Jee caps
  • nick122
    • Jul 2016
    • 109
    • Slovenia
    Jee caps
    I've just pulled a slightly bulging jee cap from a psu. Its esr was 160! Whats's the biggest esr ever measured here on badcaps.net?
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Jee caps
    My peak meter only goes to 40ohms no higher just says its failed lol
    • ChaosLegionnaire
      HC Overclocker
      • Jul 2012
      • 3264
      • Singapore
      Re: Jee caps
      someone mentioned a bad kzg cap reading 2000 ohms esr? lol but i imagine some completely burst open junk caps can even read open circuit or infinite resistance lol
      • Wester547
        • Nov 2011
        • 1268
        • USA.
        Re: Jee caps
        ^ I don't recall that. I said in another thread that UCC specified a 5x11 0.1uF 50V SMG as having a maximum acceptable ESR of almost 2,000Ω ESR (at 20˚C and 120Hz) in the datasheet (which is ludicrous - it may as well be a resistor at that point). Highest recorded ESR of a failed KZG is 100Ω by PlainBill.
        A capacitor that is open circuit would indeed have infinite resistance, suggesting the liquid electrolyte has completely dried up. A capacitor that is shorted (zero resistance) suggests great damage to the dielectric. A capacitor that reads fine for ESR but not capacitance denotes that the surface area of the aluminum oxide or foil has shrunken over time. It's a common failure mode for those capacitors based on organic solvents such as Ethylene Glycol or even γ-Butyrolactone. And it's probably why certain Rubycon series have a tendency to go out of spec in terms of capacitance as they age.
        Jee has always been some of the worst bottom-of-the-barrel junk. No surprise one reads 160Ω. Some capacitors do fail to such an extent that no ESR or capacitance meter will give you a reading.
        • mockingbird
          • Dec 2008
          • 5484
          Re: Jee caps
          Wester547 - what is the method of fatigue for a capacitor which tests within spec capacitance and ESR-wise, but has a high leakage current?
          • Wester547
            • Nov 2011
            • 1268
            • USA.
            Re: Jee caps
            High leakage current = dramatically damaged or thinned oxide layer. That's why leakage current increases as capacitors sit in storage with no voltage across their plates (the oxide layer slowly dissolves into the solution until the capacitor is reformed and rebuilds the layer).
            • TechGeek
              Computer Geek
              • Jan 2015
              • 2254
              Re: Jee caps
              jeez... these caps.
              Permanently Retired Systems:
              Kooky and Kool Systems
              sigpic
                by momaka
                03-12-2025, 03:42 PM
              • eryjus
                by eryjus
                05-10-2023, 11:21 AM
              • Paxman_Swede
                by Paxman_Swede
                Hello!
                01-14-2025, 09:51 AM
                Casing Power MPT-301 [PCB ATX9806b-p REV: A3]
                by momaka
                This one should make @Pentium4 smile (if he is still reading BCN forums) – I got a new old stock / open box Casing Power MPT-301 PSU on eBay for $4 total.
                Yes, it’s a very generic-looking box, but the manufacturer isn’t (at least not back in the days), which is…
                Macron Power Technology Co. LTD.
                Let’s look at the PSU itself.
                The shell/case also appears quite generic, like many “sold-with-the-PC-case” units. However, the shell is well-formed and has decent steel thickness. In terms of...
                06-02-2021, 10:05 PM
              • captain150
                by captain150
                03-16-2025, 07:34 PM
