crazy unknown caps factory original from Lexus??
  • theOracle
    • Nov 2012
    • 163
    I have worked on a lot of Japanese equipment fixing blown caps, but this latest 1999 Lexus GS300 ECU has some crazy capacitors I have never seen before, are they counterfeit?
    This ECU has never been soldered on since new, so I have no doubt these capacitors are the originals.
    here is what I found:
    qty.1 - Matsushita 330uf - 35V marked: CE FZY
    qty.2 - Matsushita 47uf - 35V marked: FZY
    qty.2 - Matsushita 10uf - 35V marked: FCX
    qty.1 - Chemicon 47uF - 25V marked: BP (M) 110°C (this one is definitely bi-polar)
    qty.2 - Chemicon 100uF - 10V - no series marking! except for (M) 110°C
    qty.1 - Chemicon 220uF - 10V - no series marking! except for (M) 110°C
    qty.1 - Chemicon 33uF - 35V - no series marking! except for (M) 110°C
    an overheated and cracked 2SB605 transistor is marked:
    an overheated resistor is 2.7 ohm 2W metal film
    my questions:
    ● would a multi-layer ceramic cap be a good replacement for the bipolar cap, not knowing whether any of these caps are low ESR
    ● has anyone ever seen a Panasonic capacitor of series FZY or FCX
    ● has anyone ever seen brown Chemi-con caps with no series designation??
    ● do you think in 1999 that these are all low-ESR?
    ● isn't 110 C a weird temperature, most all higher temp caps are 105 C
    __________________
    the BIG 4
    ~~~ the top tier of low-ESR electrolytic capacitors ~~~
  • mockingbird
    • Dec 2008
    • 5488
    Re: crazy unknown caps factory original from Lexus??
    Not counterfeit in my opinion. I've seen an unmarked Chemicon cap in a disposable camera (Was the large resevoir cap for the flash). Never heard of FZY or FCX... FCX is probably a 110°C or 120°C specially rated automotive version of FHQ or FC... FZY could be a lower-ESR version of FC...
    • theOracle
      • Nov 2012
      • 163
      the Matsushi-ta (Panasonic) caps all say 105C - it is the unmarked Chemi-con's that say 110 C
      __________________
      the BIG 4
      • ben7
        Capaholic
        • Jan 2011
        • 4059
        I have an unmarked chemi-con from a flash unit too!
        I agree, the capacitors are probably custom.
        Muh-soggy-knee
        • Stachujones
          Dell XPS 13 9370 unknown USB devices in device manager
          by Stachujones
          Hello, i bought a faulty Dell xps 13 9370 after installing windows in device manager i Can see 2 unknown devices, one is thingerprint reader because it dissapears after i unplug it and second one is i believe bluetooth because it also doesnt work and in bios there is no bt also.
          Device manager says "unknown device, failed to request device descriptor"
          Can somebody point me in right direction what to check?
          I updated bios to the newest version and thunderbolt controller firmware still no luck
          04-05-2025, 07:35 AM
        • apostsamking
          dell latitue e5450 AC Adaptor unknown
          by apostsamking
          Hello everyone hope all is well. Pls I bought this second hand dell latitue e5450, I realize that the battery cannot be charged because it says ac adopter unknown at bios. I tried several chargers but still I get the same messageAC Adaptor unknown. So I open the laptop up checked the motherboard and i realised that the diod PD5 is fried so I changed, but I still get the same message, changed even the charging ic still the same message AC Adaptor unknown. Can any one help me?
          02-19-2023, 03:45 AM
        • TheUser
          Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
          by TheUser
          Hello to everyone ,
          This is my first post here, and i would like to share with you a small story in case you can help me.
          Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
          All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
          I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
          02-10-2024, 02:07 PM
        • mshone
          Lenovo thinkpad P1 G2 UUID and Serial number/mashine type unknown
          by mshone
          Sorry if topic if misplaced. Have lenovo thinkpad P1 gen2 with Xeon E-2276M CPU and NVIDIA® Quadro® T1000. It is a new board replaced. Old board was P1 G1 model with i7 and it is defective. I ordered a new one with xeon, but is gen 2. Laptop case is suitable for this motherboard, with some little difference (GPU fan and subcard).Ok, ordered and replaced and GPU fan and subcard and now laptop is working fine, but serial number and UUID is unknown. Ok, i readed several topics here and found Thinkpad maintenance disk, but.....which values to type? How to find data base with those values? serial...
          08-29-2025, 06:41 AM
        • Grucha98
          Dell 5300 NorthBay 18827-1 Charger unknown but 2v33 on PS_ID_R
          by Grucha98
          Hi i have problem with laptop. In bios I have idle and ac adapter unknown but on PS_ID_R i have 2v33. What voltage should be on PS_ID_R?
          Thx for help...
          10-10-2024, 12:31 PM
