Diode or ic or capacitor
  • phillie112
    • Nov 2013
    • 8
    • philippines
    Hi good day fellas, im a newbie on board level so any capacitor, ic or diode i am unfamiliar of them, myonly question is what is the name of this ic or diode?
    http://i35.photobucket.com/albums/d1...pshwtaju6y.jpg
    Any reply will be appreciated. Thanks
  • phillie112
    • Nov 2013
    • 8
    • philippines
    Re: Diode or ic or capacitor
    Btw that is a motherboard from toshiba satellite a300-1eb laptop
    • popeye
      • May 2011
      • 155
      Hi
      Q83 is a 2N7002D = mosfet in card reader power circuit
      • phillie112
        • Nov 2013
        • 8
        • philippines
        Originally posted by popeye
        Hi
        Thanks for the reply, how about the other one below the Q83?
        I need to replace those two mosfett, what would i ask or what would write if i will buy those two?
        Again thank you sir
        • ben7
          Capaholic
          • Jan 2011
          • 4059
          Again thank you sir
          Q83 is NOT a 2N7002 ... a 2N7002 is a low-power mosfet, and would not come in that type of SMD package!
          Not sure what they are, as the lettering is just barely legible.
          Could you read us the letters on Q83 and Q73?
          BTW, that part marked 'C28' appears to have a burn mark on it!
          Muh-soggy-knee
          • phillie112
            • Nov 2013
            • 8
            • philippines
            Hi sir this is the specific value if those two ic or diode
            http://i35.photobucket.com/albums/d1...psjx5qjztr.jpg
            • ben7
              Capaholic
              • Jan 2011
              • 4059
              The top one is a Si7686 made by Vishay
              The bottom one is a FDMS8660 made by Fairchild.
              Take note that these MOSFETs have a pad on the bottom, so it will be hard to desolder them.
              Did you look at C28? Is it indeed burnt?
              Muh-soggy-knee
              • phillie112
                • Nov 2013
                • 8
                • philippines
                Yes sir the nec tokin is burnt and i replaced that with 330 Capacitor
                http://i35.photobucket.com/albums/d1...psdnfdqviz.jpg
                Now my only problem is where will i find that mosfetts. Thanks for the info.
                • ben7
                  Capaholic
                  • Jan 2011
                  • 4059
                  I honestly have no clue, since you don't live in the USA.
                  Do you know of any electronic component distributors that ship to the Philippines? In the USA we have Mouser and Digikey, but the shipping cost might be high shipping from the US.
                  Anyways, here is the Si7686 on Mouser:
                  http://www.mouser.com/ProductDetail/...FzaGCPA8j54%3d
                  And here is the FDMS8660 ... oh, according to Mouser it is obsolete! Do you want me to try to find a good replacement for it?
                  Muh-soggy-knee
                  • phillie112
                    • Nov 2013
                    • 8
                    • philippines
                    Yes sir, thats the big question i want to ask,
                    Is theresome kind of way to put a replacement mosfett for those two? And if so do i need to replace as well those two on the left outside of the encircled mosfett coz they are same.
                    And yes i need to hunt some kind of electronic shop here that supply thos kind of mosfetts, sorry the word mosfett is being abused in this conversation. Lmao.
                    • phillie112
                      • Nov 2013
                      • 8
                      • philippines
                      Up top on this, need some suggestions on what ic replacement
                      • MORETTIGIAN
                        by MORETTIGIAN
                        Title:
                        Description:
                        Procedure performed:
                        - Removed backplate
                        - Reapplied thermal compound
                        - Reassembled card
                        09-18-2025, 12:14 PM
                      • tranquility
                        newbie needs capacitor sizes. HP Spectre X360. schematic maybe available
                        by tranquility
                        hello, i am very new to laptop repair and generell electronics
                        i have a HP Spectre X360 Convertible 13 - ap0016ng
                        motherboard number DA0X36MBAE0 REV E
                        massive burned and shortet mosfets. after removing them still shortet in the i think "main power rail"
                        found a shorted capacitor. removed it and the short is gone.
                        i want to try a crazy repair which is hard because the mosfets are like welded on one side to the track. is there a method to get this loose ?
                        in this area another capacitor was shortet.
                        12-06-2024, 04:12 AM
                      • pbinet
                        Unfamiliar Zener Diode
                        by pbinet
                        I am a hobbyist electronics repairer and am working on a number of projects including a DVD player consumer SMPS 110V and I'm stuck with one component I can't identify that reads short. On the board it is identified as a zener diode and it connects in reverse between the control pin of the chip MIP2E4D and the secondary winding. The component length is 2.3mm. I have attached a photo and would appreciate any help
                        11-28-2024, 03:51 PM
                      • Prolog
                        by Prolog
                        12-01-2024, 08:27 PM
                      • Agent24
                        Dick Smith Q-1760 linear power supply filter capacitor question
                        by Agent24
                        I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
                        It has at least one problem.
                        The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
                        I have already ordered a replacement potentiometer, so that's not an issue.
                        Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
                        All are CapXon...
                        10-21-2025, 05:39 PM
