I'm looking for some ultra low ESR replacements for an 8mm 1200uf 6.3v for my motherboard. all my search results keep turning up is cap plague era Rubycon MCZ. Any suggestions? or did the mcz's miss the plague for the most part? Is the ULTRA LOW ESR always labeled at the top, if it is ultra low esr, of the cap datasheets, or is there another way to tell?
ultra low esr replacements 1200uf
Tags: None
Re: ultra low esr replacements 1200uf
Rubycon MCZ was not affected by the plague. They will be fine.<--- Badcaps.net Founder
Badcaps.net Services:
Motherboard Repair Services
http://folding.stanford.edu/
Team : 49813
Join in!!
Team Stats -
new rubycons don't die on the shelf....so they should be fine. If they're in the board, you'll know it if they're bad....they'll be bloated and leaking crud all over the place. Heat kills.<--- Badcaps.net Founder
Team : 49813
Join in!!
Team StatsComment
cool, so i should be good to go for my k8s-la motherboard now! i'm using:
1200uf 6.3v rubycon mcz
1500uf 6.3v nichicon hz
820uf 6.3v nichicon hn
does that sound decent for the board and ultra low ESR capacitors?Comment
Yup, all are of the ultra-low ESR persuasion. You'll be fine....unless ofcourse you bought them off ebay, and they're fakes...<--- Badcaps.net Founder
Team : 49813
Join in!!
Team StatsComment
which newer United Chemicons series are ultra low ESR? i am replacing old cap plague Nippon KZG ones, (same company) by the way. Is Chemicon considered reliable now days?Comment
KZG and KZJ were the only series of UCC that were really known to be problematic....and as far as I know, their only ultra-low water-based series.<--- Badcaps.net Founder
Team : 49813
Join in!!
Team StatsComment
I think they are most commonly found as 4V, 820 uF caps around the CPU on socket 775 motherboards. My Asus P5GC-MX had them (along with KZGs everywhere else).
KZG is by far the worst though. The will bulge even on the shelf. In fact, they are more likely to bulge due to not being used due to unstable electrolyte.
Originally posted by halaster79cool, so i should be good to go for my k8s-la motherboard now! i'm using:
Just make sure the Nichicon HN/HZ caps have post-2004 date codes (i.e. H05xx, H06xx, H07xx, A05xx, A06xx, A07xx, etc.). Otherwise, you could be putting bad caps back into your system.
And as TC said, it's probably better to *avoid* eBay for high-quality e-lytic caps.Comment
Sure.
Just make sure the Nichicon HN/HZ caps have post-2004 date codes (i.e. H05xx, H06xx, H07xx, A05xx, A06xx, A07xx, etc.). Otherwise, you could be putting bad caps back into your system.Last edited by Wester547; 08-09-2016, 08:31 PM.Comment
2005 is mostly okay in my experience, especially the 16V caps. I've re-used a ton of Xbox 360 caps - particularly the 6.3V 2200 uF HZ and 16V 1500 uF HN. Of those, I've had only a handful (maybe 2 or 3 total) of the 6.3V 2200 uF HZ with H05 datecodes bulge in storage. So yes, even the 2005 HN and HZ are not perfect, but they are far from being as bad as the very failure-prone 2001-2004 HM and HN.
Most of my 6.3V 2200 uF HZ appear to be okay so far and successfully passed my reforming process as well as the ESR/capacity check. Some of the H05 caps did appear to "loose" charge a bit faster than their H06 siblings, but nothing alarming. I pulled some of them as far back as spring/summer 2012 and had them in storage since. No problems whatsoever with that.Last edited by momaka; 08-09-2016, 08:26 PM.Comment
Also, as an addendum, I've seen many late 2001 and early 2002 datecoded 1800uF 16V and 1000uF 16V HMs (and KZGs too) on the VRM input of the CPU buck regulator on Dell Dimension 4300/Optiplex GX240/GX260 motherboards do just fine where all the 6.3V capacitors were always bad. That's why I cast skepticism upon HMs, HNs, and HZs with 2005 datecodes.
And even 1500uF 16V KZJs do just fine on those Xbox 360 motherboards, so the HNs doing fine doesn't say much.Last edited by Wester547; 08-09-2016, 08:47 PM.Comment
1200uf 6.3v rubycon mcz from 2005
1500uf 6.3v nichicon hz 2014
820uf 6.3v nichicon hn 2012
does that seem legit?Comment
why is suncon so hard to find on online websites? Especially ME-WG series? My current hp computer has suncons, and they don't seem to have any problems yet.Last edited by halaster79; 08-10-2016, 01:55 PM.Comment
is dementtech on ebay known to be crooked? i do buy lots from digi-key and mouser thoughLast edited by halaster79; 08-10-2016, 02:12 PM.Comment
Also, I'm pretty sure momaka meant 680uF 4V TMVs and not 820uF. Although 820uF 4V polymers are readily found by either Chemi-con, Fujitsu, or Sanyo on old Xbox 360 Xenon motherboards in the GPU VRM output. I also want to clarify that I don't think all 2005 HMs / HNs / HZs are crap even if I don't fully trust them. For an example, you'd be hard pressed to find an 1800uF 16V Nichicon HN (2003 datecodes) that hadn't blown on the VRM input of Dell Optiplex GX270 motherboards, but I too haven't seen a blown 1500uF 16V Nichicon HN with 2005 datecodes except on those 360 motherboards that were "oven" tricked.
I would not risk anyone on eBay. Not even egecku, who has also been known to sell counterfeit capacitors.Last edited by Wester547; 08-10-2016, 02:27 PM.Comment
i like Rubycon, Nichicon, Suncon, and Panasonic, at this point I'm not a fan of chemi-conComment
cap forgers luv faking suncon/sanyo caps for some reason. be very careful where u get them from if buying sanyo or suncon caps.Comment
I've seen many 2200uF 6.3V and 1000uF 10V early-mid 2005 date coded HNs at least on Dell Dimension 3000, 4700, 8400, GC068, and PowerEdge SC420 motherboards (along with Intel D925 series motherboards) pop for no reason (in the same places that KZJ would pop, with the same frequency) where the MCZs were just fine.
That said, you're still right that this doesn't say much. But overall, I've seen many more failed KZJ than HN with 2005 datecode.
Always glad to have you as my personal spell-checker. If I don't get the series wrong, I'll get the capacity wrong.
Yes, 680 uF is correct.
+1Last edited by momaka; 08-12-2016, 03:35 PM.Comment
Well, I have about 10-15 or so 16V 1500 uF KZJ caps. Of those, 3 bulged in storage. I also have about 40 or so same size and capacity (16V 1500 uF) Nichicon HN caps, of which about 1/2 to 1/3 are with 2005 date codes. From these, I had 0 (zero) bulge in storage or test bad.
I also recently found a bunch of 1500uF 16V Sanyo/Suncon WFs from Xbox 360 Falcon and Jasper motherboards that bulged in storage (they were not desoldered). So yeah, KZJs and WFs are bad news even in the VRM input of Xbox 360 motherboards. Late 2005+ HNs, MCZs, and FLs should be fine though (they don't die in storage AFAIK). What were the date codes on those KZJs that bulged in storage?
You know, my signature and slogan should be (and I'm surprised no one has called me out for this more often): "Classic Wester547... staying on-topic with a SINGLE sentence!"
This specification for the LG Gram Ultra-Lightweight Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-Lightweight boardview and Ultra-Lightweight schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...09-07-2024, 03:40 AM
This specification for the LG Gram Ultra-light Weight Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-light Weight boardview and Ultra-light Weight schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...09-07-2024, 03:40 AM
This specification for the LG Gram Ultra-Light Laptop Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-Light Laptop boardview and Ultra-Light Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...09-06-2024, 09:10 PM
- Loading...
