Need advice in finding low impedance repalcement capacitor
  • fun148
    • Feb 2015
    • 38
    • canada
    I am trying to fix a no picture problem with my Samsung HL61A750 DLP TV, and I am having difficulty in finding the right capacitor to replace the one below. It is bulging on the top, so I am pretty sure that it is bad. It is used in the sub power supply BP96-01726B PCB:
    SAMHWA WL – extremely low impedance series
    100uf 450V Impedance = 0.71 Ohm Ripple Current = 1200 mA @105C
    Cap Dimension 18x35.5
    Lead spacing 7.5 mm
    Copper dia. 0.8 mm
    Datasheet link:
    Please help. Thanks.
  • Jooo
    • Oct 2011
    • 222
    • Finland
    Re: Need advice in finding low impedance repalcement capacitor
    If you want a high reliability replacement I would go for NCC KXG series. The ESR doesn't really matter there.
    If could take picture of the capacitor in question, we could check it and give you another opinion about the state of the cap. It may not be bad.
    Of course, the only certain way of knowing if it is good or not, is using ESR meter.
    • fun148
      • Feb 2015
      • 38
      • canada
      Thanks so much, Jooo. I am sorry that I do not have a decent digital camera to take a photo of my cap, but it has a very obvious bulge on top. In any case, I want to replace it along with the other caps to be on the safe side.
      One last question if you do not mind, what do you think about Nichicon CY series as compared to NCC KXG series that you have suggested?
      Thanks for your input.
      • Agent24
        I see dead caps
        • Oct 2007
        • 4977
        • New Zealand
        CY looks nice but the datasheet says 100uF 450v is only 835mA RCR. Might be a problem.
        -David VanHorn
        • fun148
          • Feb 2015
          • 38
          • canada
          Thanks Agent24.
          Since Jooo was saying that “The ESR doesn't really matter there.”, I have been concentrating in finding a cap with the same or higher ripple current value.
          For 100uF 450V, the ripple current data are (all @105C):
          The original Samwha HL series is listed as 1200 mA (frequency not listed in the table for caps above 100V, but for smaller voltage ones, the frequency is 100kHz, so I assume the same for 450V)
          Datasheet:
          Jooo's suggestion of NCC KXG series is listed as 800 mA @120Hz and 1,800 mA@100kHz
          Datasheet:
          The Nichicon CY series is listed as 836 mA@120Hz
          Datasheet:
          I have maken the following assumptions. Correct me if I am wrong, as I am a newbie in electronics. Thanks.
          First, I make the assumption that the original WL cap is tested @100kHz.
          Second, from the datasheet of KXG, I have noticed that the ripple current jumped at least double when testing frequency changed from 120Hz to 100kHz (800 mA @120Hz to 1,800 mA@100kHz), so I assume that the CY series ripple current will be at least 2 times of 836 mA = 1672 mA @100kHz. Since @120Hz, the ripple current value of CY is higher than KXG, so I assume @100kHz CY's value is higher than 1,800 mA too.
          Based on the above assumptions and from the datasheets:
          - CY has a higher ripple current than KXG (836 mA @120Hz VS 800 mA @120Hz)
          - CY has a higher load life than KXG (10000-12000 vs 8,000- 10000 hrs)
          The things that I have no idea are:
          - Is CY as good as KXG in term of reliability (which brand of cap is better) ?
          - KXG is listed as “non solvent resistant type”, is CY the same type? And does that make any different?
          Thanks for your input and time.
          • Agent24
            I see dead caps
            • Oct 2007
            • 4977
            • New Zealand
            Good catch. Yes, the different frequency will make a difference. CY datasheet says to double the RCR when going from 120Hz as measured to 100kHz. So yeah, that one would be fine (On paper).
            I haven't heard of CY before, KXG is known good but probably either one will work fine. In any case, both are surely better than a Samwha.
            The non-solvent resistance means you can't wash the board with solvents to clean flux off afterwards, but since you're not a factory and you're not running the entire board through a wash cycle, it doesn't matter.
            -David VanHorn
            • fun148
              • Feb 2015
              • 38
              • canada
              Thanks Agent24. I now can order the capacitors and see if my TV can be saved.
              • Prolog
                RTX 3080 FE Identifying capacitor
                by Prolog
                Hi people, I hope this is the correct spot to post this, I'm new to the forum.
                I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
                I hope these photos make it clear which component I am referring to:
                (yes, the soldering is a bit botched from removing the blown one, I know)
                I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
                12-01-2024, 08:27 PM
              • chth96
                If I replace with inferior capacitor, Is it No harm to other IC components at all?
                by chth96
                I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
                Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
                It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
                So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
                I know that these capacitor will not last as long as nichicon capacitor...
                12-22-2023, 04:34 AM
              • chth96
                How can I test non-polarized capacitor?
                by chth96
                I desoldered samwha NF capacitor(50v 5.6uf) from PCB circuit of 29inch CRT TV which have symptoms of no display after I heard sound of inrush of current to TV whenever I switch on this television.
                I measured ESR value of this non-polarized capacitor(samwha NF capacitor 50v 5.6uf) by means of MESR-100 ESR meter and It displayed 0.3 ohm
                And When I measured its capacitance with digital multimeter and LCR-T4 Mega328 meter, It displayed 10uf from DMM and 8uf from LCR-T4 meter.
                I found catalogue of samwha capacitor(samwha-catalogue_3.pdf file), which is attached to this thread,...
                06-02-2024, 07:31 PM
              • chth96
                Is it no harm to replace with capacitor without ripple current rating?
                by chth96
                When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
                Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
                But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
                Rubycon YK DataSheet (b...
                04-19-2024, 05:19 AM
              • chth96
                Should I replace polymer capacitor?
                by chth96
                a few days ago I finally purchased mser-100 v2 and I tested its abillity of measuring ESR value.
                I found that It shows pretty accurate ESR value for electrolytic capacitor,But When I measure polymer capacitor of dreamcast game console,I found that one third of polymer capacitor's ESR value is more than twice the value of ESR meter table.(for example, I measured one polymer capacitor of 6.3v 100uf, It showed ESR value of 7.68)
                Although my dreamcast now turns 20 years old but it still works. I occasionally have played game with it.
                Is this ESR value of polymer capacitor correct?...
                11-18-2022, 04:22 AM
