Rubycon caps
  • Drack
    Yup it's me
    • Nov 2016
    • 297
    • Venezuela
    Rubycon caps
    Hi guys!
    Do you think this are real?
    http://articulo.mercadolibre.com.ve/...uf-x-63v-_JM#D[S:HOME,L:HISTORY-NAVIGATION-BY-CATEGORY-SECOND-LAST-PUBLISHED-2,V:0]
    Drack.
  • Wester547
    • Nov 2011
    • 1268
    • USA.
    Re: Rubycon caps
    Potentially real, but a very old series (datasheet attached). Probably a quaternary ammonium salt series too, so a cap that old has the potential to leak from the bottom. If I'm reading the datecode on that cap right, it has a 1990 (possibly 1991) datecode.
    • Drack
      Yup it's me
      • Nov 2016
      • 297
      • Venezuela
      Re: Rubycon caps
      Danm... Those are old, and for 1.3$ ehhh, not for me
      • petehall347
        • Jan 2015
        • 4435
        Re: Rubycon caps
        might be an old picture ..
        contact them ..
          by momaka
          03-12-2025, 03:42 PM
        • eryjus
          by eryjus
          05-10-2023, 11:21 AM
        • Paxman_Swede
          by Paxman_Swede
          Hello!
          01-14-2025, 09:51 AM
          by momaka
          03-15-2023, 10:17 PM
        • captain150
          by captain150
          03-16-2025, 07:34 PM
