Onkyo TX-NR807
  • Nadar
    • Mar 2016
    • 15
    • Norway
    Onkyo TX-NR807
    Onkyo receivers are infamous for bad caps on the HDMI board. This is my second Onkyo where this has happened in just a few years, and I've been aware of the issue for a while now (as it has taken several attempts to get it to work for a while). The reason I'm writing this is because I haven't really considered the problem to be anything else, even though theoretically it could be.
    I'm confident enough that bad caps are to blame to just replace them as the first course of action.
    A short description of the issue: For a while (some months) it's been difficult to switch input source, or to get the input source relays to "click in" when turning the receiver on. I've had to do it up to 4 or 5 times before it would actually work. In addition to that, the DLNA client on the card (a tiny embedded Linux) have been generally unstable freezing and rebooting a lot in the same periode - to the extent that the DLNA client hasn't really been usable. Even if I got it to start playing some media, it would usually freeze or reboot within the first minute.
    The issue is isolated to the HDMI board, analog audio is still working. It doesn't help me much though, since all my sources are HDMI. It's also the HDMI board that has the bad caps issue for some reason, so I'm guessing Onkyo buys them from another place. These cards are very hard to come by second hand (since the failure rate is veery high within 5 years or so), is out of production and are quire expensive even if they were still for sale, so a repair is pretty much the only viable solution.
    I've removed the board, taken pictures and notes of the instriptions on the electrolytes. I've had a different model Onkyo with the same problem before that I managed to find a description of which capasitors to replace and with what online. I haven't been as fortunate this time around though, and I have no idea which one(s) are bad. All caps are surface mounted, and some are quite small and in tricky places so I'm a bit worried about soldering in some of them without making it a disaster zone, but unless someone here has some more insight as to which ones are the likely culprits I'll just have to change them all.
    There are quite a few different types, and I'm not sure what the all inscriptions mean. They all have "3 lines" of text. The first line usually has a letter followed by a digit with a horizontal line printed on top. I'm assuming that's some kind of tolerance/quality value. The second line is just a number, I'm assuming it's the capacitance but there are no letters indicating kilo, micro, nano etc behind the numbers so I'm unsure how to interpret this. The last line seems to be the rated voltage as it ends with a "V" on most of them, but not all.
    My complete list is:
    • a1 100 16V (2 pieces)
    • E3 10 16V (2 pieces)
    • E 22 4 (8 pieces)
    • E4 220 4V (10 pieces)
    • E3P 470 10V (4 pieces)
    • E2 220E CD (4 pieces)
    • F1 100 4V (4 pieces)
    • E3 4.7 50V (1 pieces)
    • Z3 100 16V (2 pieces)
    • C4 220 10V (1 piece)
    Some are very small with weak print so I can't be 100% sure I've read correctly, but I think I got it right. I first and foremost need help assuring that I have "sane" values.
    There's also quite a few caps there, and I'm expecting most of them to be ok (even if they all seem to be of the same manufacturer which means that's probably just a matter of time). I'm worried that replacing all those can become quite costly and increase the chance for a soldier mistake by me quite a lot, so any input about what's the best course of action is appreciated.
    I'm appending the service manual if anyone should be interested in looking at that. The card is called U005 HDMI CIRCUIT PC BOARD (BAHDM-0132-1B) in the service manual.
  • mmartell
    • Oct 2013
    • 3189
    Re: Onkyo TX-NR807
    Put it all back together carefully and send it back to Onkyo. This is a known problem (not caps) and they will repair free under extended warranty with no cost to you.
    • mmartell
      • Oct 2013
      • 3189
      Re: Onkyo TX-NR807
      I should back up a bit... when the second relay doesn't click you probably don't have the speaker icons, right ? Also the network problems are another sign of this problem. The problem is the DSP ic - heat it up with a hair dryer good and hot then fire it up it will probably come on and work properly.
      • mmartell
        • Oct 2013
        • 3189
        Re: Onkyo TX-NR807
        Try here..
        https://repair.onkyousa.com/eu/
        ..and good luck.
        • Nadar
          • Mar 2016
          • 15
          • Norway
          Re: Onkyo TX-NR807
          Thank you for reminding me about this, when you say it I'd read about this a time ago but forgotten about it. I didn't interpret the hanging/rebooting of the DLNA client as "loss of network connectivity" either, but I guess that's one way to see it.
          Unfortunately I'm from Norway and Norway isn't listed in the list. I'll have to try to contact the distributor manually.
          I'd already put it back together so I won't do the hairdryer test - I just opened it to take pictures and note the values and put it back together. It certainly looks like the case covered by the extended waranty by its sympthoms.
          Thank you for putting me on the correct path
          • mmartell
            • Oct 2013
            • 3189
            Re: Onkyo TX-NR807
            No worries and good luck.
            • Nadar
              • Mar 2016
              • 15
              • Norway
              Re: Onkyo TX-NR807
              You were indeed right and although this has taken almost 2 months, I now have my Onkyo up and working again after being repaired under the extended warrany.
              • MotherTeresa
                Onkyo TX-NR5007 (NR3007 NR1007) NAND DUMP for DZKB4 DSP
                by MotherTeresa
                Hi.
                I'm looking for a DSP NAND DUMP for the Onkyo TX-NR5007 that works with the DZKB4 chip. Can anyone help?
                Regards.
                09-20-2025, 12:09 PM
              • CDNBrewer
                Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
                by CDNBrewer
                Hello Everyone,
                I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
                Symptoms:
                • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
                • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
                • I swapped the Left and Right surround
                08-05-2025, 09:29 PM
              • FrancescoV
                Onkyo HT-R390 no sound output, video output ok
                by FrancescoV
                Good morning everyone,
                I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
                The firmware reported is the following:
                M:1.00/11107BLP
                D:?.??/????????
                O:1.00/11107AL
                The DSP firmware given the question marks seems corrupt.
                On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
                05-11-2025, 02:59 AM
              • Sisko
                Onkyo-593 No power and now clicking sound
                by Sisko
                Hi all!!
                Ok just got a Onkyo SKW-593 sub woofer that has no power person told me that it smoked and that his GF let the volume full when she powered off the amp and when he came to turn it on the sub played but then suddenly smoke was coming out, didn't say from where. So opened it up and saw a resistor made of metal (pic) but can't see any writing on metal par so what ever was written on it was burnt. So I'm kinda stuck here with this. I did ask for a repair or schematics in the other group section and waiting for this but I hope someone here might lend me a hand to try and identify...
                10-03-2025, 02:18 PM
              • tranquility
                Onkyo TX-NR809 – no hdmi, DTS or NAND chip ? stuck at starting kernel
                by tranquility
                i want to repair an Onkyo TX-NR809 receiver.
                symptoms:
                on power on, display appears and i hear one click. enue functions is given.
                - no hdmi output
                - audio output not tested, but i think it is not there
                - usb sticks are not recognized
                if i read out the chips with display+standby button + tone+
                both dts show only ????
                chip is D830K013BZKB4
                things i have done:
                - reflow of the dts chip without taking off and reballing
                - changed the aluminium caps without the big one with 25v because i dont...
                08-25-2025, 01:04 AM
