Electrolytic capacitor leak in storage?
  • cloudff7
    Banned
    • Jul 2024
    • 3
    • usa
    there a risk of this aluminum electrolytic capacitor of electronic device long term storage opening and leaking acid and corroding the PCB board?
Name:	polymer-hybrid-aluminum-electrolytic-capacitor-product-image.png?VersionId=GaIJ9einvnYuPl9_w6qFsDBqBIBSku96&itok=AVPxFlEW.png
    • 31150
    with cheap rubish caps - yes.
    but it takes years
    • cloudff7
      Banned
      • Jul 2024
      • 3
      • usa
      but it takes years
      In the long-term storage of electronic devices, does the leakage of acid from the aluminum electrolytic capacitor that corrodes the PCB occur because the protective layers have been slowly corroded over the years and opened to release the acid in board?
      • redwire
        • 3912
        No. "protective layers" corroded? Work on your English. It's the rubber bung shrinking, drying out that allows the electrolyte to leak out in storage. It's uncommon unless they are cheap chinese capacitors that use recycled car tire rubber lol, or the reflow was too hot.
        • cloudff7
          Banned
          • Jul 2024
          • 3
          • usa
          Rubber is too brittle to hold corrosive liquid but do they use it? I don't know the manufacturers of the electrolytic capacitors in my devices, I have cartridge consoles from the early 90s, Philco and Toshiba CRT TVs from the early 2000s, PS2 slim 90000, and the most recent ones are TVBOX T95 Max Plus, power supply Chinese 5 and 12v, asus sata dvd drives all these devices use electrolytic capacitors and are stored
            • 21446
            TROLL
            https://www.badcaps.net/forum/general-topics/general-capacitor-questions-issues/88113-question-electrolytic-capacitor-from-1990`s?p=1710916#post1710916
            https://forum.digikey.com/t/shelf-li...apacitors/7946
            https://maker.pro/forums/threads/que...acitor.296053/
            https://maker.pro/forums/members/ele...recent-content
            https://maker.pro/forums/threads/que.../#post-1819948
            https://forums.tomshardware.com/thre...#post-22827718
            https://eepower.com/forums/members/c...recent-content
            https://forum.zwame.pt/threads/duvid...itico.1068226/
            https://www.electronica-pt.com/forum...-ja-respondido
            Post #4 Quote:
            User names:
            John rodrigues, johnroduigues, Gamer87, micksmelanie, James23051987, cloudff7(banned), johnmullins, scatmanjohn
            Forums:
            allaboutcircuits - micksmelanie (banned)
            Edaboard - Gamer87, John rodrigues
            ETO - cloudff7 (banned)
            Electronics Point - gamer87, johnmullins, scatmanjohn
            EEVblog - micksmelanie (banned), johnrodrigues (banned)
            EverDrive - cloudff7
            tutorbrasil.com.br - cloudff7
            electronica-pt.com - cloudff7 (banned)
            From Brazil, but claiming UK on two forums
            Obsessions:
            Storing things in ridiculous ways, flooding multiple forums, opening multiple accounts, asking the same question over and over
            Parece que não somos apenas nós por aqui....​
            • redwire
              • 3912
              Just confirming - do caps bulge and then leak although in storage?
              Aliexpress (Xnbada store) power supply, JCPOWER JC-10-5, 5V 2A. Unused although I remember doing a brief load test on it.
              Sits on my shelf for over 2 years and today I see this bulging cap 1,000uF 16V yung Li garbage brand. It's about 145uF and ESR 1.3Ω. IC is ME8115F.
              I'm assuming it made it's own gas, sitting there corroding inside- and then broke the vent.
Name:	JCPOWER JC_10_5 bad cap.jpg
              • petehall347
                • Jan 2015
                • 4430
                • United Kingdom
                i have seen lots going bad by not being used . maybe they had started going bad already though as they are on scrap boards .
                • redwire
                  • 3912
                  The stronger the electrolyte (acid H2SO4) concentration, the more capacitance you get. The corrosion-inhibitors, the missing secret sauce behind the "capacitor plague" I don't think are the problem here.
                  It's just china being cheap. But I didn't expect hydrogen bubbling while no voltage was applied.
                    • 31150
                    panasonic FC arent chinese or cheap, but i'v seen sozens of old ones leaking from the bung.
                    • redwire
                      • 3912
                      I think that's a manufacturing defect with the Panasonic FC and it's not enough to make the cap fail or wreck a PCB. Just a little green crud on the leads. Could be the wash, excess electrolyte during assembly on the leads.
                      It's not making enough hydrogen gas to bubble the top and vent and die lol.
                        • 31150
                        no, crust or puddles under them.
                        worst are sony psu's in SGI computers, and european/220v dreamcast psu's
                        • MORETTIGIAN
                          Capacitor detached from PCB – RTX 2070 Super Founders Edition
                          by MORETTIGIAN
                          Title:
                          Description:
                          During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
                          I did not notice it detaching, so I am unsure of its original location on the PCB.
                          Procedure performed:
                          - Removed backplate
                          - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
                          - Reapplied thermal compound
                          - Reassembled card
                          Observed behavior after reassembly:
                          - GPU powers on and operates normally under...
                          Yesterday, 12:14 PM
                          Samsung 4 Chromebook 4 11.6" 64GB Storage, 6GB RAM Notebook Specification for Upgrade or Repair
                          This specification for the Samsung 4 Chromebook 4 11.6" 64GB Storage, 6GB RAM Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Chromebook 4 11.6" 64GB Storage, 6GB RAM boardview and Chromebook 4 11.6" 64GB Storage, 6GB RAM schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                          09-06-2024, 12:00 PM
                          Samsung 4 Chromebook 4+ 15.6" (64GB Storage, 6GB RAM) Chromebook Specification for Upgrade or Repair
                          This specification for the Samsung 4 Chromebook 4+ 15.6" (64GB Storage, 6GB RAM) Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Chromebook 4+ 15.6" (64GB Storage, 6GB RAM) boardview and Chromebook 4+ 15.6" (64GB Storage, 6GB RAM) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on...
                          09-06-2024, 11:50 AM
                        • AleXis6
                          Manufacturing Date of Electrolytic capacitor
                          by AleXis6
                          Guys. could you help me please to decode some codes of main capacitor's producers.
                          I would like to know the manufacturing date.
                          Based on the information from capacitors I have - it seems easy to decode manufacturing date for Rubycon, Nichicon.
                          If I understood correctly:
                          1. Nichicons marks date of production as (see the attached pictures) H2116
                          I don't understand the meaning of first letter - may be it is code of factory.
                          21 -year
                          16 week
                          I bought this capacitor recently.
                          another one-
                          2....
                          10-11-2021, 02:20 PM
                        • Prolog
                          RTX 3080 FE Identifying capacitor
                          by Prolog
                          Hi people, I hope this is the correct spot to post this, I'm new to the forum.
                          I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
                          I hope these photos make it clear which component I am referring to:
                          (yes, the soldering is a bit botched from removing the blown one, I know)
                          I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
                          12-01-2024, 08:27 PM
