacitors
  • mgarcia
    • Jun 2016
    • 8
    Greetings,
    Hoping you all can help me confirm I am looking for the right replacement capacitors. I have an older Vizio 50 inch plasma tv where the screen would go off and on as well as the power. I opened the back and found some of capacitors were bad so figured I would remove and replace them. I've checked on digikey and mouser, but can't seem to find something comparable.
    From what I've read here, I need to make sure the replacement has an ESR equal or lower than the original and the ripple equal or higher. I checked both sites mentioned and can't seem to find something to match up. The capacitors I'm looking to replace are:
    Samwha WB 3300 uf 10v
    Samwha WB 1000 uf 25v
    I can find some with lower ESR, but the ripple is lower than the original one also. I only checked these two sites since they were recommended, im not sure if there are any other sites that might be reputable as well.
    Thank you for any help you can provide!
  • mariushm
    • May 2011
    • 3799
    Re: Question on finding replacement capacitors
    Replace with Panasonic FM or FR series or united chemi con kze or nichicon hw or rubycon zlh / zlj ... if you have room (height) go with the 16v versions of the 3300uF capacitors which may have slightly higher ripper values.
    Same for 1000uF 25v, you may go with 35v rated versions if the diameter and height won't be an issue.
    But I wouldn't worry to much, as long as the ripple value is within a few percentages. These new capacitors are better quality compared to Samwha and you don't know if the circuit even creates so high ripple currents as to get close to the old capacitor's specification.
    • mgarcia
      • Jun 2016
      • 8
      Thank you for the advice. I was at a standstill trying to figure out what to do.
      thank you
      • Behemot
        • 4845
        • CZ
        Most of these series are just SO old, KZE especially has so short endurance, it's pretty much obsolete series compared to todays standard.
        I can supply ya with current models, e.g. KYB, KZN, KZM. In general, you do not really *need* to keep ripple or ESR if you do not go too far from the original values. Most PSUs have wide margins, after all, it was working for years with already failing caps (=they got much higher ESR and lower ripple handling capacity).
        • JohnsonJ
          Allen&Heath XONE92 DJ mixer repair
          by JohnsonJ
          Hello everyone.
          I'm having issues with my DJ mixer, and after taking it apart and checking everything out, it seems that I need to replace 2 rotary potentiometers for the filter, and that the PSU has some caps burned. Hopefully these 2 fixes will solve my issues.
          The potentiometers I will just replace (hopefully the repairman I spoke with will indeed send me the spares, in case he doesn't, I'll update here if we can find a suitable replacement), but for the PSU caps I'd kindly ask you forum members, if anyone could help guide me in the right direction. I'm having difficulty...
          12-12-2020, 11:19 AM
        • TomGJ
          Genelec 8020C Bad capacitor
          by TomGJ
          Hi All, So I have two Genelec 8020Cs that are about 10 years old, one of them stopped switching on. I took it apart, fuse was blown, and I've traced the short to one of the two large capacitors on the circuit board.
          Now from looking at the Capacitors, they seem to be from Samwha's SD Series with the following specs: 3300uf, 35v, 85C, 25 x 16 mm Radial.
          The problem is, I can't find any capacitor from Samwha's SD Datasheet that matches these specs. The closest is 3300uf, 35v, 85c but 31.5 x 16mm, with a max ripple current of 2.5A. I'm guessing the 25mm is custom made for...
          11-02-2024, 07:45 AM
        • quickname
          Cyberpower 1500AVR UPS repair
          by quickname
          I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
          I decided to verify that the batteries were...
          11-12-2023, 09:57 AM
        • dragon3x
          by dragon3x
          power on.
          Here are some examples :
          switching supply area).
          than 6.3 V.)
          03-21-2025, 02:46 PM
        • samoelec
          Trying to understand how to find best replacement cap for old parts.
          by samoelec
          Disclaimer: This is the first time I step into the realm of analog electronics and my natural language is not English, so please forgive me if I failed to use the correct terms when describing things.
          Recently I purchased a Tektronix TDS1012, a 20 years old product for cheap and I thought it could be a nice opportunity for playing (i.e. recapping) and learn something in the process.
          The power supply board is exactly the same from this post so I'll just steal it for now.
          I'm trying to find replacements for all those Lelon electrolytic caps, but then quickly...
          04-01-2024, 03:39 AM
