Dying Rubycon MHZ?
  • smiggy
    • Nov 2007
    Dying Rubycon MHZ?
    Rubycon MHZ series
    10v 2200uf
    This is an Intel D865GLC board with the usual failure of all the Nichicon HN(M) series caps.
    There is one Rubycon which looks a bit out of place. Is this a possible failure, or is it a feature produced during manufacture? The top isn't exactly bulging - could something pushing down really hard on it make that kind of feature? There has never been anything pushing down on the cap in the case.
    I don't have an ESR meter, but I do have an old (but decent?) Tektronix THM565.
    (bigger pic here)
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Dying Rubycon MHZ?
    It looks like someone dropped a heat sink or something on it when they were working on the system.
    In other words it's called a "dent". ... LOL
    Not bad enough to worry about.
    Mann-Made Global Warming.
    - Dr Seuss
    • kikkoman
      • Jul 2007
      • 691
      that's no normal dent.
      if you look closely, the groove is always on the same 'arm' of the K vent.
      maybe a production fault?
      "Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin slitting throats." - H.L. Mencken
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        It looks like 3 pictures of the same cap from here.
        Orientation of the K stamp and the sleeve is exactly the same.
        Could be whoever was doing assembly was using some machine wrong and popped out a batch of dented caps.
        Still not bad enough to affect anything.
        - Dr Seuss
        • smiggy
          • Nov 2007
          Thanks guys Rubycon MB/CZ are hard to find, so lucky I don't need any
          Taa.
          (PS. yes, just the one cap)
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            Orientation of the coil next to the cap as well.
            I think it's one cap 3 times.
            - Dr Seuss
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              I have an FC on an old Intel P2 board that dented far worse than that from a heatsink-cap collision (fender bender?) incident before I got it.
              Never had a problem with it and it ran for years before it was,, um,, parked?
              - Dr Seuss
              • Topcat
                The Boss Stooge
                • Oct 2003
                • 16958
                That cap has just sustained some damage. If it came out of the factory like that, it doesn't say much for the board maker's quality control, as that would be an easy detection. Most likely, it was sustained in shipping or by poor handling.
                <--- Badcaps.net Founder
                Badcaps.net Services:
                Motherboard Repair Services
                http://folding.stanford.edu/
                Team : 49813
                Join in!!
                Team Stats
                • puccovelli
                  Dell 9310 Memory or RAM (Random-Access Memory) failure (2,4)
                  by puccovelli
                  Hi all, I hope this is the right place to post.
                  I'm having a problem with a Dell 9310 which is posting 2 orange, 4 white lights on startup (hangs on Dell BIOS logo). The service manual says its a RAM failure.
                  I've taken the motherboard out and noticed that one of what looks like an SMA 0805 resistor has blown (see photo). The board is an LA-J144P Rev 2.0(A01).
                  1] Could someone confirm what the component that has blow actually is (and where I could get another from).
                  2] Whether this component is likely to cause the RAM failure issue, and if replacing...
                  Yesterday, 06:30 AM
                • Sus256
                  HISENSE 65E7KQ PRO - no boot
                  by Sus256
                  Hi all!
                  HISENSE 65E7KQ PRO
                  RSAG7.820.13512 - chassis
                  MT9618BAATAB - cpu
                  RSAG7.820.12059 - power
                  HD650Y3U77 - panel
                  KLM8G1GETF - emmc
                  Replaced emmc.
                  Terminal log
                  UART
                  AC_ON
                  E-B
                  FDE enabled
                  06-01-2025, 02:11 AM
                • howardc64
                  by howardc64
                  07-24-2025, 05:17 PM
                • max_smart
                  T430 laptop doesn't power on- please help me troubleshoot w/multimeter (fixing for fun)
                  by max_smart
                  First off, this forum really helped me out by advising me to cut some ribbon connectors to the LCD panel in order to fix a 70" TV (lots of threads on Sharp TVs with this issue). I didn't believe that it could work, but it did.
                  Now I've been encouraged to try to diagnose something quite a bit more complicated. That is an old T430 motherboard. I work on a college campus so I have access to pretty decent tools. I found the schematic for the motherboard on the site, and have been following traces and taking DC measurements from things. I also don't mind...
                  06-01-2024, 03:27 PM
                • ctroxtell
                  Carrier HK50AA063 display controller common failure help
                  by ctroxtell
                  I've got a control display for a Carrier chiller that I'm trying to understand what the common failure with these boards are. This is the board in question https://www.supplyhouse.com/Carrier-...arquee-Display all of them seem to develop a failure with the up and down arrow buttons on the right side of the display, the esc and enter keys I've never seen fail. Once these boards are plugged in they run 24/7, you used to have to press extremely hard with the end of the blunt screwdriver and you could still get the arrows to work but now it has completely stopped working. The button...
                  02-05-2025, 05:31 PM
