Hello. I'm curious about some of these ratings I've been seeing in the various tech docs. Is a higher ripple better? Also, how about ESR?
This is to replace 5 GSC caps that went to absolute hell after I put in my Radeon 9800XT and a new A+GPB 510w psu. The cpu is an Athlon XP barton core overclocked to 2.65GHz (not PR, true MHz). Put a bit of strain on the caps I believe and now my +5 is unstable and drooping to 4.75v even with an 800MHz Athlon installed sitting idle. The board is the original Epox 8RDA.
My system experienced instability and blue screens out of nowhere.. I checked my water-cooler but the temps were fine, everything looked ok until I saw the leaking/buldging caps.
I also added a resistor to a mosfet near the chipset and increase the VDD (chipset) voltage to allow higher FSB speeds. As it turns out, a GSC 1500uf/6.3v capacitor near the chipset was buldging as well.
I've already replaced the single 1500uf 6.3v with a Sanyo 1500uf/10v. Now all I have left is the four 2200/10's near the cpu and 4 other 1500uf/6.3's I'm going to replace anyway. The Sanyos near the cpu are fine, I trust.
Here is what I see in the documentation for Nichicon caps:
HE Series 2200uf 10v 10x31.5 "Low Impedance"
Impedance(20C/100kHz)0.031
Ripple (mA rms 105c/100kHz)=1910
PL Series 2200uf 10v 12.5x25 "Extremely Low Impedance, High Reliability"
Impedance(20C/100kHz) 0.034
Ripple (mA rms 105c/10kHz-200kHz) = 1710
I've already ordered the HE series 2200uf/10v. Should I have bought the PL Series instead? The numbers seem pretty close (but I'm a newbie when it comes to capacitors, so...). Also, can I use a higher uf rated capacitor (say, 2200uf) in place of the 1500uf that failed that was closest to the chipset? How about using four 3300ufs in place of the dead GSC 2200's?
If the PL is that much better I'll just order those and put the HE's into another board I have here. I really wanted the Rubycon MCZ 2200's but uh.. I'm sure I'd have better luck finding gold in my back yard.
Any suggestions on would be greatly appreciated. Thanks.
