Got My intel OR840 today. Checked all the caps first, all look fine. The main ones around the cpu are small, fat ones. The manufacturers are either OS-con, or Sanyo. No vents on the top of any of them either?
Any of these bad caps?
Tags: None
Re: Any of these bad caps?
Ahhhh...they're solid. NICE!!! I didn't know that, way to go intel and IBM on a job well done on a good board.
How long will it be until Yum Cha Industries starts manufacuring cheap polymers
In that case an ESR meter would be the only way to troubleshoot.Elements of the past and the future combining to make something not quite as good as either.Comment
by eryjusHello,
by Paxman_SwedeHello!
I have studied the board and...-
by captain150I'm trying to repair two old VCRs, they both have bad caps. One has leaky ones, the other would barely run until I subbed in some caps from another power supply I had laying around (though they are the wrong values). This vcr works for an hour or two, but then the power supply starts whining and the picture gets lines in it. I didn't replace all the secondary caps, so another voltage might still be problematic, or the values I used are too far off.
I've been on mouser and digikey but the options are a bit overwhelming. I just need some new ones that will work. They don't need to be top quality,...-
by FoetussGood evening
I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
But I was also suprised about the bigger boys, which are 330µF 25V.
Could it be they used 25V caps because they were cheaper / available at that time?...-
I do have several old pc motherboards which i recapped 10 year ago and some of those caps are bulged now.
I would like to upgrade them using solid capacitors. I do use them for testing and helping some alternative operating systems.
I would like to ask if such an upgrade can be done, what should i have in mind when replacing electrolytic by solid caps and if such thing exist, if there are caps list for old motherboards. I would have to figure out what caps needs each motherboard and then prepare a list to try to ask for them on some electronics stores.-
- Loading...
