Is it ok to replace Rubycon MCZ with MBZ? Same specs...
  • powrslave007
    • Sep 2008
    I accidently ordered a 6.3v 820uf Rubycon BMZ capacitor to replace a 6.3v 820uf Rubycon MCZ - is it ok to use the BMZ? What is the difference between the two?
    Sorry is this is a newbie question - I did make an effort to read through all of the related FAQs. Thanks for your help..
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Is it ok to replace Rubycon MCZ with MBZ? Same specs...
    One has to be a newbie to become an oldbie.
    95+% chance it won't be a problem.
    What is it going into? (or is that on?)
    Mann-Made Global Warming.
    - Dr Seuss
    • powrslave007
      • Sep 2008
      An Intel motherboard - (E210882) - D865GBF/D865Sperc chipset. It comes out of a whitebox PC.
      Good chance it won't be a problem? Good news! Thanks for your help.
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        MBZ should be fine.
        If you have Nichicon HN or HM series on that with 2002, 2003, or 2004 date codes you should replace those too.
        There were some bad batches of those and Intel ended up with some of them.
        I know that board is one of the affected models.
        - Dr Seuss
        • Newbie2
          • Sep 2005
          • 885
          Rubycon MBZ are one of the best aluminum electrolytic capacitors for motherboard use.
          My gaming PC:
          AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
          ASUS M4A77TD AMD 770 AM3 Motherboard
          PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
          G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
          TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
          WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
          ASUS Xonar DG 5.1 Channel PCI sound card
          Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
          Antec Three Hundred Mid-Tower Case
          Microsoft Windows 10 Pro 64-bit
          Microsoft Windows 7 Ultimate SP1 64-bit
          • bgavin
            • Jan 2007
            • 1355
            I stock both MBZ and MCZ, and regularly use MBZ when I cannot obtain the MCZ.
            I guess you could look at the MBZ as the Gold Standard, and the MCZ as the Platinum Standard. Both are very high quality components.
            • spike93
              Xbox 360 parallel caps
              by spike93
              I'm probably going to ask a very noob question but after many readings and videos I'm still unsure on the answer.
              I've broken one of the caps around the gpu of an xbox 360 by overheating it. In the forum I've found this thread where the user had exactly my situation (same console version and same broken caps): https://www.badcaps.net/forum/showthread.php?t=24983
              The difference is that I've broken only one of the Rubycon caps (or at least that's what I can tell from a visual inspection). Now I'm planning to use a solid capacitor as replacement,...
              02-18-2023, 10:45 AM
            • quickname
              Cyberpower 1500AVR UPS repair
              by quickname
              I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
              I decided to verify that the batteries were...
              11-12-2023, 09:57 AM
            • P4C800
              ASUS P5A and P2B-S recapping. Searching old datasheets.
              by P4C800
              I'd like to recap some of my old mainboards (they are from 1998) before switching them on again for the first time after many years in storage. All caps still look good from the outside.
              There are three mainboards:
              - ASUS P5A rev 1.04
              - ASUS P2B-S rev 1.03 "Rubycon"
              - ASUS P2B-S rev 1.03 "Chemi-Con"
              If you are interested in their specs, The Retro Web has pages for the P5A and the P2B-S.
              They all have many 1000uF 6.3V 105°C capacitors. But there are some differences I cannot figure out.
              P5A
              10-09-2023, 05:55 AM
            • yuuki47
              ASUS P5KPL-AM.I bought caps with a big tolerance rate
              by yuuki47
              I have an ASUS P5KPL-AM board with swollen and leaky capacitors. Amazingly, it still works, but I'm guessing it won't be long before it doesn't so I'm looking to replace the capacitors. All that electrolyte is probably not good for the traces too.
              Anyway. Every cap on that board that is 820uf 6.3v is swollen, so that issue is isolated to those specific caps. They're TK AWTY caps. Never heard of them but I suppose they're bad quality.
              To replace them, I bought Rubycon ZLH capacitors with the exact same 820uf 6.3v spec. But when I went to test...
              05-20-2023, 01:14 PM
            • crosswinds
              Assistance with identifying replacement caps on ASUS P5VDZ-MX
              by crosswinds
              So, pulled a motherboard out from storage, was working when put away, wont post when I took it out of storage today.
              Since it was working, and it looks to be essentially time that killed it I figured its a good idea to replace the caps before digging further.
              Looks to be only good quality caps on this board, so might not be the issue. But it is closing in on 20 years now so, wont hurt i guess
              Its a ASUS P5VDZ-MX board.
              I would really appreciate some assistance on what the best replacement caps would be for these:
              Panasonic(M)...
              04-17-2024, 04:25 PM
